Could Anything Survive in the Habitable Zone Without a Host Star?
  • Context: Undergrad
  • Thread starter Thread starter Yosty22
The discussion revolves around the concept of the habitable zone (HZ) and whether life could exist in this zone without a host star. Participants explore the conditions necessary for maintaining liquid water and the factors that define the habitable zone for different stars.
  • Some participants propose that a greenhouse effect could allow a planet far from its host star to maintain temperatures suitable for liquid water, suggesting that other heat sources could enable life in the habitable zone.
  • Others argue that the habitable zone is defined by the energy output of the host star and that liquid water could exist outside this zone under certain conditions, such as on moons like Europa.
  • A participant inquires about the specific factors that define the habitable zone and whether energy output is the sole consideration in its calculation.
  • Another participant explains that astronomers use various metrics, including apparent magnitude and luminosity, to calculate the habitable zones for stars, providing examples of distances for stars with different luminosities.
  • One participant shares links to articles that detail the calculations involved in determining habitable zones, noting the complexity of the methodologies used.
  • Another participant expresses appreciation for an article that discusses the impact of planetary mass and atmosphere on the greenhouse effect and its influence on the habitable zone limits.
Participants do not reach a consensus; multiple competing views remain regarding the definition and implications of the habitable zone, as well as the potential for life without a host star.
Limitations include the dependence on specific definitions of the habitable zone and the assumptions made regarding energy sources and planetary conditions.
Yosty22
I understand the concept of the habitable zone or ''Goldilocks Zone," but can't anything technically be in the habitable zone? Even if the planet in question is far away from its host star, couldn't a greenhouse effect create an atmosphere and/or warm enough temperatures (but not too warm) to contain liquid water? Would this mean that anything could be in the habitable zone as long as it has another way to generate heat of its own if it is too far to gain sufficient heat from its host star?
Space news on Phys.org
The goldilocks zone is dependent on the output of its star, it only describes a region where liquid water is possible and temperature is suitable. Their are other ways to have liquid water outside or inside the goldilocks zone that could support life or for that matter other life supporting elements such as ammonia etc. One example is the possibility of Europia supporting life in its underground oceans. That moon lies outside the habitable zone.
Oh, thank you. With that in mind, what defines the habitable zone? Is there a way to calculate how large the habitable zone is for a certain star? Is energy output the only factor in calculating the habitable zone of a star?
Astronomers use apparent magnitude, luminosity and stellar flux along with the inverse square law to calculate habitable zones for stars. The "center" of the HZ is defined as the distance that an exoplanet would have to be from its parent star in order to receive the right amount of energy from the star to maintain liquid water. For example, a star with 25% of the luminosity of the Sun will have a CHZ centered at about 0.50 AU, while a star with twice the Sun's luminosity will have a CHZ centered at about 1.4 AU.
here is a couple of articles that covers some of the calculations involved
http://www.daviddarling.info/encyclopedia/H/habzone.html
http://www.astro.umd.edu/~miller/teaching/astr380f09/lecture14.pdf
http://www.planetarybiology.com/calculating_habitable_zone.htm
http://arxiv.org/pdf/1301.6674v2.pdf
the last paper is fairly intense but it shows more modern methodology. The graphs are also handy.
Mordy, that article http://arxiv.org/pdf/1301.6674v2.pdf is interesting! Thanks for calling our attention to it. I'm going to add it to the informal A&C bibliography in the Astro forum. It's a handy place to keep links of stuff one might want to refer to, if you think they might be of general interest and helpful to other members.
The thing I like is that it considers various cases of the mass of the planet and its atmosphere, so the various ways the greenhouse effect changes the inner and outer limits of the Zone are presented in a detailed informative way.
No problem I often save gems such as that article, saving it on the site would be a good idea.
I've seen a lot of various short hand ways to use my callsign but that's the first time I've seen Mordy used lol
  • · Replies 19 ·
  • · Replies 37 ·
15K
  • · Replies 42 ·
  • · Replies 26 ·
