When and where do the cars meet?
  • Thread starter Thread starter CollegeStudent
    Cars
The problem involves two cars approaching each other from different traffic lights that are 100 meters apart. Car 1 moves east at a constant speed of 25 m/s, while Car 2 starts from rest at light 2 and accelerates westward at 2.0 m/s². The discussion centers on determining when and where the two cars will meet.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss expressing the positions of both cars as functions of time. There are attempts to apply kinematic equations to find the time and location of their meeting. Some participants question the assumptions made regarding the starting points and the equations used.
Several participants have provided guidance on using appropriate kinematic equations. There is an ongoing exploration of the calculations involved, with some participants noting discrepancies in their results and discussing significant figures. The discussion is active, with various interpretations being examined.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is a focus on ensuring that assumptions about the initial conditions are clarified.
CollegeStudent
Two traffic lights are 100m apart. Light 1 being due west from light 2. Car 1 is moving east at a constant speed of 25m/s. When car 1 passes light 1, car 2 starts from rest, west at a constant acceleration of 2.0 m/s². Where do they pass and how long after the light changes do they pass?
I was thinking Vf² = Vi² + 2aΔx
Well I tried solving for the final velocity of car 2, since Vf of car 1 would be the same as initial.
Vf² = Vi² + 2aΔx
= 0² + 2(2.0m/s/s)(100)
Vf² = 400
Vf = 20
I'm not sure if this was the right approach but can someone point me in the right direction here?
I assume car 2 starts out from light 2?
See if you can express the position of each car as a function of time. (Hint: Measure the position of each from the same point.)
Yeah sorry it starts from light 2.
Well if the assumption I'm making based on your advice...I'd choose
Δx = 1/2(Vf + Vi)t for the formula.
So for time I believe it would be
t = (2Δx)/(Vf+Vi)
I decided to measure from 50m
so
Car 1 = 2(50)/50 = 2 seconds to reach 50m
and
assuming I calculated Vf correctly up in the original question (but subbing in 50 for 100)
Car 2 = 2(50)/14.14213562 = 7.071067814 seconds to reach 50m
So now do I just set these 2 equal to each other?
25 m/s = 7.071067814 m/s
divide both sides by 7.071067814 making the time it takes to pass 3.5 s?
That's OK, but realize that Vf also depends on time.
You'd be better off using:
[tex]x = x_0 + v_0 t + (1/2) a t^2[/tex]
That's what I had in mind when I spoke of position as a function of time.
Note: The calculation you made for Vf in your first post is not quite relevant. You found the speed of car 2 when it reaches light 1, not when it passes car 1.
Ahh, see I'm going off an equation sheet my prof gave us
Actually:
Δx = Vi*t + (1/2) a t^2...could this also be written as:
X - Xo = Vi*t + (1/2) a t^2
X = Vi*t + (1/2) a t^2 + X_o
Yeah, that makes sense...okay so let's see
Car 1 would be 25m/s * t
Car 2 would be (1/2)(-2.0m/s/s) t^2 + 100m
so
(-1m/s/s) t^2 + 100m
So NOW set them equal to each other?
(-1m/s/s) t^2 + 100m = 25m/s/s t
(-1m/s/s) t^2 - 25m/s/s t + 100m = 0
Ahh a quadratic...hmm well after the calculating I get -28.5 , 3.51
Obviously time can't be negative so I'm assuming 3.51 would be the time they intersect??
Actually:
so
Looks good. (I'll have to have a second look at what you did before, since you somehow got that same answer. )
Yeah I noticed that as well...however in terms of significant figures...
25 / 7.071067814 comes out to 3.535533905 with 3 sig figs = 3.54
and this other method came to 3.507810594 and here would be 3.51
So with the 3 sig figs it would make a difference...not much at all...but different
I did take a second look at your earlier work and I cannot understand your reasoning. Probably just a fluke that you got the "right" answer that way.
  • · Replies 22 ·
  • · Replies 126 ·
12K
