Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Classical Physics (http://www.physicsforums.com/forumdisplay.php?f=61)
-   -   Fluid velocity vs pressure in taper. (http://www.physicsforums.com/showthread.php?t=671675)
THORPE Feb13-13 09:07 PM
I have been running this question through my mind.
If you apply pressure to a fluid (with say a piston) through a straight hole then the faster you push it through with applied pressure then the more back pressure it builds. Until eventually it pretty much locks up.
I understand that.
Ok if you push fluid through a tapered hole then the fluid velocity should increase and pressure should decrease.
My question is will the resistance to applied pressure stay consistent, decrease, or increase with increased applied speed of the piston?
THORPE Feb15-13 01:18 PM
Re: Fluid velocity vs pressure in taper.
Any ideas?
Does my question make sense?
THORPE Feb27-13 09:01 PM
I'm surprised I haven't seen the first response to this question.
I am going to assume that the flow will be at least linear with progressive speed.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
