Question about electric generators
The discussion revolves around the design and operation of electric generators, particularly in the context of high voltage generation for power transmission. Participants explore the practicality and implications of using high voltage generators directly connected to transmission lines, as well as alternative methods such as electrostatic generators.
  • Some participants question why generators are not designed to produce high voltages directly for transmission, suggesting that connecting multiple generators in series could be a solution.
  • Others argue that insulation requirements for high voltage generators make this impractical, as the dielectric threshold could lead to arcing and shorts.
  • One participant notes that large generators typically operate synchronously with separate exciters to manage reactive power, challenging the idea that they are grid-excited.
  • There is a discussion about the efficiency of HVDC (high voltage direct current) transmission over long distances, with some participants expressing that it is becoming increasingly relevant.
  • Participants explore the concept of electrostatic generators, debating whether they produce AC or DC power and discussing their potential applications and limitations.
  • Some contributions suggest innovative ideas for harnessing energy from electrostatic generators, including the use of induction coils and the conversion of static discharge into usable energy.
The discussion contains multiple competing views regarding the practicality of high voltage generators and the nature of electrostatic generators. There is no consensus on the effectiveness or feasibility of the proposed ideas and concepts.
Participants express uncertainty about the definitions and operational principles of electrostatic generators, as well as the implications of high voltage generation in practical applications. The discussion reflects a range of assumptions and conditions that have not been resolved.
Bararontok
Generators in power stations are usually connected to step-up transformers to boost their output voltages for long distance power transmission, but why not just use a generator that has been designed and built to produce really high voltages and just connect the generator directly to transmission lines or connect multiple generators in series directly to the transmission lines to produce the really high voltages?
The insulation requirement - turn to turn in the generator makes it impractical. The spacing between the actual conductors (turns).
Although I believe ABB tried to make a HV Cable based generator - some years ago, obviously never caught on.
That's a good question, but you're missing a teeny-tiny detail. Large generators have to be excited by the grid and that's why they operate at the same voltage. They return energy in the form of current, while maintaining the same voltage. You want to think of the step-up/down transformers as an interface for the special case that the energy is transmitted at a large distance (hundreds of kilometers). Additionally, if we followed your logic, then what if the generator is near a consumer area, and your generator created a high voltage, in that case you'd have to use a step-down transformer. Or manufacturers would have to design high-voltage and low-voltage generators depending on where a generator is used. Not practical at all! Transformers keep things real :)
The step down transformer will still be used. It is only at the power producing end where the voltage has to be raised where the transformer and standard voltage generator will be replaced with a high voltage generator. But as was mentioned previously, this would cause an insulation problem in the turns of the generator because the high voltages would overcome the dielectric threshold voltage of the air gaps and contact resistance of the turns and create shorts which could produce arcing. This problem could be solved by insulating the turns but that would require impractically thick insulation which would make the generator needlessly large and heavy and interfere with the exposure of the turns to the rotating magnetic field of the generator's rotor by blocking the magnetic field and distancing the turns from the rotor which would lower or completely prevent the generator from producing an electrical output.
But why not just use an electrostatic generator that uses triboelectric and electrostatic inductive effects to produce the electricity to avoid using induction coils in the generator?
Hassan - I beg to differ - large generator are not excited by the grid - they are 99.9% ( every one I have seen) of the time synchronous generators with separate exciters - necessary to manage reactive power (KVARS). Anything that is grid excited would need to be connected to the grid to be started -with systems this large that just can not be done.
Actually the MV level (15-22KV) generation causes other problems because the current levels are very high ( >10KA... >100KA Fault current etc) and difficult to control, so large generators are almost always stepped up immediately to make the currents more manageable. In some cases the Gen is connected directly to the step up transformer with no breaker, and then the primary CB is at the higher voltage.
Windadct, I was under the impression that most generators are asynchronous. I guess I was mistaken.
Bararontok, if by electrostatic generator you mean DC generators, I can tell you about the last power generation, transmission, & distribution conference I attended. There was a lot of babble about HVDC power transmission (in Europe). If I understood correctly, over larger & larger distances it's more efficient to do so, especially now that the Old Continent's grids are becoming increasingly interconnected, with projects in renewable energy carried out all over by the European Commission in renewable. The way I see it, HVDC generation, and transmission is becoming more relevant but still a long way to go. Of course this is all debatable, and viewpoints clash regarding this subject, and even at the conference I attended. But in my opinion, the HVDC proponents have a lot of ground to support them. I hope I'm not starting the old Tesla vs Edison debate now! :smile:
Yes, the electrostatic generators produce DC power. This is usually done by using similar or different materials that can have their balance of charges altered by placing them close together while being electrically grounded and then disconnecting the circuit or rubbing the materials together to transfer charge to the other material. The electricity is then produced by letting the charged material discharge the electric current until the charges are balanced and then the process is repeated. The constant mechanical movement needed by the materials is of course provided by a source of mechanical power. But is it not possible to also extract energy from the source of power so that the first movement cycle of the generator transfers charge to material 1, the current is then discharged and the charges balance, the charge is then forcibly transferred to material 2 and the current is discharged but because it is being discharged by material 2, there is a reversal in the polarity of the current and this produces AC power as a result. After all, why does the charge transporting only have to occur in one direction?
Sorry, but electrostatic genrators do not produce DC.
So the electrostatic generators produce AC after all.
Static is it's own form of electricity. If you figure out how to convert it to useable energy, don't tell anyone and let me know.
There is a type of device on this link that explains how the electrostatic generator works:
http://en.wikipedia.org/wiki/Electrostatic_induction#Explanation
The neutral material is placed in closed proximity to the electric field of a charged material. This causes the electrons in the neutral material to move to the end that is closer to the charged material. When the neutral material is rotated and the other side is placed in close proximity to the charged material, the electrons that previously accumulated on one side will now flow to the other so constantly rotating the neutral material while it is close to the charged material will cause the electrons to constantly shift from one side to the other, producing an alternating current. By placing electrical contacts on the neutral material, is it not possible to make the current flow through a circuit?
I understand electrostatic generators - but the stored charge can not be used for anything - at least not easily. As for large generators per the OP - the is nothing close to harnessing static that even comes close. You can maybe light a neon bulb - but not run an air conditioner.
What about shaping the neutral material into an induction coil so that when the charges oscillate back and forth, electromagnetic radiation is discharged and this radiation can be absorbed by a nearby material such as an induction coil or photoelectric material to convert the energy back into electricity?
Static is just accumulated charge producing an electric field that want to be discharged (like when you touch the doornob in a cold winter). There is energy in there, but it's discharged instantaneously as soon as it finds a path to do so, and that's not useful in any way shape or from. Unless you're talking about harnessing static discharge like from lightning bolts, and then converting that to DC or AC, then that's alright, and there are people working on that actually. But if you mean using static in lieu of AC and DC then that really makes no sense. We need a steady flowing current in our devices, and not just a quick jolt of energy that would do nothing but make it chaotic.
In addition to what "Windadct" said about the problems in construction because of the very large number of turns, there is also a problem which that not all MV and HL voltages are the same, so in some cases you want to increase the voltage up to 6.6kv, while in some networks you want to increase up to 11KV, so with transformers you will have this advantage also.
So this means that static discharge is not as consistent as current produced from other types of phenomenon and because of this it is not advisable to use it to run loads. But what about my suggestion on this post:
https://www.physicsforums.com/showpost.php?p=4232549&postcount=13
Where the radiation emitted by the constantly oscillating flow of static electricity will be converted into electricity by a photoelectric material or induction coil.
Or what about intentionally placing a spark gap in the electrostatic generator to produce an electric arc and converting the heat energy and radiation emitted by the arc into electrical energy by some type of material that can perform such an energy conversion?
Although the problem with such a system would be the high operating voltage of the device. Since the material that will convert the energy of the electrostatic rotor is close to it, the high voltage would cause a static discharge into the device lowering the net charge of the rotor. When this happens, the rotor's ability to be influenced by the electric field of the charged material would weaken until the charged material can no longer influence the rotor and there would be no more static electricity in the rotor. Connecting the rotor into contacts to make an electrical circuit would also cause the same problem. The static electricity will discharge into the external circuit until charges balance and lower the net charge that is close to the electric field of the charged material. This will also lower or eliminate the charged material's capability to influence the rotor and no more power output will be produced as a result.
Perhaps the only way to harness static electricity's energy would be to hypothetically get enough electrically charged material if it even exists and connect an external circuit between it and the ground. Or connect an external set of circuitry between a lightning rod and the ground as suggested in this post:
https://www.physicsforums.com/showpost.php?p=4232624&postcount=14
And use that energy. But then transformers would still be needed because different transmission lines use different voltage levels since there is no universal standard for high voltage transmission.
But what about substituting the rotor magnet of generators that use the electromagnetic induction phenomenon with an electrically charged material and spinning that instead, using its rotating electric field to move the electrons in an external circuit? But then again, the high voltages induced would pose insulation problems. And, since to convert the mechanical energy into electricity efficiently requires the rotor to be as close to the coils as possible without making contact, the close proximity of the coils to the spinning charged material could cause the charged material to discharge static electricity into the external circuit, eliminating the electric field of the charged material and rendering the generator unable to produce an output, again posing insulation problems.
You need to go back to first principles, and you'll see why everything you've proposed becomes awful complicated.
Charge exists everywhere, but for practical purposes, it isn't useful whatsoever unless it is moving nicely in a predictable manner, with amplitude and direction. Your typical copper wire has 8.5×1028 free e-/m3--that's a lot. You can harness them all you want using a static generator but what for? You want them moving down the cable that's what powers your light bulb.
The point of electric power generation is to get electrons moving in a closed loop. It's true on any scale. That's what your battery does, small/large generator, etc. So to say let's replace the battery with a charge accumulator, then create some mechanism to make that charge flow nicely is, in my opinion, as strange as saying let's suck all the fresh water from a stagnant river, pump it onto an uphill pond (at a higher potential), then let it flow again. But I assure you, it will stagnate again. It's a lot smarter (& efficient) to use the water pump to give it that lil nudge to move in its preferred direction.
This is what I mentioned in this post:
https://www.physicsforums.com/showpost.php?p=4233161&postcount=16
It turns out to produce so many complications and inefficiencies that it is just not practical. Things would actually work more efficiently with the current electrical generation methods. Besides an induction alternator has an efficiency of up to 97% and a transformer has an efficiency of >90% so the grid is already very efficient as it is.
In conclusion, what you said about using the conventional induction electromagnetic generator to give the electrons a steady nudge is better and more controlled than forcing the charge distributions to change and letting the distribution equalize then repeating the process which is inefficient and produces an output that is unstable and difficult to control.
What's in a name?
That's why, when first starting out with beginners i stress that "E" for Voltage is short form of "EMF",
which is the abbreviation for Electro Motive Force", a good name for it
which should be thought of backwards: Force that Motivates Electrons (to move).
Then one can introduce the concept of potential, absolute and differential, with finger on the table,
and from that it follows naturally that work = Force X Distance...
Some people need that kind of visual aid in order to gain confidence in the equations.
Not lecturing you guys, just I've seen this method help struggling newbies. Hope it helps you help someone.
It now seems we have 2 threads in one ...
Back to the OP to clarify "Generators in Power Stations" - to be large scale > 100MVA, this is where the issue of a step up transformer is most relevant.
The issue of practical energy harvesting from static - is a completely different topic. -- really should not be in the same discussion.
Alright, my questions have been completely satisfied. Thank you very much for the advice. If ever I have more questions about this, I will post it here or in a different thread.
jim hardy said:
What's in a name?
But the force the gets electrons moving would have to be Lorentz force. How could it be otherwise? F = Fe + Fm = q(E + uXB).
I am not positive about the origin of the term "emf", but it is not at all a real force. In the early days before Lorentz force was known about, "emf" was coined and it stuck since then although we now know that the force acting on electrons is indeed Lorentz force. Just thought it should be mentioned. BR.
Claude
Thanks Claude
i was never quite sure whether Lorentz included both magnetic and electric fields - so just now i looked at hyperphysics and it appears that it does, just as you said.
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magfor.html
From a thread earlier this year:
https://www.physicsforums.com/showthread.php?t=588037
I've got to where i try to understand why things got the name they were given.
To that end it's sometimes helpful to parse acronyms backward like we do for RMS.
Term EMF is acronym for Electro-Motive-Force , that is a Force that Moves Electric Charge. (in some circles, that'd be electrons)
It is not implied by the name of that term whether the origin of the Force is elecrostatic, magnetic , thermoelectric , or electrochemical.
And that's how i answer that question.
GM's "Electromotive Division" makes those beautiful railway locomotives.
Every time i see one my thoughts leap to the huge generators and traction motors inside, and QV cross B. Now THERE"S some torque !
Wouldn't it be fun to be see the charge getting shoved sideways inside those conductors?
old jim
Hi Jim,
I would say that just as "emf" is not an actual force, it is equally true that "mmf" is also not an actual "force". The term "mmf" is "magneto-motive force". As I said, neither is actually a force, but generators, motors, & transformers were examined prior to 1890-91, which is when Lorentz published his force equation. Induction was measured & the terms "emf" & "mmf" were coined. Based on known mAcroscopic laws, it was postulated at the mIcroscopic level, that induction must involve forces acting on charged particles. So the terms were coined. We still use emf & mmf when describing xfmrs, motors, & generators, without a problem since it is understood that the "f"'s in emf/mmf are not true "forces".
Anyway, this is an interesting discussion. Thanks Jim, for your contributions.
Claude
Isn't all this a bit 'speculative'?
Magnetic induction is a very good way (tried and tested) to generate electric power at useful AC voltages which can be conveniently transformed up and down, to suit - and at enormous powers. Electric induction can be used to pump charge into a circuit but the system is not "electrostatic" if it is supplying 'current' electricity. The area involved in making what would be, in effect, a massive Whimshurst Machine would be in the order of Football pitch size if you wanted to produce any significant power. Something like the London Eye perhaps?
Hmmm i always stumble a bit when learning something new. Please forgive.
An electron moving in a magnetic field assumes a curved trajectory, as in a CRT with magnetic yoke,
Does not its acceleration away from the straight line result from one term of "Lorentz Force Law" , QV cross B ?
How should i conceive of it if not a force? Is Lorentz Force Law misnamed?
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magfor.html#c2
not being argumentative here, just i'd like to step up to next level of understanding.
Guess I'm stuck in the(18)90's. Been reading Sylvanus P Thompson...
old jim
old jim
Your conception of Lorentz being a force is quite correct. It is a true force in the full sense of the word. The "forces" that I referred to as not being true "forces" are the "electro-motive force", & the "magneto-motive force" as well. Lorentz force is rightly named, but "emf/mmf" are not. But there is no harm in using the emf/mmf terms when describing induction because it is understood that these terms were coined while there was still more to learn about the subject.
This happens elsewhere as well. We use the term "centrifugal force". Is it really a true "force". Inside the rotating reference frame it is valid. It's inclusion maintains Newton's laws in that rotating frame. But in an inertial reference frame, if we draw free body diagrams of all forces acting on the body in circular motion, there is no "centrifugal force" at all. It is merely a math construct employed when viewing circular motion while inside the rotating frame of reference.
We use the phrase "centrifugal force" knowing how it should be construed. There is no need to acknowledge the nature of said quantity every time it is mentioned, so we don't. Likewise, emf & mmf are understood as being related to volts/turn & ampere-turns. When summing forces acting on charges, we use Lorentz forces due to E & B fields with velocity taken into account. A free body diagram of the forces acting on a charge carrier does not include "emf or mmf", because they are not actually forces.
I hope this helped. Best regards.
Claude
Claude - it helped far more than you know.
Thank you.
old jim
"Science is but language well arranged" - Lavoisier
Shame about the term 'emf'. It's really hard to think in terms of fields (volts per metre) producing force on a charge when the wires connecting the two terminals of a source of emf are taken round the room and back again. Where's yer volts per meter then? This hypothetical field is shared out all over the geometry of the circuit.
  • · Replies 37 ·
9K
  • · Replies 47 ·
