Deriving equation for minimum height in projectile motion with two give me's
The discussion revolves around deriving an equation for the maximum height of a projectile launched at a 45-degree angle, given a horizontal displacement of 152.4 m. Participants are exploring the relationships between the variables involved in projectile motion, particularly focusing on how to express maximum height in terms of horizontal distance and launch angle.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to derive the equation Δy = {\frac{Δxtan(ϴ)}{4}} and are discussing the dependencies of maximum height and horizontal displacement on time and other variables. There are questions about the relationships between the kinematic equations and the specific variables involved.
The discussion is ongoing, with various participants offering insights into the relationships between the variables. Some have suggested starting over with the problem and re-evaluating the equations used, while others are questioning the assumptions made about the trajectory and the timing of maximum height.
Participants are working under the assumption of neglecting air resistance and are focusing on the kinematic equations relevant to projectile motion. There is a recognition that the launch and landing occur at the same vertical position, which influences the analysis of maximum height.
Ceeerson
deriving equation for minimum height in projectile motion with two give me's :)
A ball is launched at a 45 degree angle and lands 152.4 m away. What is the maximum height the ball will reach during its flight. I Know the answer, what I need is to find a way to derive an equation [itex]Δy = {\frac{Δxtan(ϴ)}{4}}[/itex] I have played around for hours working backwards and forwards with the equations below. Its miserable.
[itex]Δy = {\frac{gt}{2tan(ϴ)}}[/itex]
All kinematic equations
[itex]Δy = {\frac{gt}{2tan(x)}}[/itex] was the best i got - with the help of the internet. Though with it i have no idea how to solve for t. Help:(
What does the maximum height depend on?
What does the horizontal displacement depend on?
sorry the equation in the bottom is tangent of thetaθ, I'm not sure what you are asking, they are both dependent on time, assuming gravity is constant, apparently one is able to derive an equation and calculate max height using only the three kinematic equations.but the only known variables are angle of elevation and Δx, which is the final displacement from the origin.
Where θ is the launch angle and Δy and Δx stand for ...?
oh, Δy indicates the maximum height achieved by the ball, which is achieved at half the total time since the balls starting y position is negligible, Δx indicates the total distance covered in the x position of the coordinate system, so making the ball's starting position the origin, the coordinates for the ball at max height are ((Δx/2),Δy) and the coordinates for the ball after it lands are (Δx,0)
and yes, θ is launch angle above the horizontal
Ok, so assume some launch speed u and write the equations for x and y as functions of time. Assuming level ground, what will x be when it lands?
Δx = utcos(θ), Δy = ut/2sin(θ) - 1/2g(t/2)^2 Δx = 152.4m
and (usinθ)/2g = Δy
Ceeerson said:
Δx = utcos(θ), Δy = ut/2sin(θ) - 1/2gt^2 Δx = 152.4m
I meant the generic equations that apply throughout the trajectory, but never mind. In the above, t is the total flight time, right? If so, the second term in the expression for Δy is wrong.
Write another equation for the height at time t.
ok so I am going to start this problem over. ok so
in the y direction, Δy = (vsinθ)t - (1/2)gt^2; Vf = Vsinθ - gt; vf^2 = v^2sinθ^2 - 2gΔy
in x direction, Δx = Vcosθt
so I am guessing i rearrange for t using the x equation, so t = Δx/v(cosθ)
then i plug it into the first equation? let's see Δy = vsinθ(Δx/v(cosθ)) - (1/2)g(Δx^2/v^2(cos^2θ))
if i simplify it, Δy = (Δx)tanθ - (1/2)gΔx^2/cos^2θ
am i in the right direction ?
Those equations are all correct, but you need to think about the specific points in the trajectory at which to evaluate them. For which instants do you have data?
i just have the final displacement in the x direction, i was just guessing that since the launch starts and ends on the ground that half the time wouldd be at max height, neglecting air reistance
No, you have more than that. What is the final y displacement? What is the x displacement when at max y displacement?
10K
28K
