Finding the Second Derivative Using Implicit Differentiation
The discussion revolves around finding the second derivative of an implicit function defined by the equation \(\sqrt{x} + \sqrt{y} = 1\). Participants are exploring the process of implicit differentiation and the subsequent calculation of derivatives.
  • Participants are examining the correctness of the first and second derivatives, with some questioning the simplification steps taken. There are discussions on the application of the quotient rule and the implications of substituting values into the derived equations.
Some participants have provided feedback on the correctness of the derivatives, while others are clarifying their understanding of the original function and its implications. There is an ongoing exploration of the relationship between the derivatives and the values substituted into them, with no explicit consensus reached on the final form of the second derivative.
Participants are working under the constraints of implicit differentiation and are addressing potential mistakes in their calculations. There is a recognition of the need to consider the nature of the original equation when substituting values.
dekoi
Can someone check my answer (I am trying to find the second derivative) for any mistakes?
I have looked it over many times, and I've realized that my second derivative is not correct, but I cannot figure out why. Thank you.
[tex]\sqrt{x} + \sqrt{y} = 1[/tex]
[tex]\frac{1}{2\sqrt{x}} + \frac{1}{2\sqrt{y}}(y') = 0[/tex]
[tex]y' = (\frac{-1}{2\sqrt{x}})(\frac{2\sqrt{y}}{1}) = \frac{-2\sqrt{y}}{2\sqrt{x}} = \frac{-\sqrt{y}}{\sqrt{x}}[/tex]
[tex]y'' = \frac{(\frac{-y'}{2\sqrt{y}})(\sqrt{x}) + (\sqrt{y})(\frac{1}{2\sqrt{x}})}{(\sqrt{x})^2}[/tex]
[tex]y'' = \frac{\frac{-y'\sqrt{x}}{2\sqrt{y}} + \frac{\sqrt{y}}{2\sqrt{x}}}{x}[/tex]
[tex]y'' = \frac{-y'\sqrt{x}\sqrt{x} + \sqrt{y}\sqrt{y}}{2x\sqrt{x}\sqrt{y}}[/tex]
[tex]y'' = \frac{-(\frac{-\sqrt{y}}{\sqrt{x}})\sqrt{x}\sqrt{x} + \sqrt{y}\sqrt{y}}{2x\sqrt{x}\sqrt{y}}[/tex]
[tex]y'' = \frac{\sqrt{y}\sqrt{x} + \sqrt{y}\sqrt{y}}{2x\sqrt{x}\sqrt{y}}[/tex]
[tex]y'' = (\frac{\sqrt{x}\sqrt{y}+y}{2x\sqrt{x}\sqrt{y}})(\frac{\sqrt{x}\sqrt{y}}{\sqrt{x}\sqrt{y}})[/tex]
[tex]y'' = \frac{xy + y\sqrt{x}\sqrt{y}}{2x^2y}[/tex]
[tex]y'' = \frac{x + \sqrt{x}\sqrt{y}}{2x^2}[/tex]
Your first derivative is correct, but I don't see what you mean with 0y' then... You also appear to have a lot of equal-signs, it seems a bit weird...
So we have:
[tex]\left( {\sqrt x + \sqrt y } \right)^\prime = \frac{1}{{2\sqrt x }} + \frac{{y'}}{{2\sqrt y }}[/tex]
Now, the second derivative is doing just the same, just a bit longer:
[tex]\left( {\frac{1}{{2\sqrt x }} + \frac{{y'}}{{2\sqrt y }}} \right)^\prime = \left( {\frac{1}{{2\sqrt x }}} \right)^\prime + \left( {\frac{{y'}}{{2\sqrt y }}} \right)^\prime = \cdots[/tex]
I don't understand your first function. Is that supposed to be the second derivative?
And I have a lot of equal signs because I'm trying to simplify my second derivative. I think that's where I made the mistake... in simplifying.
My first line is the first derivative, the second line is the beginning of the second derivative. Since it's linear, I already split it for you. The first term will be easy since it only depends on x, the second will be a bit longer.
Well that's what I did, starting in my fourth line. I used the quotient rule on my simplified form of the first derivative, to find the second derivative. Shouldn't both methods result in the same answer?
Ok, I wasn't aware of the fact it was an equation at first.
It's much clearer now you've adjusted your initial post.
Line 6 seems to be correct, then:
[tex]y'' = \frac{{ - y'\sqrt x \sqrt x + \sqrt y \sqrt y }}{{2x\sqrt x \sqrt y }} = \frac{{y - y'x}}{{2x^{3/2} \sqrt y }}[/tex]
How about after line 6?
Is the whole thing correct? Right up to the last line?
I took over after line 6 but I didn't realize you substituted y' again.
Anyway, it seems to correct (at least your solution, I didn't carefully check every step). It's possible to 'simplify' it one last bit, although it doesn't really matter a lot anymore:
[tex]y'' = \frac{{x + \sqrt x \sqrt y }}{{2x^2 }} = \frac{{\sqrt x + \sqrt y }}{{2x^{3/2} }}[/tex]
This makes sense, however...
When I substitute a value of x, y, & y' into my equation on line 4 (the first y''), I get a different value for y'' than when I substitute the exact same values into my last equation for y''.
Why is that?
You realize that in line 4, the first derivative y' is still present in the expression for y''?
nevermind..
Yes I know.
I used my values as:
x = 4
y = 1
y' = 1/2
Huh? Your initial equation was [itex]\sqrt x + \sqrt y = 1[/itex] but [itex]\sqrt 4 + \sqrt 1 \ne 1[/tex]...[/itex]
You are right.
I know why now...
I rearranged that formula to put it in the graphing calculator.
But I forgot to consider the fact that squares can be positive or negative. ... Well at least I think that's my mistake.
Do you know what the graph of this function looks like?
Is it a circle? Or not?
Never mind that...
Substitute x = 4 into the original equation and solve for y.
You will get the value "1" .
That's what I just got.
This is odd...
  • · Replies 105 ·
13K
  • · Replies 21 ·
