Understanding the Equalizing Nature of Negative Feedback in Op Amps
  • Thread starter Thread starter sidvelu
    Amp Op amp
The discussion focuses on the equalizing nature of negative feedback in operational amplifiers (op amps). When negative feedback is applied, the output voltage drives the inverting input closer to the non-inverting input, ensuring both inputs are equal. This principle applies to both inverting and non-inverting configurations of op amps. The relationship is defined by the equation V_{out}=A\cdot(V_+-V_-), where A represents the gain of the op amp.
  • Understanding of operational amplifier (op amp) fundamentals
  • Familiarity with negative feedback concepts
  • Knowledge of inverting and non-inverting op amp configurations
  • Basic grasp of voltage output equations in op amps
  • Study the principles of negative feedback in op amps
  • Learn about the differences between inverting and non-inverting op amp configurations
  • Explore the mathematical modeling of op amp circuits
  • Investigate practical applications of op amps in signal processing
Electronics students, circuit designers, and engineers interested in understanding operational amplifier behavior and feedback mechanisms.
sidvelu
I understand how to apply op amps, but one thing about op amps had bugged me for some time. I want to know what about an op amp in negative feedback forces both the posotive and negative inputs to be equal. And could your explanation be for both an inverting and non inverting op amp.
Thanks! :)
Welcome back to PF.
If the (-) input were significantly lower than the (+) input, that would drive the output high, since [itex]V_{out}=A\cdot(V_+-V_-)[/itex]. And because of the feed back to the (-) input, driving the output high would raise the voltage at (-) input, driving it closer to the voltage at the (+) input.
A similar argument applies to considering if the (-) input were significantly higher then the (+) input.
Not sure what you mean here. Op amps are not "inverting" or "non inverting", those terms refer to the two inputs of any op amp. The explanation only works for feedback to the inverting input, that I refer to as (-) above.
oh okay, that makes more sense now. I should've drawn that conclusion on my own, but i guess i was just being stupid.
Thanks a lot!
  • · Replies 33 ·
  • · Replies 50 ·
