Air Consumption Rate of Cylinder Actuators on SKG200 Valves
  • Context: Undergrad
  • Thread starter Thread starter WillemBouwer
    Air Rate
The discussion revolves around calculating the air consumption rate of cylinder actuators used with SKG200 valves. Participants are exploring the implications of air consumption for selecting an appropriate compressor and sizing an air receiver, with a focus on the technical calculations involved.
  • One participant presents calculations for the air consumption rates during the opening and closing strokes of the actuator, providing specific values based on given parameters.
  • Another participant seeks clarification on whether the total air consumption is cumulative for both strokes or if it only applies to one stroke, proposing two interpretations of the air usage.
  • A participant confirms the understanding that the actuator is double acting and acknowledges the same duration for both strokes, leading to a calculation of maximum consumption in liters per minute.
  • Concerns are raised about the need for an air receiver instead of a spring for fail-safe purposes, with a participant attempting to apply Boyle's law to determine the appropriate sizing of the receiver.
  • One participant expresses uncertainty about the application of Boyle's law and the correct values to use for the calculations.
Participants generally agree on the need to calculate air consumption for both strokes of the actuator, but there is uncertainty regarding the application of Boyle's law for sizing the air receiver and the specific values to use in the calculations.
There are limitations in the discussion regarding the assumptions made in the calculations, particularly concerning the use of Boyle's law and the definitions of variables involved in the air receiver sizing.
WillemBouwer
Hi all
I am trying to set up a report showing the air consumption rate of my cylinder actuators on different valves. I am stuck at the very end where I should calculate the air consumption rate. All calcs are in metric units.
Okay as an example let's use the following:
Valve: SKG200 with closing thrust 1259kg at 10bar line pressure.
Actuator size: D = 250 mm
Valve stroke: S = 296 mm
Cylinder rod diameter: d = 32 mm
Available air pressure: P2_gauge = 4 bar
Now I calculated the total cylinder volume for the closing and opening strokes:
V_open = ((D-d)/10)^2*∏/4*S = 8584.8 cm^3
V_close = (D/10)^2*∏/4*S = 11290.1 cm^3
So the total air consumption respectively:
Air_open = V_open*(P2_guage+1)/1000 = 42.92 liter
Air_closed = V_close*(P2_guage+1)/1000 = 56.5 liter
And with a maximum operating speed of 25mm/s we calculate that the duration of the stroke is:
t = S/25 = 296/25 = 11.84 sec
So now that I have all this info, how do I calculate the rate of air consumption if I want to know what size compressor to buy... Thanks guys and I hope this is in the correct forum...
Are you saying:
a) it uses 43L to move the piston one way and another 57L to move it back the other way? eg a total of 100L per cycle?
or
b) The cylinder volume changes from 43 to 57 L in one stroke and no air is used for the return stroke? (eg the load or a spring does the return).
Is the duration of the stroke the same in both directions? eg The cycle time is 2 * 11.84 = 23.68 seconds?Assuming you mean a) then..
The max consumption is going to be around...
100L every 23.68 seconds
or
(100/23.68) * 60 = 253 L/min
CWatters: Yes as stated in A it is a double acting actuator... Let's say that the duration of the strokes is the same so yes thanks, now you made that seem pretty obvious, haha...
Thanks
Now the other thing I started to have trouble with, say I do not want to place a spring for fail safe purposes (load is to big), I am recommending an air receiver.
I however have to size the receiver accordingly. Let's say for only the closing stroke.
I know I have to use Boyle's law: pV = k or p1V1 = p2V2
I've tried a view solutions by now. I don't know what to use as V1 and V2? Do I use the 57 liters as V1 and say V2 = Vreceiver + V1? One of the engineers said that rule of thumb says multiply it by 4 so that gives 228L! But surely I can get to the answer using Boyle's law.
Thanks for the help
I'm afraid that's outside my level of experience.
  • · Replies 30 ·
19K
  • · Replies 45 ·
