Flamethrowers: Why Do They Need Compressed Gas?
  • Context: High School
  • Thread starter Thread starter Thunderclap
Flamethrowers utilize compressed flammable gas to propel fuel towards the ignition source, typically spark plugs, creating a controllable flame. The compressed gas ensures a consistent flow of fuel, enhancing ignition reliability compared to non-compressed systems, such as traditional gas stoves. This mechanism allows for a fuel-rich mixture that ignites easily, while also projecting the flame safely away from the operator.
  • Understanding of combustion principles
  • Knowledge of gas propulsion systems
  • Familiarity with spark ignition mechanisms
  • Basic physics of pressure and gas flow
  • Research the design and function of flamethrower fuel tanks
  • Explore the chemistry of flammable gases used in ignition
  • Study safety protocols for handling compressed gases
  • Investigate advancements in ignition technology for gas appliances
Engineers, safety professionals, and enthusiasts interested in the mechanics of flamethrowers and gas ignition systems.
Thunderclap
Many flamethrowers use compressed flammable gas, which flows from the special tank to the end of the gun, where it is ignited by spark plugs. This creates a small flame, which ignites the flowing fuel.
But why a flamethrower needs a tank with compressed gas? Can the fuel be ignited just only by spark plugs?
Have you tried lighting a kitchen gas stove ring? I know modern stoves have automatic electric ignition, but the older ones require that you use a match or a gas igniter. The gas igniter is like a butane cigarette lighter but with a long barrel. When the butane runs out you can still light the stove, but it is unreliable and you often have to make many clicks (sparks) before ignition. When you recharge the butane, ignition is usually on the first try.
I'd say the butane provides a fuel-rich mixture so it ignites easily; the gas stove is set to provide no excess of gas for maximum heat and smoke-free operation.
The compressed gas also projects the flame so that the operator does not roast himself.
  • · Replies 20 ·
