Thermodynamics and Mechanics questions
The discussion revolves around thermodynamics and mechanics problems involving heat exchange between two blocks, centripetal force in circular motion, and motion under constant acceleration on an inclined plane.
  • Mixed
  • The original poster attempts to solve problems related to heat transfer, centripetal motion, and kinematics but expresses uncertainty in their approaches.
  • Some participants question the assumptions made in the centripetal force problem, particularly regarding the conditions for maintaining tension in the string.
  • Others suggest using kinematic equations to analyze the motion of the ball on the inclined plane, noting the relationship between time and displacement under constant acceleration.
Some guidance has been offered regarding the centripetal force problem and the kinematics of the ball on the incline, with participants exploring different interpretations of the problems. The original poster has indicated progress on the first question but still seeks clarification on the remaining questions.
The original poster is self-studying and has expressed difficulty in solving the problems independently, indicating a need for support without direct solutions.
nasar176
I am self studying and I can't ask anyone else so can you please help me out with these problems?
Two blocks of iron, one of mass m at 10.0C and the other of mass 2m at 25.0c, are placed in contact with each other. If no heat is exchanged with the surroundings, which of the following is the final temperature of the two blocks?
A)10
B)15
D) 20C ( this is the answer)
I have no idea how to solve the above problem I don't kno, any help would be really apreciated.
Q2) A 1kg block attached to a string revolves in a vertical circle of 1 meter radius near the surface of the earth. what is the minimum speed of the block which will keep the string taut all the time?
The answer is (9.8)^1/2. I tried using the centripetal force formula and the acceleration formula but i couldn't somehow come up with an answer.
Q3) A ball, initially at rest at t 0 sec, rolls with constant acceleration down an inclined plane 10m long, if the ball rolls 1 meter in the first 2 sec, how far will it have rolled at t=4 secs?
for this question i just added the 2 four times and got the answer 8 but the book says the answers is 4 meters
ok i figured out the 1st one, just need help with the others
For Q2, think about the "worst" case (since it asks for the minimal speed - which will barely keep the string taut). When the block is at the top of the circle, both gravity and tension contribute to the centripetal force, therefore
[itex]F_g + T = \frac{mV^2}{R}[/itex]
In the worst case scenario (the minimal speed), the string is barely taut - which means it is barely pulling the block - so you can say T = 0 for the minimal speed. Therefore
[itex]mg = \frac{mV^2}{R}[/itex]
[itex]V = \sqrt{Rg}[/itex]
which results in 9.8^(1/2) :)
For Q3, the "easy way" is to remember that, for constant acceleration, [itex]\Delta S = v_ot + at^2/2[/itex], so as Vo = 0, [itex]S \alpha t^2[/itex], where S stands for the displacement.
Therefore, if you double the time, the distante will be multiplied by four (since it depends on the square of the time), which gives you 4m.
Did i make any sense? :P
Thank you sooo much!
  • · Replies 47 ·
  • · Replies 37 ·
