Value of Vout in PMOS Inverter?
The discussion focuses on deriving the output voltage (Vout) equation for a PMOS inverter. The participants clarify that while the equation for an NMOS inverter is Vdd - id*rd, the PMOS inverter's output can be expressed as Vout = id * Rd when considering the resistor's position. The resistor's placement at the bottom of the PMOS inverter alters the output behavior, leading to a simplified understanding that Vout can equal Vcc when the output is logic HIGH.
  • Understanding of PMOS and NMOS transistor operation
  • Familiarity with inverter circuit design
  • Knowledge of Ohm's Law and basic circuit analysis
  • Experience with voltage output calculations in digital circuits
  • Study the characteristics of PMOS transistors in digital logic
  • Learn about the impact of resistor placement in inverter circuits
  • Explore the derivation of output equations for different inverter configurations
  • Investigate the role of Rd in determining output voltage levels
Electrical engineers, circuit designers, and students studying digital electronics who are looking to deepen their understanding of inverter circuits and PMOS transistor behavior.
jean28
Hey guys. I am simply trying to derive the equation for Vout in a PMOS inverter (attached). I know that in an NMOS inverter (which has the resistor in top of the transistor instead of the bottom) the equation for Vout is:
Vdd - id*rd.
But how does the resistor being in the bottom change this behavior? Is it now Vcc - ground? (which would equal Vcc).
Thanks.
It could also be Vout = id * Rd.
If by Rd you mean that external resistor, then that looks right for output logic HIGH.
