Can I Find a Series of Numbers That Add Up to kn?
  • Context: Undergrad
  • Thread starter Thread starter Nickclark
    Set Summation
The discussion revolves around finding a series of numbers that add up to a multiple of a specified last number, n, with the goal of solving a larger problem. Participants explore the conditions under which such a series can be constructed, including the nature of the numbers involved and the constraints on the parameters.
  • Homework-related
  • One participant seeks a series of numbers that sum to kn, with the last number fixed as n.
  • Another participant suggests that if k can be any integer, then a possible solution could be to set all terms equal to k, but this does not satisfy the condition of the last term being n.
  • Further clarification is requested regarding restrictions on the set of numbers and the nature of k (e.g., whether it must be an integer, rational, or real).
  • One participant proposes that the sum of the series should be of order 1, contrasting it with the sum of the first n integers, which is of second order.
  • A participant provides an example of a geometric series as a potential solution, indicating that it leads to a linear sum, which aligns with the goal of minimizing computational complexity.
  • There is a call for more precise definitions and constraints to facilitate better assistance in solving the problem.
Participants express uncertainty regarding the specifics of the problem, particularly about the nature of k and the restrictions on the series. Multiple competing views remain on how to approach the problem and what conditions must be met.
Participants note the need for clearer definitions regarding the parameters of the problem, including the types of numbers allowed in the series and the specific requirements for k. There is also ambiguity about the number of terms in the sum and the implications of the phrase "sum is of order 1."
This discussion may be useful for individuals interested in combinatorial mathematics, algorithm design, or those facing similar problems in mathematical reasoning or series summation.
Nickclark
i need to find a series of numbers up to n that will add up to kn
x1 + x2 + x3+ ... + n = kn
where k is a constant.
this is part of a long complex problem once this sum is found it will finally be solved.
Mathematics news on Phys.org
Do you mean ##x_1+x_2+x_3+\cdots +x_{n-1}+x_n = nk##?
How about ##x_1=x_2=\cdots =x_{n-1}=x_n = k##?
no, i need the last number to be n.
some how i need to find a set of numbers when added together all i get is a multiple of the last number.
Do you have any restrictions on that set of numbers or the parameters? e.g., how many terms can you have in the sum? Is k any real number, or is it limited to certain values or sets (like the integers or rationals, etc)?
From what you've said, k can be any integer, and there can be any number of terms in the sum ... so you appear to be saying you want to find any set of numbers ##\{x_i\}## so that $$n+\sum_{i=1}^m x_i = kn$$ (the last number is n as specified) .. which suggests that $$(k-1)n=\sum_{i=1}^m x_i$$ and again I can say that ##x_1 = x_2 = \cdots =x_{m-1}=x_m = \frac{n}{m}(k-1)##
... which means that you have to be more specific about your problem if you are to get sensible answers. I'm guessing the x's can't be just any old numbers for example, and k is not supposed to be a specific integer? But I'm guessing - don't make people guess.
yeah, i should've added more restrictions.
well the numbers must increase as we go on, for example:
1+2+3+...+n=n(n+1)/2 right, but this is of second order
i want to add numbers that increase up to n, and their sum is of order 1.
You still need to be a bit more specific. You still haven't told us if k has to be an integer or rational or real or positive or negative, etc. It's also not clear how many terms you have in your sum - it looks like it's n terms where the last term is also equal to n, but you haven't told us that explicitly - we're still just guessing. Please tell us precisely what you want.
If this is a problem that has been supplied to you, then please provide the exact text of the problem and the context.
I'll add that we don't know that the numbers have to be integers of if they can be real, and so on. eg.
##\sum_{i=1}^n = n(n+1)/2 = kn \text{ if } k=(n+1)/2##
But what do you mean "the sum is of order 1"?
You mean that kn cannot be quadratic in n? (k cannot depend on n?)
Maybe you are thinking more like:
x1=1, x2=2, x3=3=n, then 1+2+3=6=2n so k=2
that the idea?
Well the problem is not about this sum, if you find a series like the one described the problem will be solved.
i have submitted the following answer:
2+4+8+16+32+64+...+2^k = 2(1+2+4+8+...+2^(k-1) = 2(2^k -1)/2-1 = 2(2^k -1)
but 2^k = n
k = log (base 2) n right, then substitute in the sum:
2(n-1) which is linear that is (of order one).
the idea of the problem is that i want to get to n with the least sum possible, if i went with the quadratic equation that would have taken too much time O(n^2), so this sum will save so much time O(n)
it's an algorithm problem.
So to get good help you will need to describe the problem properly.
  • · Replies 29 ·
13K
