When tissue gets wet,it becomes weak
  • Thread starter Thread starter asdff529
    Weak
The discussion centers around the mechanical properties of tissue paper when wet compared to when it is dry. Participants explore the reasons behind the observed phenomenon of tissue paper becoming easier to tear when wet, touching on concepts related to material composition and molecular interactions.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant notes that wet tissue paper can be separated into smaller portions more easily than dry tissue, questioning the underlying reason.
  • Another participant suggests that the process involves dilution, with water aiding in breaking down organic and inorganic compounds within the tissue.
  • A different viewpoint describes tissue paper as composed of fibers bound by a glue-like substance, which water partially dissolves, making it easier to rip.
  • One participant elaborates that tissue paper is primarily made of cellulose, where water disrupts hydrogen bonds between cellulose molecules, allowing them to separate more easily. They also compare this to the strength of dry versus wet wood, indicating a similar principle at play.
Participants present multiple perspectives on the mechanisms involved, but there is no consensus on a single explanation for why wet tissue is weaker than dry tissue.
Participants mention various aspects of the tissue's composition and the effects of water, but the discussion does not resolve the complexities of the interactions involved or the specific conditions under which these observations hold true.
asdff529
That is if a tissue paper is wet,it is easier for us to "separate" into many small portions than in dry condition does.
Why?
Sorry for my poor english,i don't know how to express it well, but i hope it is understandable.
Chemistry news on Phys.org
it is dilution process per say! water helping breaking organic/inorganic compounds.
Tissue paper is a bunch of fibers held together by a glue like substance.
Water dissolves this glue somewhat. So it rips easier
Paper is mostly cellulose. Cellulose molecules are held together by hydrogen bonding. When you add water, some of these bonds are broken, as cellulose starts bonding with water instead of the other cellulose molecules. That means wet molecules of cellulose are easier to separate. It is not only a matter of paper or tissues, dry wood is stronger than the wet one for the same reason.
  • · Replies 23 ·
  • · Replies 89 ·
10K
10K
