System of cross-polynomials of variable degree
The discussion focuses on solving a system of three simultaneous equations involving variables x, y, and z, defined by the equations (y+z) / ((x+y+z)²)=ax^{α-1}, (x+z) / ((x+y+z)²)=by^{α-1}, and (x+y) / ((x+y+z)²)=cz^{α-1}. The parameters a, b, and c are positive real numbers, while α is constrained within the interval (0,1). The key conclusion is that while a unique solution exists due to the monotonic nature of the equations, the challenge lies in determining the conditions under which a closed-form solution is achievable, particularly through variable substitution with n=x+y+z.
  • Understanding of simultaneous equations and their properties
  • Familiarity with real analysis, particularly in the context of monotonic functions
  • Knowledge of polynomial equations and variable substitution techniques
  • Basic grasp of mathematical parameters and their implications in equations
  • Research techniques for solving nonlinear simultaneous equations
  • Explore variable substitution methods in polynomial systems
  • Study the implications of parameter constraints in mathematical modeling
  • Investigate closed-form solutions in the context of real analysis
Mathematicians, researchers in applied mathematics, and students studying systems of equations and real analysis will benefit from this discussion.
ydydry
Dear all,
I am stuck with an apparently easy system of 3 simultaneous equations that has to be solved in x,y and z. The system is the following:
##(y+z) / ((x+y+z)²)=ax^{α-1}##
##(x+z) / ((x+y+z)²)=by^{α-1}##
##(x+y) / ((x+y+z)²)=cz^{α-1}##
The parameters (a,b,c) and the variables (x,y,z) are all in ℝ₊. The parameter α is in the open interval (0,1), so that the problem is not trivial. The question is for which α there exists a closed-form solution, and for which α there exists none, given a general vector (a,b,c).
Proving that there always exist a unique solution is trivial as in each equation the right-hand sides are always increasing, whereas the left-hand sides are always decreasing in the corresponding variable (x for the first, y for the second, z for the third).
Hence, my problem is in the existence of a closed-form solution.
Many thanks!
It looks as if we first should substitute the variables ##x,y,z## by ##\frac{x}{n},\frac{y}{n},\frac{z}{n}## with ##n=x+y+z## which makes the left hand side linear and ##n## should be constant or at least can be put into the parameters on the right hand side. I suppose that the equations are then easier to solve.
  • · Replies 0 ·
  • · Replies 25 ·
