Rocket launches up starting from zero, conservation momentum
The discussion revolves around a rocket problem involving conservation of momentum and energy. The original poster presents a scenario where a rocket ejects exhaust to achieve acceleration, with specific parameters for initial and final mass, as well as exhaust velocity. The problem includes both theoretical and practical aspects of rocket propulsion, particularly in relation to achieving relativistic speeds.
  • Participants discuss the application of conservation laws, with the original poster attempting to derive the rocket's final velocity using momentum principles. Some participants suggest looking up established equations, while others express the need to differentiate the equations due to changing mass and velocity. There is also mention of using the center of mass frame for momentum calculations.
The discussion is ongoing, with participants exploring various interpretations of the conservation laws and how they apply to the rocket problem. Some guidance has been offered regarding established equations, but there is no explicit consensus on the approach or solution yet.
Participants note the constraints of the problem, including the requirement to use conservation laws as outlined in their textbook. There is also a mention of the need to estimate the mass required for a specific payload to reach a significant fraction of the speed of light, which introduces additional complexity to the discussion.
ex81
A rocket ejects exhaust with an velocity of u. The rate at which the exhaust mass is used (mass per unit time) is b. We assume that the rocket accelerates in a straight line starting initial mass (fuel plus the body and payload) be mi, and mf be its final mass, after all the fuel is used up. (a) Find the rocket's final velocity, v, in terms of u, mi, mf. (b) A typical exhaust velocity for chemical rocket engines is 4000m/s. Estimate the initial mass of a rocket that could accelerate a one-ton payload to 10% of the speed of light, and show that this design won't work. (ignore the mass of the fuel tanks.)
Kinetic Energy = 1/2 mv^2
momentum = mv
work = f*d
f=ma
I started out with the conservation of energy, and then switched to the conservation of momentum.
The rocket starts out at rest. so mi*vi = 0
0 = mf*v +(mi-mf)*u
which makes sense since the rocket's momentum will be opposite to the exhaust velocity, and the two momentum will cancel.
Now is the part where I am stuck.
Look up the ideal rocket equation. Although it is basically a Newton's third law momentum problem, it is not that simple to develop it on your own.
AM
It is in the conservation section of the book. Ergo I have to use the conservation law :-(
I do realize that I need to differentiate the equation but I am pretty sure I need to tweak my current equation. Due to the change in mass vs velocity.
Ok. You can do a rough estimate using conservation of momentum.
Use the centre of mass frame - the earth. Initial momentum is 0. In order for you to get 1000kg moving at .9c how much mass moving at 4000 m/sec in the opposite direction will you need so that the total momentum is 0?
AM
I think I am on the right track just from looking at NASA's ideal rocket equation
0 = mf*v +(mi-mf)*u
now NASA has dm * u/dt= v * d(mass propellant)/dt. Cancel out their dt, and their equation is dm *u=v*d(mass propellant)
So based on the above my equation needs to change a little, and needs to be derived.
P.S. my u, and v is switched from NASA's
  • · Replies 30 ·
  • · Replies 42 ·
