What is the condition for one-dimensional motion in an infinite potential well?
The discussion revolves around the conditions for one-dimensional motion in an infinite potential well, focusing on the wave function, its implications for particle motion, and the types of particles that can be modeled within this framework. Participants explore theoretical aspects, mathematical formulations, and interpretations of quantum mechanics.
  • Some participants assert that one-dimensional motion is implied by having a single distance variable, x.
  • There is a discussion on whether the wave function describes the motion of a particle, with some suggesting that the Schrödinger equation governs the evolution of the state in time.
  • Questions arise regarding what types of particle masses are suitable for the infinite potential well model, with one participant suggesting that any mass can be used, but larger masses lead to closely spaced energy levels.
  • Participants debate the significance of the wave function's phase, particularly regarding why ##\phi_{-n}(x)## is not drawn, with one stating it is the same state as ##\phi_{n}(x)##.
  • There is mention of superposition states and the probabilistic nature of measuring energy levels, with interpretations of quantum mechanics affecting how one views the state of the particle.
  • Some participants express confusion about the normalization of wave functions and the implications of coefficients in superposition states.
Participants express varying interpretations of the wave function and its relation to particle motion, with no consensus on the implications of the wave function or the types of particles that can be modeled. The discussion remains unresolved regarding the specific conditions for one-dimensional motion and the interpretation of quantum states.
Limitations include the dependence on interpretations of quantum mechanics, the need for specific situations to determine coefficients in superposition states, and unresolved mathematical steps in the normalization process.
This discussion may be of interest to students and researchers in quantum mechanics, particularly those exploring the foundations of wave functions, potential wells, and the implications of different interpretations of quantum theory.
matematikuvol
In one dimensional problem of infinite square potential well wave function is ##\phi_n(x)=\sqrt{\frac{2}{L}}\sin \frac{n\pi x}{L}## and energy is ##E_n=\frac{n^2\pi^2\hbar^2}{2mL^2}##. Questions: What condition implies that motion is one dimensional. Did wave function describes motion of particle? When we say particle did we mean electron? What kind of particle mass are good enough to be treated in this model? And also why we don't draw ##\phi_n(x)##.
one distance variable x, implies one dimension.
In quantum mechanics, the analogue of Newton's law is Schrödinger's equation for a quantum system, usually atoms, molecules, and subatomic particles; free, bound, or localized. It is not a simple algebraic equation, but (in general) a linear partial differential equation. The differential equation describes the wavefunction of the system, also called the quantum state or state vector. In the standard interpretation of quantum mechanics, the wavefunction is the most complete description that can be given to a physical system. Solutions to Schrödinger's equation describe not only molecular, atomic, and subatomic systems, but also macroscopic systems, possibly even the whole universe.[1].....
In quantum mechanics, particles do not have exactly determined properties, and when they are measured, the result is randomly drawn from a probability distribution. The Schrödinger equation predicts what the probability distributions are, but fundamentally cannot predict the exact result of each measurement.
The Heisenberg uncertainty principle is a famous example of the uncertainty in quantum mechanics.
http://en.wikipedia.org/wiki/Schrödinger_equation
be sure to see the dynamic illustration near the beginning of the article here...http://en.wikipedia.org/wiki/Infinite_square_well
The picture you must draw is a string (one dimension) vibrating between two fixed point (the walls of the potential) - distance L. The harmonics are the quantum excitations of the same particle or elementary system - p_n = n h / \lambda . This gives you the quantized momentum spectrum, that is the harmonic discrete spectrum a guitar string. The energy spectrum follows from the non-relativistic dispersion relation E = p^2 / 2 m.
I didn't get the answer that I'm looking. My questions:
And
And also why we don't draw ##\phi_{-n}(x)##?
For motion you need to solve the Schrödinger equation. The wavefunctions you are talking about are solutions to the energy eigenvalue equation, but it is the Schrödinger equation that gives you the evolution of state in time.
Anything I guess. You have an expression involving m, and you can plug in whatever you want for m. If m is large then the energy levels are closely spaced which is good as that is common experience.
[itex]\phi_{-n}(x)[/itex] is the same state as [itex]\phi_{n}(x)[/itex] as they only differ by a phase.
What about post #2 did you not understand?
Did you read the links I posted...they will help a lot.
" Interpretations of quantum mechanics address questions such as what the relation is between the wavefunction, the underlying reality, and the results of experimental measurements."
There are different interpretations about exactly what the wavefunctions means...there are different ways to think about it.
Usually in one dimensional problem you can constrain a particle between two infinitely large parallel plates, that makes the particle only subject to the boundary conditions in one dimension.
Also, I don't think that particles are described by equations of motion in QM. In QM we describe particles in Hilbert space, in classical mechanics we use phase space which describe the equations of motion of a particle.
Basically any particles follows QM, but when n is large, by Correspondence Principle, classical mechanics must be a good approximation of QM
One more question. By solving Sroedinger eq we get
##\varphi_n(x)=\sqrt{\frac{2}{a}}\sin \frac{n\pi x}{a}##
##E_n=\frac{n^2\pi^2\hbar^2}{2ma^2}##
But for example solution of Sroedinger eq is also
##C_1sin\frac {\pi x}{a}+C_2\sin\frac{2\pi x}{a}##
in which state is particle?
What is the energy level? How could I know in which state is particle?
The particle is in a superposition of the n=1 and n=2 states. When something happens that in effect measures the particle's energy, it will be either E1 or E2, chosen randomly according to probabilities that depend on C1 and C2.
Before the measurement happens, the answer to the question, "which of the two energy states is the particle really in?" depends on which interpretation of QM you subscribe to.
Well from
[tex]\int^{a}_0 (C_1\sin \frac {\pi x}{a}+C_2 \sin \frac{2\pi x}{a})^2=1[/tex]
I get
##C_1^2+C_2^2=\frac{2}{a}##
what next?
It's better to start out by normalizing each individual function:
$$\psi(x) = C_1 \psi_1(x) + C_2 \psi_2(x)\\
\psi(x) = C_1 \sqrt{\frac{2}{a}} \sin {\left(\frac{\pi x}{a}\right)}
+ C_2 \sqrt{\frac{2}{a}} \sin {\left(\frac{2 \pi x}{a}\right)}$$
Then when you normalize ##\psi## as a whole by doing an integral like yours, you end up with
$$C_1^2 + C_2^2 = 1$$
We interpret ##C_1^2## as the probability that the particle will be measured to have energy E1, and ##C_2^2## as the probability that the particle will be measured to have energy E2. The two probabilities add to 1 because they are the only two possibilities for this particle as far as energy is concerned.
Ok but from ##C_1^2+C_2^2=1## and some other physical behavior could I say something about ##C_1^2## and ##C_2^2##?
Obviously you need additional information about your specific situation in order to find C1 and C2. It's impossible to say more unless you have a specific situation in mind.
I understand that. But could you give me example of some specific situation.
