What is the best approach for layer-by-layer deposition of aluminium oxide?
  • Thread starter Thread starter idmena
    Deposition
The discussion focuses on the layer-by-layer (LBL) deposition process, specifically for aluminium oxide. Key techniques mentioned include Molecular Beam Epitaxy (MBE) and Pulsed Laser Deposition (PLD), with Atomic Layer Deposition (ALD) noted for its ability to produce high-quality films, although not strictly LBL. The substrate requirements for LBL processes include conductivity and porosity, which are critical for successful deposition. The conversation emphasizes the need for proper preparation of the liquid anion/cation for effective metal deposition.
  • Understanding of layer-by-layer deposition techniques
  • Familiarity with Molecular Beam Epitaxy (MBE)
  • Knowledge of Pulsed Laser Deposition (PLD) and its applications
  • Basic principles of Atomic Layer Deposition (ALD)
  • Research the substrate requirements for layer-by-layer deposition of aluminium oxide
  • Explore detailed guides on preparing anion/cation solutions for deposition
  • Investigate the differences between MBE, PLD, and ALD techniques
  • Look into the properties of amorphous films produced by various deposition methods
Materials scientists, chemical engineers, and researchers involved in thin film deposition techniques, particularly those focusing on aluminium oxide applications.
idmena
Hi
I was hoping you could help me a little bit regarding the layer-by-layer deposition process. I have not been able to find a book in my campus library that talks about this particular process, nor have found any "how to" online (must likely haven't searched in the right places), so I come to you with some doubts.
The things I would like to learn are:
What conditions should the substrate meet to be elegible for LBL? (e.g. must it be conductor? must it be porous (how much)?
What or how is the process of preparing a metal for deposition with this techniche? In other words: How do I prepare the liquid anion/cation?
In my case, I am only interested in depositing one type of metal (aluminium oxide), so what should/can the other layer be?
I expect only to be pointed in the right direction, if you could share a tutorial/text/book/article that can tell me about this I would really apreaciate it. Of course that if you can also provide a direct answer to any of my questions it would be great.
I am also aware of other deposition techniques, and I'm already doing the proper research on them.
Thanks in advance
Layer-by-layer deposition isn't a method as such. There are several techniques that can be used, and the choice of technique depends on the materials you are usings.
The most "obvious" technique for layer-by-layer deposition is MBE, this is e.g. used for III-V semiconductors. However, you can also do layer by layer using other methods, for example pulsed laser deposition (used with in-situ RHEED) is often used for complex oxides.
I am not sure there is a technique that can be used for aluminium oxide, most films tend to be amourphous, ALD (atomic layer deposition) can be used to deposit good quality films, but I don't think it can be used for true layer-by-layer deposition.
  • · Replies 16 ·
