Pseudoscalars and pseudovectors
  • Context: Graduate
  • Thread starter Thread starter copernicus1
The discussion centers on the concepts of pseudoscalars and pseudovectors, particularly their behavior under parity inversion. Participants explore the definitions and properties of these mathematical entities, including their parity eigenvalues and how they differ from ordinary vectors.
  • Technical explanation, Conceptual clarification
  • One participant notes that a pseudoscalar changes sign under parity inversion, citing the determinant of a matrix as an example and mentioning that pseudoscalar particles have a parity eigenvalue of -1.
  • Another participant asserts that an ordinary vector changes sign under parity inversion, implying that a pseudovector must not change sign.
  • Some participants discuss the directional behavior of pseudovectors, suggesting that after reflection, a pseudovector is reversed in direction, while a vector is simply reflected.
  • A further elaboration is provided on the behavior of polar vectors versus pseudovectors, indicating that a polar vector has its component normal to the mirror reversed upon reflection, whereas pseudovectors do not exhibit this behavior.
Participants express varying degrees of understanding regarding the definitions and behaviors of pseudoscalars and pseudovectors, but no consensus is reached on the implications of these properties or their applications.
The discussion does not resolve the underlying assumptions about the definitions of pseudoscalars and pseudovectors, nor does it clarify the implications of their parity properties in broader contexts.
copernicus1
I remember learning that a pseudoscalar is one that changes sign under a parity inversion, like the determinant of a matrix. Pseudoscalar particles have parity eigenvalue -1. Why is it that pseudovector particles have parity value +1?
An ordinary vector changes sign under a parity inversion, so a pseudovector must not.
I think I get it. A pseudovector, after being reflected, is also reversed in direction. A vector is simply reflected.
Another way to look at it: A polar vector (or true vector) has the component normal to the mirror reversed upon reflection. Pseudovectors don't. Stand in front of a mirror and point straight at your reflection. Your reflection is pointing back at you, opposite the direction you are pointing. Now rotate some object so that the axis of rotation is into the mirror. The axis of rotation reflected image is also into the mirror, unaffected by the reflection.
  • · Replies 0 ·
