What Is the Last Address in a 2K Memory System?
  • Thread starter Thread starter jaydnul
    Computer Memory
The discussion revolves around determining the first and last address in a 2K memory system, specifically addressing the confusion surrounding the total number of addresses and the implications of using binary versus decimal interpretations of memory size.
  • Some participants suggest that the first address is 0, but there is uncertainty about the last address, with one participant initially stating it as 1999.
  • Another participant proposes that the last address could be 2047, based on the understanding that 2K equals 2048 bytes.
  • One participant notes that in computing, "K" typically refers to 1024, prompting further inquiry into the implications of this definition.
  • A later reply discusses the organization of memory in terms of bits and bytes, explaining that the last address depends on the word size used (8, 16, 32, or 64 bits).
  • There is mention of the confusion surrounding the terms gigabyte and gibibyte, highlighting the differences between binary and decimal interpretations of memory capacity.
  • One participant reflects on the verbosity of their explanation, indicating a broader context of marketing and technical terminology in computing.
Participants express differing views on the correct last address in a 2K memory system, with no consensus reached on the final answer. The discussion includes multiple interpretations of memory size and terminology, indicating ongoing uncertainty.
The discussion highlights the dependence on definitions of memory size and the organization of data in memory, which may lead to different interpretations of the last address. There are also unresolved aspects regarding the implications of using binary versus decimal measurements in computing.
jaydnul
What would the first and last address be? I said 0 and 1999 but the answer was 0 and some other number which i don't remember (it wasnt 1999 haha) What is the correct number for the last address and why isn't it 1999 since there are 2000 bytes in a 2k ram?
In computers "K" mean 1024. Why do you think that might be?
Ahh so 2047? Does that mean a gig is 1,024,000,000 bytes?
Nevermind, I realized my error after i hit post
Get one of those cheap TI calculators that has BIN, OCT and HEX buttons.
You'll quickly become fluent.
AGAIN, I ask ... why do you think that might be?
lundyjb,
In general when discussing RAM, EEPROM and FLASH memories the capacity is given in 2^X format. Therefore 2K represents 2^11 = 2048 Bytes. Assuming the starting address is 0x00, and the memory is organized as 8 bit words, the last address would be 0x7FF (2047d). Directly addressing this space would require an address width of 11 bits if it were organized as 8 bit words, 10 bits if it were organized as 16 bit words, 9 bits if it were organized as 32 bit words and 8 bits if it were organized as 64 bit words.
When working with digital electronics it is generally beneficial to work in powers of 2 (and Hexadecimal notation greatly facilitates this); this gives you the clearest indication of what is actually happening.
The confusion and dis-ambiguous nomenclature surrounding GB, Gigabyte, gibibyte, Gb and other similar terms is discussed @: http://en.wikipedia.org/wiki/Gigabyte. In general gigabyte refers to 2^30 bytes when referencing pc memory (1,073,741,824 bytes) which is similar in value to the SI prefix "giga" which = 10^9 = 1,000,000,000.
One of the great travesties of marketing is that hard drives typically base capacity on SI units (ie, a 400GB HD = 400,000,000,000 bytes; however, Windows Operating systems report the hard drive capacity (and file sizes) in binary notation. As an example a "400GB" hard drive would likely be reported by windows to be a 372GB drive.
The final nebulous marketing scheme I will mention concerns data transmission rates. In almost every case from the early RS232 specifications to the bleeding edge SATA specifications, the transfer rate is defined as the number of bits per second. It might appear this means that the bytes per second is simply the bits per second divided by 8, but this, of course, is never possible in a serial transmission. At the very least a serial packet must have a "start condition" and a "stop condition". In many cases the packet length is a single 8 bit byte, so we have at the minimum, 1 start bit, 8 data bits and a stop bit. In noisy environments the addition of a parity bit is common, increasing the number of bits per byte to 11. There are lots communications standards and protocols, the common theme is that they all sound faster than they really are, lol.
LMAO, that was prolly a lot more than the OP was asking for, sorry for the verbosity.
Fish
  • · Replies 17 ·
  • · Replies 32 ·
