Not Satisfied with Linear Algebra Theorem
The discussion revolves around the theorem stating that a linear transformation T: R^n -> R^m is one-to-one if and only if the equation T(x) = 0 has only the trivial solution. Participants express confusion regarding the proof of this theorem and the implications of the trivial solution.
  • One participant questions the proof's logic, specifically how it establishes the theorem's validity and what is meant by the "two conditions."
  • Another participant explains that if T is one-to-one, then T(U-V) must not equal zero for U not equal to V, implying that non-trivial solutions to T(x) = 0 would indicate T is not one-to-one.
  • Concerns are raised about whether the zero vector being the only solution to T(x) = 0 is sufficient to conclude that T is one-to-one everywhere.
  • Some participants clarify that if T is injective, then the only vector that maps to zero must be the zero vector, reinforcing the theorem's assertion.
  • A later reply acknowledges a shift in understanding, indicating that the trivial solution must indeed be the only solution for the zero vector, allowing for better comprehension of the theorem.
Participants express varying levels of understanding and agreement regarding the proof of the theorem. While some clarify and refine their understanding, there remains uncertainty about the implications of the trivial solution and the proof's completeness.
Participants discuss the assumptions underlying the theorem and the conditions necessary for injectivity, highlighting the need for careful consideration of definitions and implications in linear transformations.
Vorde
Hello,
I am just not satisfied with the following theorem (I don't know it's name):
Let T:R^n -> R^m be a linear transformation. Then T is one-to-one if and only if the equation T(x) = 0 has only the trivial solution.
The "proof" involves saying that if T is not one-to-one, then there are two different vectors U and V such that T(U)=T(V)= some vector B. And since T is linear it follows that T(U-V) = T(U)-T(V) = B - B = 0. It then concludes by saying "hence there are nontrivial solutions to T(X)= 0. So, either the two conditions in the theorem are both true or they are both false."
I just don't see how that proved the theorem in any way, perhaps because I don't fully understand which two conditions it is talking about.
Could anyone help me here? Thank you.
Hey Vorde.
A 1-1 would imply that T(U-V) = T(U) - T(V) != 0 for U != V. If however this were false then it would imply that for some U != V that T(U) = T(V) proving that the mapping is not 1-1.
But then you have to take into account the trivial solution (i.e. the zero vector) as a special case where T(U) = 0 for U = 0.
The formal proof for 1-1-ness is to show that for U != V then T(U) != T(V) for all U and V in the domain of the mapping.
Hey Chiro,
Right, so I understand that part. What I don't understand is how it is enough to show that there aren't any non-zero vectors that map to the zero-vector to know that the mapping is one-to-one everywhere.
Why couldn't the zero vector be the only vector that maps to the zero vector but still have non 1-1-ness elsewhere?
We know that the zero vector always maps to the zero vector, but we also know that if everything is 1-1, then it means that only the zero vector maps to the zero vector and everything else maps to some other vector (that isn't the zero vector).
Take two vectors, u and v.
Suppose T(u) = T(v).
Then T(u) - T(v) = 0.
But be linearity, T(u) - T(v) = T(u-v).
Then only vector that maps to 0 is the zero vector.
Hence, u - v = 0, so u = v, proving T was 1-to-1.
Okay, but that only works if you posit that the transformation is 1-1, and the theorem doesn't start with the assumption that the transformation is 1-1. I understand that the zero vector will always map to itself, just not why that says anything about the rest of the transformation.
Ah, wait, I think I might see it now.
Let [itex]T[/itex] be injective (sorry I absolutely hate the term 1 - 1 god knows why it is even used). Because T is linear, [itex]T(0) = 0[/itex]. This immediately implies this is the only vector for which this is true because if [itex]\exists v\in V :T(v) = 0[/itex], then the injectivity of [itex]T[/itex] implies that [itex]v = 0[/itex]. Now let [itex]T(v) = 0[/itex] be true only for the zero element then if [itex]T(v) = T(w)[/itex] we have that [itex]T(v - w) = 0\Rightarrow v = w[/itex] thus [itex]T[/itex] is injective. This is essentially what the proof you quoted is saying but the quoted proof is more concise.
EDIT: Seems like people responded while I was typing this up but I guess I'll leave it here anyways =D.
Okay, thank you to all who have been helping.
What was really bothering me was that I didn't see why the trivial solution had to be the only solution for the zero vector. But I just went back and thought about it and now I can see that this must be the case.
That assumed, I can follow the rest of the theorem.
Once again, thank you all.
T is one to one if
whenever
T(u)=T(v)
we must have
u=v
now suppose
T(x)=0
only when
x=0
If
T(u)=T(v)
by linearity
T(u-v)=0
then we must have
u-v=0
so
u=v
  • · Replies 23 ·
