Shear stress and pressure drop
The discussion centers on the relationship between shear stress and pressure drop in fluids, exploring the physical mechanisms behind pressure changes in fluid flow, particularly in pipes. Participants examine concepts from fluid dynamics, including viscosity, shear stress, and the implications of ideal versus real fluids.
  • Some participants assert that fluids cannot support shear stress, citing the inability of shear waves to propagate through liquids as evidence.
  • Others argue that shear stress can exist in fluids, referencing Newton's law of viscosity and the relationship between shear stress, viscosity, and shear rate.
  • A participant explains that in pipe flow, viscous shear stress at the wall leads to a pressure drop, necessitating a higher pressure at the inlet than at the outlet.
  • Concerns are raised about the terminology of "pressure loss," with participants questioning why a necessary pressure differential for flow is termed a loss.
  • Some participants discuss the concept of an ideal fluid, noting that it is an approximation and questioning how such a fluid could flow without a pressure drop.
  • References to educational resources, such as "Transport Phenomena" and "Fundamentals of Fluid Mechanics," are made for further understanding of the concepts discussed.
Participants express disagreement regarding the nature of shear stress in fluids, with some asserting it cannot exist while others maintain it can. The discussion remains unresolved on several points, including the interpretation of pressure drop terminology and the behavior of ideal fluids.
Participants highlight the complexity of fluid dynamics, including the dependence on viscosity and the conditions under which pressure drops occur. There are unresolved questions about the molecular mechanisms behind viscosity and pressure changes.
tonyjk
hello all... Please can i know physically why the pressure drop in a fluid when there's shear stress? what happens? thank you
Greetings Tonyik
Firstly
you cannot have shear stress in a fluid ... That is, fluids cannot support shear stress
This is how we found out that the outer core of the Earth is liquid, because earthquake shear waves will not propagate through that region
knowing that, would you like to redefine your question and maybe give an example relating to your question
cheers
Dave
davenn said:
Greetings Tonyik
Firstly
cheers
Dave
Of course you can have shear stress in a fluid. According to Newton's law of viscosity, for a fluid that is being sheared between parallel plates, the shear stress is equal to the viscosity times the shear rate, with the shear rate equal to the relative velocity divided by the distance between the plates.
In a fluid flowing through a pipe, there is a viscous shear stress at the wall that acts in the direction opposite to the direction of fluid motion. This integrates to a tangential force at the wall. In order to overcome this force, you need a higher pressure at the inlet of the pipe than at the exit. For pipe flow, the pressure drop in the pipe is equal to 4L/D times the shear stress at the wall, where L is the length of the pipe and D is the diameter. The shear stress at the wall for laminar flow is equal to 8V/D times the viscosity, where V is the volumetric average velocity of the fluid.
If you want to learn more about this, see Transport Phenomena by Bird, Stewart, and Lightfoot.
Chet
Chet
my geophysics lecturer at university would have severely debated that with you
and would have give you the inverted jug of beer experiment to prove otherwise
if a fluid could support shearing then why do shear waves not travel through it ?
it just doesn't happen, Shear modulus of a fluid = 0
shear modulus
Shear Modulus (S) also known as the rigidity modulus
Gases and liquids can not have shear moduli. They have viscosity instead.
http://physics.info/elasticity/
Dave
shear modulus
http://physics.info/elasticity/Dave
Who said anything about gasses and liquids supporting shear strain? You do know the difference between stress and strain, correct? The OP was asking about shear stresses in a liquid, and how they contribute to pressure drop. Either your lecturer didn't know much about fluid mechanics, or you misinterpreted what he was saying. Viscosity is precisely what we are talking about here. This is the fluid property that allows a fluid to develop shear stress. I hope you really didn't think that shear stresses could only exist in solids. In a liquid, the shear stress is proportional to the rate of strain, rather than the strain itself.
Chet
Yea... viscous fluid shear is a pretty fundamental part of fluid dynamics and boundary layer theory.
hello again... yes I am talking of the shear stress due to the viscosity of the fluid..i don't know but if you google it you will get thousands of links about it .. and yes I am not an expert in fluid mechanics and still i didnt know why Physically there's drop of pressure i know its to overcome the energy loss due to friction ect quotation from the book Fundamentals of Fluid Mechanics by Bruce Munson :
"The need for the pressure drop can be viewed from two different standpoints. In terms of a force balance, the pressure force is needed to overcome the viscous forces generated. In terms of an energy balance, the work done by the pressure force is needed to overcome the viscous dis- sipation of energy throughout the fluid"
i mean why the viscous forces causes pressure drop in a molecular view that's what i mean by physically... thanks again
Chet
thanks a lot i think i will like it
ahh okk i think i understand it if we want to make a flow in a pipe we have to make a pressure difference ( drop of pressure between the entrance and the exit) so when fluid is flowing there's the viscosity of the fluid causing the viscous forces... but why we say an ideal fluid doesn't have viscosity so it has no pressure drop in a pipe? so how an ideal fluid can flow without pressure drop?
There's no such thing as an ideal fluid. It is only an approximation to the behavior of a real fluid in the limit of vanishingly small viscosity. As you make the viscosity of a real fluid lower and lower, the pressure drop in the pipe gets lower and lower. Thus, for the same axial velocity, water will have a lower pressure drop than molasses.
As to the question of what is happening on the molecular scale that gives rise to viscosity, see Transport Phenomena.
Chet
sorry for re-openning this thread but really I am not getting it look what i found:
But in fluid flow, DP is used to designate pressure drop, and thus it is P1 - P2
. A pressure drop due to viscous
effects represents an irreversible pressure loss, and it is called pressure loss
DPL to emphasize that it is a loss (just like the head loss hL
Note from Eq. 8–20 that the pressure drop is proportional to the viscosity
u of the fluid, and DP would be zero if there were no friction. Therefore,
the drop of pressure from P1 to P2 in this case is due entirely to viscous
effects
Im confused about why they call it a pressure loss? if it's necessary for a pressure drop in a fluid to flow in a pipe than why they called it pessure loss? and why they say if there's no friction there's no pressure drop? so how can an ideal fluid even in theory flow without a pressure drop... thanks again
http://www.uio.no/studier/emner/matnat/math/MEK4450/h11/undervisningsmateriale/modul-5/Pipeflow_intro.pdf even all the books they say its a pressure loss..
It is necessary for a pressure differential (i.e. the pressure at the inlet of the pipe is greater than the pressure at the outlet) for a fluid to flow in a pipe, not a pressure loss. Though all real fluids will have viscosity, and therefore some degree of shear, which results in pressure losses.
Some people call pressure drop "pressure loss" because, if the pressure at the inlet is higher than the pressure at the outlet, there is a "pressure loss." When they talk about "friction", what they really mean, more precisely, is viscous resistance.
When you ask the question "how can an ideal fluid even in theory flow without a pressure drop," this is analogous to asking "how can electric current pass through a zero resistance wire without a voltage difference across it." Even the smallest voltage difference across the wire will result in a huge current. For a finite current, the voltage difference would approach zero. Even the smallest pressure drop across the pipe will result in a huge flow. For a finite fluid flow, the pressure drop would approach zero. We are talking about the limit as the resistance approaches zero or as the fluid viscosity becomes vanishingly small.
  • · Replies 31 ·
