Concept of Rate: Understanding Division of Different Units
  • Context: High School
  • Thread starter Thread starter Square1
    Concept Rate
The discussion revolves around the concept of "rate," particularly in the context of quantities with different units, such as speed and acceleration. Participants explore the relationship between division and the expression of rates, as well as the conceptual understanding of these terms in practical scenarios.
  • One participant seeks clarification on how the expression for division arises from statements like 'a' meters per 'b' seconds, questioning the role of division in defining rates.
  • Another participant asserts that the slope, which represents speed, is a division of units (meters over time).
  • A third participant notes that "per" implies division, reinforcing the connection between rates and division.
  • A practical example is presented involving a ball rolling a certain distance over time, illustrating how to reason through the relationship between different properties without using fractions.
  • A participant expresses uncertainty about their understanding of the topic, indicating a moment of confusion regarding their own questions and the concept of rates.
Participants express varying levels of understanding regarding the concept of rates and the role of division. While some agree on the connection between "per" and division, others remain uncertain about the implications and reasoning behind these concepts, indicating that the discussion is not fully resolved.
There are indications of missing clarity on how division specifically relates to the concept of rates, as well as unresolved questions about the reasoning behind the use of units in this context.
Square1
The concept of a "rate"
Here's another question from good ol square :|
I was hoping to get some clarification about the concept of a rate of two quantities, with different units, like speed [itex]\frac{a-units}{b-units}[/itex]. How does the expression for division [itex]\frac{a-units}{b-units}[/itex] arise from the statement like 'a' meters per 'b' seconds?
If I were to plot meters vs. time for some object moving at constant speed, I can get the 'rate' of the curve by using the definition of slope like we were taught Δmeters/Δtime ie the speed.
I also understand that acceleration is the change in velocity, 'per' given desired time interval ie Δvelocity/Δtime.
In both cases, I don't think I have conceptual issue with why it makes sense to define these rates of change with respect to time, I just don't understand what division has to do with it - multiple subtractions of units of time, from the numerator?? :S Thanks.
Hi Square1! :smile:
Square1 said:
… I can get the 'rate' of the curve by using the definition of slope like we were taught Δmeters/Δtime ie the speed.
… I just don't understand what division has to do with it - multiple subtractions of units of time, from the numerator??
The slope is a division: units up over units across.
(and i don't understand the last part of your question, about subtractions)
"per" means "divide".
A ball rolls 5 feet every 30 seconds. How far has it rolled after 3 minutes (solve without using fractions)? How did you reason out your answer? Is it a bit like "There are 5 feet attributed to every slice of 30 seconds, so I just have to find how many slices of 30 seconds fit into 3 minutes" ? That's pretty much the motivation for a fraction: one property is directly associated to a certain amount of a different property, so operations with that property correspond to operations on the proper corresponding multiple of the first property.
Thank you for the feedback everyone. I am backing out of this question though. I don't know if I am overthinking it or something, but I am having a "I'm not exactly sure what my own problem even is" moment. Although, there is something I'm not getting :S Maybe I'll come back to it another time.
  • · Replies 31 ·
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 58 ·
  • · Replies 0 ·
