Rewrite in terms of sinØ and cosØ:
  • Context: Undergrad
  • Thread starter Thread starter Digital Limit
    Terms
The discussion revolves around rewriting trigonometric expressions in terms of sine and cosine, specifically focusing on the expressions involving cotangent and cosecant. Participants are seeking methods to simplify these expressions, which is relevant for their upcoming test.
  • Homework-related
  • One participant requests assistance in rewriting cot²Ø/(cscØ + 1) + 1 and simplifying tan x/(csc x + cot x), expressing a need for clarity on the methods used to arrive at the answers.
  • Another participant provides a suggested answer for the first expression as 1/sinØ and for the second as sec x - 1, but does not elaborate on the steps taken to achieve these results.
  • Some participants propose writing everything in terms of sine and cosine and mention using identities like cos² + sin² = 1 to simplify the expressions.
  • One participant describes their attempts to apply various identities, noting that these efforts often complicate the problem rather than simplify it.
  • Another participant asks for clarification on a previous response, indicating that some points made were inconsistent and lacked detail.
  • Several participants share their progress on the problems, indicating that they were able to solve the first expression using the common denominator approach suggested by others.
Participants express a mix of agreement on the general approach of rewriting expressions in terms of sine and cosine, but there is no consensus on the specific methods or identities to use, as some find the process complicated and others report success with different strategies.
Some participants mention using specific identities and common denominators, but the discussion reveals that there are various interpretations and methods that lead to different levels of success in simplifying the expressions.
Digital Limit
Code:
 cot²Ø
--------  +1
 cscØ+1
Simplify:
Code:
    tan x
csc x + cot x
A friend of mine and I have been struggling over these type of problems for the past few hours, unable to find any logical and simple way to solve them. We have the answers already thanks to our handy answer key, but we need to know HOW to get the answers. If someone would be so kind enough as to walk us through these, that'd be great. We have a test tomorrow, and need to know quick ways to arrive at an answer while taking the final, so be accurate, heh.​
Thanks.​
Mathematics news on Phys.org
Oh; and for your convenience, here are the answers:
Code:
sinØ
Simplify:
Code:
 sec x - 1
Thanks again.​
what about writing everything in terms of sines & cosines? there are also only a few identities you can use. what have you done so far?
edit: ok i just did the 1st one by doing what i said, writing cot as cos/sin, getting a common denominator & the identity cos^2 + sin^2 = 1, cancelling (1 + sin) to get the correct answer.
edit again: for the 2nd one write as cos & sin everywhere, simplify, write (1-cos^2) as (1+cos)(1-cos) to be able to cancel (1+cos) & get the correct answer
For this problem we did the basic stuff: we rewrote it in terms of sin and cos and started doing a little dance that really didn't help us. Honestly, we tried a few identities here and there, but all of them ended up making the problem more elaborate, which isn't what we want.​
Simplify:
As for this problem, it was the same idea. We rewrote it in terms of sin and cos, and attempted to apply some identities and work for some cancelation. Sadly, it'd always end up making it more elaborate than before, which is obiouvsly not the goal. As for specific identities, I'm not sure. We tried a lot of stuff and it'd take an extensive and pointless post to recollect what they all were.​
Thanks again for any help, and sorry that I couldn't be of any, heh.
Could you please elaborate? Certain points you make are inconsistent with the equation and it seems like you're leaving holes to inturpret. Thanks for your concern, though - any help is greatly appreciated.
silly me i should have just added a couple new replies rather than edits just look up instead
Thanks for the tips on the common denominator - we got the first one. We'll try your tactic on the second one and see if we can't manage a similar result. Thanks again :!)
Edit: We got them both. w00t![/size]
ok fine here's the 1st one
[tex]\frac{cot^2\theta}{csc\theta + 1} + 1 = \frac{\frac{cos^2\theta}{sin^2\theta}}{\frac{1}{sin\theta + 1}}} + 1[/tex]
put the sin^2 in the denominator:
[tex]\frac{cos^2\theta}{sin^2\theta(\frac{1}{sin\theta}+1)} + 1 = \frac{cos^2\theta}{sin\theta + sin^2\theta} + 1[/tex]
common denominator:
[tex]\frac{cos^2\theta + sin^2\theta + sin\theta}{sin^2\theta + sin\theta}[/tex]
use an identity:
[tex]\frac{1 + sin\theta}{sin\theta + sin^2\theta} = \frac{1 + sin\theta}{sin\theta(1 + sin\theta)}[/tex]
can you do the rest now? :wink:
edit: lol i guess i didn't have to do that after all :rolleyes:
[tex]\frac{cot^2\theta}{csc\theta + 1} + 1 = \frac{\frac{cos^2\theta}{sin^2\theta}}{\frac{1}{si n\theta + 1}}} + 1[/tex]
this line should be
[tex]\frac{cot^2\theta}{csc\theta + 1} + 1 = \frac{\frac{cos^2\theta}{sin^2\theta}}{\frac{1}{sin\theta} + 1}} + 1[/tex] or [tex]\frac{cot^2\theta}{csc\theta + 1} + 1 = \frac{\frac{cos^2\theta}{sin^2\theta}}{\frac{1 + \sin \theta}{si n\theta}}} + 1[/tex]
  • · Replies 20 ·
  • · Replies 125 ·
21K
