Work Done On or By The System
  • Context: Undergrad
  • Thread starter Thread starter brentd49
    System Work Work done
The discussion revolves around the concepts of work done "on" a system versus work done "by" a system, particularly in the context of lifting objects and energy changes. Participants explore the definitions and implications of these concepts in various scenarios, including mechanical and thermodynamic systems.
  • One participant asserts that work done by the system is negative when lifting an object against gravity, while work done on the system is positive, as it is the opposite of work done by the system.
  • Another participant emphasizes that work is always associated with a specific force and displacement, indicating that if the displacement is in the direction of the force, the work is positive, and if opposite, it is negative.
  • A different viewpoint suggests that determining the change in energy can simplify understanding whether work is positive or negative, referencing the first law of thermodynamics as a framework.
  • One participant proposes using visual aids, such as diagrams, to clarify the boundaries of the system and the forces acting on it, noting the potential confusion introduced by gravity.
Participants express various interpretations of work done on and by a system, with no clear consensus on how to approach situations where the gravitational force is not explicitly defined. Multiple competing views remain regarding the best method to determine the sign of work in different contexts.
Some limitations include the dependence on the definitions of work and energy, as well as the assumptions made about the system boundaries and forces involved. The discussion does not resolve the complexities introduced by different scenarios or the implications of including or excluding certain forces.
brentd49
Work Done "On" or "By" The System
Will someone help solidy this concept of Work 'On' a system and Work 'Done' by a system.
If I lift an object from some defined zero potential. Then the work BY the system is -mgh, because gravity 'g' is in the reverse direction as the displacement 'h', but work done ON the system is +mgh because it is the opposite of work BY the system.
But what do I do if I don't know the work done by the system, i.e. there is not a given 'g' vector pointing down? How can I tell if the work is plus or minus?
Work is always associated with a particular force. The work done by the force is:
[tex]W = \int \vec{F}.d\vec{r}[/tex]
In your example of lifting an object, the work done by the gravitational force is negative, while the work done by the lifting force is positive.
Can you give an example of what you mean? As James R stated, work is always associated with a particular force acting through a displacement. If the displacement is in the direction of the force, the work is positive; if opposite to the force, negative.
It's sometimes easier to find the change in energy first (whether +ve or -ve) and decide whether it is positive or negative afterwards.
energy lost ===> ΔE is negative ==> work done by system
energy gained => ΔE is positive ==> work done on system
A good example is the first law of thermodynamics:
change in internal energy = heat added to system - work done by system; OR, equivalently:
change in internal energy = heat added to system + work done on system
E.g. in a four-stroke engine, if you consider a single cylinder,
work is done BY the system during the power stroke (i.e. BY the gas expanding on the piston to move it outwards and thus transferring energy outsdie the system to the other cylinders) and work is done ON the system during the exhaust stroke (i.e. by the piston (the force is supplied by the power stroke of a different cylinder) ON the exhaust gas as it is pushed out of the cylinder).
For me it's always easiest to draw a picture. Start with a big circle that defines the boundary of your system, then place objects in it. And if often doesn't matter whether something is placed inside or outside, as long as you are consistent.
Since gravity seems like an all-encompassing force, it can get confusing, but if the system is just the box, then both you lifting and gravity acting against you are outside the system. And if you put you in the system, you need to put gravity in the system as well. Otherwise, you could accidentally create a perpetual motion machine (no inputs, only outputs).
  • · Replies 77 ·
  • · Replies 34 ·
