Can Adding a Potentiometer Adjust LED Brightness?
  • Context: High School
  • Thread starter Thread starter StevenA
    Circuit
The discussion revolves around the feasibility of using a potentiometer to control the brightness of an LED in a circuit. Participants explore various methods, including the use of potentiometers and PWM (Pulse Width Modulation) circuits, while addressing the implications of each approach.
  • One participant inquires whether a potentiometer can be used to control LED brightness.
  • Another participant explains that potentiometers function as variable resistors, affecting voltage and current, but warns about their wattage limitations and the need for a current limiting resistor to prevent LED damage.
  • A fixed series resistor of approximately 300 Ohms is suggested to ensure safe operation of the LED when using a potentiometer.
  • One participant asserts that effective LED brightness adjustment requires a PWM circuit, citing various available designs.
  • Another participant provides a link to a PWM LED dimmer circuit as a resource.
  • Concerns are raised about the level of expertise required to implement PWM versus using a variable resistor, with some suggesting that beginners may encounter difficulties with the latter method.
  • A participant humorously notes that using a variable resistor can lead to quickly damaging LEDs.
Participants express differing opinions on the effectiveness of using a potentiometer versus a PWM circuit for adjusting LED brightness. There is no consensus on the best approach, and the discussion remains unresolved regarding the practicality of each method.
Participants highlight the importance of current limiting resistors and the potential risks of using a potentiometer without proper precautions. The discussion also reflects varying levels of expertise among participants, which may influence their perspectives on the methods discussed.
StevenA
If I add a potentiometer to my circuit will I be able to control the brightness of the LED with the meter?
potentiometers are nothing more than variable resistors .so by adjusting it you either increase or decrease both the voltage/current as voltage is relative to current.and vice versa.
Now usually potentiometers are with low wattage so they cannot manage large currents or they will overheat and damage.In the case of a single or multiple led's that is not the problem as led draws few miliamps an average of 20mA I guess.
Yes if you have a let's say 9v battery you can put a potentiometer in series with the Led but be careful as led's have a current limiting resistor.It would be better to use the resistor in series with the pot and the battery.Without the resistor you could accidentally or on purpose turn it to very few ohms resistance and the current through the led would be too high and it would burn down your led (destroy it )
A fixed series resistor of about 300Ohms would ensure that the LED doesn't get overloaded. (The LED will take up about 1.5V of the supply volts and that leaves 7.5V from your 9V battery. 7.5V across 300Ohms will give you 25mA when your variable resistor is at zero - safe.
The only way you are going to effectively adjust a LED brightness is to use a PWM ( Pulse Width Modulation) circuit
There's numerous circuits available online using NE555 timers and a small handful of other components to do this :)
Dave
Using the search terms “adjust led brightness PWM 555” Google shows hundreds of opportunities for you to choose from. Here is only one:
http://www.circuitsgallery.com/2013/02/PWM-Led-Dimmer.html
It's all a matter of the level of expertise, surely. PWM could be beyond the experience of someone who has just done Ohm's law but trying to use a variable resistor will show them the shortcomings of the method.
yup, they will learn how quickly you can pop LED's ;)
D
  • · Replies 52 ·
  • · Replies 19 ·
  • · Replies 16 ·
