A second order nonlinear ordinary differential equation
In summary, to solve the equation x''x=((x')^2)/2, you can use the substitution x'' = x' dx'/dx and then integrate the resulting equation to find x' in terms of x. If you need a numerical solution, you can rearrange the equation and reduce it to a quadrature.
Lightfuzz
How, if possible, could I solve the equation: x''x=((x')^2)/2? Thanks.
If you are allowed to guess, then try guess a very often used function that when differentiated gives a scaled version of itself, i.e. a function that satisfy x' = a x, with a being a constant.
Try to find such a pair of real numbers a & b that d/dt (x^a x'^b) is proportional to x"x-((x')^2)/2.
I've tried that but is there a way to actually solve it without guessing?
Equations like this, which do not contain the independent variable, are called autonomous systems. They are easily solved with the substitution x'' = x' dx'/dx . Then collect the terms in x' and x and integrate them both. This will give you x' in terms of x, which you can then integrate a second time.
Do you only require a numerical solution given some particular boundry conditions?
rearrange:
[tex] \frac{1}{2x}=\frac{\ddot{x}}{x}=-\frac{d}{dx}(\frac{1}{\dot{x}}) [/tex]
Then, reduce to a quadrature:
[tex]dt=(C-ln(\sqrt{x}))dx =d[x(C'-ln(\sqrt{x}))] [/tex]
1. What is a second order nonlinear ordinary differential equation?
A second order nonlinear ordinary differential equation is a mathematical equation that relates a function to its derivatives, where the highest derivative is of order two, and the equation is nonlinear, meaning that the function is not proportional to its derivatives. It is commonly used in physics and engineering to model complex systems.
2. How is a second order nonlinear ordinary differential equation different from a linear one?
In a linear differential equation, the function and its derivatives are only multiplied by constants, whereas in a nonlinear differential equation, they may also be multiplied by variables or functions. This results in a more complex relationship between the function and its derivatives, making it more challenging to solve analytically.
3. What are some real-life applications of second order nonlinear ordinary differential equations?
Second order nonlinear ordinary differential equations are used to model a wide range of phenomena in the physical and natural sciences, including population growth, chemical reactions, fluid dynamics, and electrical circuits. They are also used in economics, finance, and other fields to analyze complex systems and predict future behavior.
4. How are second order nonlinear ordinary differential equations solved?
There is no general method for solving all second order nonlinear ordinary differential equations, but there are several techniques that can be used depending on the specific equation. These include separation of variables, substitution, and series solutions. In some cases, numerical methods must be used to approximate a solution.
5. What are the limitations of using second order nonlinear ordinary differential equations?
While second order nonlinear ordinary differential equations are powerful tools for modeling complex systems, they have some limitations. They may not accurately represent a system if the underlying assumptions are incorrect, and they may be difficult or impossible to solve analytically. Additionally, small changes in the initial conditions or parameters of the equation can result in significantly different solutions, making it challenging to predict long-term behavior.
  • Differential Equations
