Set 4.5x - 9(1-x) to Equal -1 with TI 83 Calculator
  • Context: High School
  • Thread starter Thread starter Kombaiyashii
    Set
The discussion revolves around how to set the expression 4.5(x) - 9(1-x) equal to -1 using a TI 83 calculator. Participants explore the algebraic manipulation required to achieve this goal, while also addressing the use of calculators in learning mathematics.
  • One participant asks how to set the expression 4.5(x) - 9(1-x) equal to -1, indicating it is for personal use rather than homework.
  • Another participant suggests rewriting the equation as 4.5(x) - 9(1-x) + 1 = 0, implying a method to approach the problem.
  • A different participant clarifies that to set the expression to -1 means to write it as 4.5x - 9(1-x) = -1 and provides steps for solving for x, emphasizing algebraic manipulation.
  • Some participants express a viewpoint that using a calculator for basic math operations detracts from learning, suggesting that one should rely on manual calculations instead.
There is no consensus on the best approach to solving the problem, as participants present differing views on the use of calculators and the method of setting the equation. Some advocate for manual calculations while others focus on the algebraic setup.
Participants do not fully agree on whether using a calculator is beneficial for learning math, and there are varying opinions on the necessity of manual calculations versus calculator use.
Kombaiyashii
Hi.
I would like to make the answer equal -1
here's the formula:
4.5(x) - 9(1-x)
How do I set this to equal -1? (This isn't homework, I'm working out some poker math and am not very good at this type of thing.) I use a TI 83 calculator.
Mathematics news on Phys.org
It's the same as 4.5(x) - 9(1-x)+1 = 0
Take a hint from me:
If you want to learn math, set your calculator aside.
To "set" something to -1 means to write "= -1" at the end! So to "set" 4.5x- 9(1- x) to -1 is just to write 4.5x- 9(1- x)= -1. If you mean "find the value of x that makes this true", use the usual "rules" of algebra. First multiply out those parentheses:
4.5x- 9+ 9x= -1
Add the terms in x, 13.5x- 9= -1. Now add 9 to both sides, then divide both sides by 13.5.
Using a calculator to do that is like using a calculator to add "1+ 1" (and I have seen people do that!).
+1 to that!
  • · Replies 22 ·
