Maths statement for point when condition is met some fraction of the time
The discussion revolves around finding a mathematical expression to represent the condition where a function, f(x), exceeds a certain threshold (y) 95% of the time in the presence of noise. Participants explore the appropriate nomenclature and notation for this concept, which is relevant in statistical modeling and experimental data analysis.
  • One participant seeks a mathematical expression for the statement "f(x) > y 95% of the time," emphasizing the need for proper nomenclature.
  • Another participant suggests that the concept relates to a "95% confidence level," but this is contested by the original poster who notes the non-normal distribution of their data.
  • A participant clarifies that they are fitting a model to data using chi-squared statistics and are interested in the point where a certain percentage of results are successful.
  • There is a discussion about the applicability of confidence intervals to non-normally distributed data, with some arguing that confidence intervals can apply to chi-squared distributions.
  • One participant proposes using probability notation, suggesting that the expression could be represented as p(f(x) > 10) = 0.95, indicating an estimation of the probability.
  • Another participant mentions the use of a caret symbol to denote estimation, suggesting a notation like \hat p_{1000}(f(x) > 10) = 0.95, but emphasizes the need for accompanying explanations.
Participants do not reach a consensus on the correct mathematical notation or nomenclature. There are competing views on whether the concept relates to confidence levels and how to express the desired condition mathematically.
Participants express uncertainty regarding the distribution of their data and the implications for statistical notation. The discussion highlights the complexity of conveying probabilistic statements in a mathematically rigorous way without assuming a specific distribution.
jimbof85
Hello all,
I would like to express the following as an equation, but don't know the nomenclature.
'The point at which a condition is true 95% of the time'
ie. I have a function, f(x) which returns some value in the presence of random and uncharicterizable noise. I run this 1000 times. I find the condition f(x)>10 is true 50% of the time. I adjust f(x), and rerun 1000 times and find f(x)>10 is true 80%. I keep rejecting f(x) until I reach the point where f(x)>10 for 95% of samples.
Basically I want something like (f(x) [itex]\stackrel{95\%}{>}[/itex]10)1000
but there is bound to be a correct way to do this
Thanks
James
Sounds to me like you are talking about a "95% confidence level".
Hi HallsofIvy,
Thanks for the reply. It is not (I believe) fair to talk about confidence levels in the way I think you suggest - this is not a normally distributed random variable, it is not a two tailed distribution. I am in fact fitting a model to my data to get a chi sqrd, comparing this chi sqrd to a threshold, and if it is below this claim a success. I simply extract the point where some percentage of these results are successes - I chose 95%. The distribution of the number of successes in each of the many variations of the experiment is not normally distributed. I simply want an mathematical expression that says the equivalent of 'x > y 95% of the time' rather than 'x>y'
Sorry i can't put it clearer than that!
jimbof85 said:
Hi HallsofIvy,
Confidence intervals are not limited just to normal distributions. This concept can be applied to ##\chi^2## distributions for inferences about ##\sigma^2 ##. The hypothesis tests can be one-tailed or two-tailed.
Hi Mark44,
Thanks for the reply. Ok, I understand your point, but i am not asking for a confidence interval. My question is on nomenclature. I simply need a mathematical way of conveying the following statement 'f(x) > y 95% of the time'. I do not need the distribution behind it, or the mathematics that control it - I am just after the correct symbols to properly convey that I have chosen a set of values for f(x) such that it meets some criterion for some fraction of realisations of the experiment.
Thanks
Just to further clarify, I simply want to do as follows, take an expression in words and write it using mathematical notation. i.e.
'x is a complex number' : [itex]x\in C[/itex]
'natural log tends to infinity as x tends to infinity' : [itex]\lim\limits_{x\to+\infty}[/itex][itex]\ln(x)\to+\infty[/itex]
'f(x) > y 95% of the time' : ?
Thanks for your help
It seems to me that, if P(E) denotes the probability of an event E, you are referring to an estimation of the following statement:[tex]p(f(x) > 10) = 0.95[/tex]This statement, however, speaks of a theoretical (and unknown) probability, which your experiment is trying to estimate. An often used notation is to write a caret or "hat" symbol over the letter, to denote it is an estimation:[tex]\hat p_{1000}(f(x) > 10) = 0.95[/tex]But I think it is unavoidable to accompany these lines with a few words in plain English (as I did) that define what p-hat means in your context. My 2 cents.
  • · Replies 40 ·
  • · Replies 21 ·
