- #36
NascentOxygen
Staff Emeritus
- 1,074
Then let's call him back and demand that he explain himself! http://imageshack.us/a/img10/9783/whiponionheademoticon.gif [Broken]davenn said:I really don't understand NascentOxygen's responses
First, the question seems to come from Circuit Principles 101, and concerns a simple first order system. So it's not meant to invoke a treatise on inductive non-idealities. Further, the circuit appears to have been dreamt up by someone who himself doesn't have a good grasp of inductors. Well, that's my conclusion, because had he constructed the circuit he would have discovered that it has not a hope in hell of doing what he obviously expects it to.
Not much to argue about there.lets start at the start and some one clearly define each step please
1) switch closed to A ... current flowing from battery through inductor, resistor and back to battery
Ha! There's the problem. And it's a big problem. Unless the switch goes from A to B without opening the circuit for even one-squillionth of a second, then the inductor will dump its energy inside the switch and the party is over and we may as well all go home. (Remember, -L.di/dt. We must not interrupt the inductor current.)2)switch opens from A and closes to B
So I gave the author the benefit of the doubt by assuming that he really means for the neon to be connected across the inductor at all times, and for the switch to do nothing more than disconnect the battery. Fair enough? Because if we don't assume this then there is not much left for students to analyze.
Why would an ideal neon have significant capacitance? The question doesn't say to consider it is a capacitor as well as a neon, so why complicate it? Let's use a tiny ideal neon globe, it has no capacitance.3) I see the neon being an open circuit till the voltage is high enough to strike the neon ... prior to striking, the neon is a significant capacitor ?
We are using an ideal neon. It [apparently, since the question doesn't say otherwise] strikes at practically its holding voltage, so we have no need to complicate the issue by separately considering the striking and the holding voltages.So WHEN does the neon strike ?
It couldn't, for a couple of reasons. One I pointed out above. Another rather major one being that the neon is not even in the circuit until the switch is safely in position B! (But I'm confident that students of Circuit Principles 101 would not notice there's an issue with the switching, so I wouldn't anticipate they would baulk here.)a) -- is the opening of the switch contact generating the voltage spike that lights the neon but before the switch closes to B position? or...
That. (But I'm uneasy with your emphasis on reversed current flow. I thought we agreed that the inductor current does not reverse? Ever — this being a first order system. No current in any element here reverses.)b) is it the collapsing magnetic field through the coil and the spike is that EMF that's generated and with current flowing in opposite direction and with the switch closed to B position that "reverse direction " current flow is striking the neon?
Hope that has cleared some things up.
