Find the y-intercept of the tangent line to: -.4/ sqrt(3 + x) at
The discussion revolves around finding the y-intercept of the tangent line to the function y = -0.4/√(3 + x) at the point (2.5, -0.170560573084488). Participants are exploring the process of calculating the derivative to determine the slope of the tangent line and subsequently using that slope to find the y-intercept.
  • Mixed
  • Participants discuss using the Quotient Rule to find the derivative, with some suggesting rewriting the function to apply the Power Rule instead. There are questions about the correctness of the derivative calculations and the implications of using different methods.
Several participants have provided feedback on the derivative calculations, pointing out potential errors and suggesting alternative methods. There is acknowledgment of mistakes made in the derivative process, and some participants express uncertainty about the correctness of their results. The discussion reflects a collaborative effort to clarify the steps involved without reaching a definitive conclusion.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is an emphasis on ensuring accuracy in derivative calculations and the importance of correctly applying mathematical rules.
Lo.Lee.Ta.
1.Find the y-intercept of the tangent line to: y= -.4/√(3 + x) at [2.5, -.170560573084488]
2. So I thought the first step would be to find the slope of the tangent line.
I think we find the slope of the tangent line by taking the derivative.
So I am going to use the Quotient Rule to take the derivative.
[(√3 + x)(0) - (-.4)(.5(x + 3)^-1/2) * 1] / √(x + 3)^2
.2√(x + 3) / (x + 3) <----- This is the slope of the tan line to y= -.4/√(3 + x)
If we want to know the slope at x = 2.5, then wouldn't we plug in 2.5 for x?
So, [.2√(3 + 2.5)]/(2.5 + 3) = .085<----- This is the slope
Now, I thought we could substitute everything into y = mx + b in order to find out what b is.
-.1705606 = .085(2.5) + b
b = -.3831
3. But this is NOT the right answer!
Please tell me what I am doing wrong!
Thank you! :)
So, [.2√(3 + 2.5)]/(2.5 + 3) = .085<----- This is the slopeNow, I thought we could substitute everything into y = mx + b in order to find out what b is.
b = -.3831
Thank you! :)
Your derivative is wrong. What is u^(-1/2)/u? You aren't combining the exponents correctly. u^(-1/2)=1/sqrt(u). Not sqrt(u).
For calculating the derivative, instead of using the quotient rule, rewrite the equation:
y = -0.4/SQRT(x+3) as y = -0.4 * (x+3)^(-1/2)
Now, you have an eqn. of the form y = a u^n and you can use the power rule to get the derivative.
The Quotient Rule is useful when you are dealing with the ratio of two functions.
A better choice (because it's simpler and less prone to errors) would be write your equation as y = -.4 * (x + 3)-1/2
It's a good idea to keep track of what you're doing. For the above, you're working with the derivative, so this line should start with y' = or dy/dx = .
I see that you are including brackets around your numerator, so you've been listening. Good!
You have a mistake above that might just be a transcription error. At the beginning you have (√3 + x)(0) ...
That should be [(√(3 + x)(0)
You have a mistake above. You should have gotten
dy/dx = .2(x + 3)-1/2/(x + 3)
b = -.3831
Thank you! :)
To expand on what SteamKing said, you should NEVER use the quotient rule if either the numerator or denominator is a constant.
It's not incorrect to use it in this case, but it's more complicated, and the chances are greater of making a mistake.
For example, if f(x) = 2/(x2 + 1), write this as f(x) = 2(x2 + 1)-1 and use the chain rule to get f'(x) = 2(-1)(x2 + 1)-2(2x).
When I was working it out on paper, I left out the (-) on the -1/2 exponent!
Thanks for pointing that out!
So the Quotient Rule method is:
[.4(1/2(x + 3)^-1/2)]/(x + 3)
.2/(x + 3)^1/2 * (x + 3)
= .2/ (x + 3)^3/2
If I substitute the x = 2.5, then I get: .0155 as the slope.
I tried the Product Rule as well to see if I'd get the same thing.
So, -.4*-1/2(x + 3)^-3/2 + [(x + 3)^-1/2](0)
= .2(x +3)^-3/2
When substituting x = 2.5, I get the same slope of .0155
When I substitute everything into y = mx + b, I get: -.17056 = .0155(2.5) + b
b = -.209
...But this is not the right answer...
Do you know what could be wrong?
Is my derivative still wrong?
Thanks! :)
= .2/ (x + 3)^3/2
= .2(x +3)^-3/2
b = -.209
Thanks! :)
Now I don't see anything wrong with what you did. It looks correct to me. I get b=(-0.209324).
@Dick - Thank you so much for always helping me! :) You are kind.
I used the extra digits you found, and NOW the computer counts it as correct!
Thanks! :D
