Proof of calculating area and volume
  • Context: High School
  • Thread starter Thread starter sitokinin
    Area Proof Volume
The discussion revolves around the formulas for calculating the area and volume of geometric shapes, specifically circles and spheres. Participants explore the origins of these formulas, the definitions of geometric terms, and the distinctions between different types of shapes. The conversation includes elements of calculus, geometry, and definitions of mathematical concepts.
  • Some participants assert that the formulas for the perimeter and area of a circle, as well as the volume of a sphere, arise from integration.
  • One participant challenges the notion that a circle has an area, arguing that a circle is a one-dimensional object and questioning how one can speak of the area of a curve.
  • Another participant provides a visual explanation of how the area of a circle can be understood through a geometric construction involving slices of the circle.
  • There is a discussion about the definitions of geometric shapes, with some participants expressing confusion over the distinction between a circle and a disk.
  • Participants debate the terminology used to describe the area enclosed by various shapes, including triangles and polygons, and whether these shapes can be defined in terms of curves or angles.
  • One participant introduces the concept of geodesic curves in relation to triangles and angles, suggesting a more complex understanding of these definitions.
Participants express differing views on whether a circle has an area, with some insisting it does not, while others refer to established terminology that includes the area of a circle. The discussion remains unresolved regarding the definitions and properties of geometric shapes.
The conversation highlights limitations in definitions and assumptions about geometric shapes, particularly regarding dimensionality and the nature of curves versus enclosed areas. There is also a lack of consensus on the terminology used to describe areas and volumes of various shapes.
This discussion may be of interest to individuals exploring geometric concepts, definitions in mathematics, and the relationship between calculus and geometry.
sitokinin
If r is the radius of a circle,
For circle perimeter we use; ''2*pi*r''
For circle area we use; ''pi*r²''
And for sphere we use; (4/3)*pi*r³
but how do we calculate them?
Mathematics news on Phys.org
Do you mean, how did we find these formulas?
If YES, then, they arise from integration
Yes,by integration.
Daniel.
P.S.The circle does not have an area...
What !?
The circumference of the circle is very easy, because it follows from the definition of [itex]\pi[/itex].
This actually needs calculus to be rigorous but there exists a cute "proof" that I learned in the local equivalent of elementary school. Take equal miniscule (at the limit, infinitesimal) segments of the circle. Each of these is shaped like a little slice of pizza. When you place two "slices" in opposite orientations, aligned along the radius, you will construct something that looks like a parallelogram. As you take more and more slices, it will approach a rectangle at the limit. The rectangle will have smaller side equal to r and larger side equal to [itex]\pi r[/itex], giving the area of [itex]\pi r^2[/itex]. Note that while this helps you to "see" the proof, it really uses basic concepts of calculus explained simply. To do it properly really does require calculus.
There is an elegant proof due to the Greeks that does not involve calculus. Read about it here : http://mathcentral.uregina.ca/QQ/database/QQ.09.01/rahul1.html
Curious3141 said:
What !?
1.What is the definition of a circle??
Daniel.
Daniel.
I have absolutely no idea what you're on about, but even Mathworld calls it the "area of the circle". http://mathworld.wolfram.com/Circle.html
OMG,they can't make the difference between a circle and disk...
THE CIRCLE IS A CURVE,A UNIDIMENSIONAL OBJECT.CAN U CONSIDER THE AREA OF A CURVE?CAN U CONSIDER THE LENGTH OF A SURFACE??CAN U CONSIDER THE VOLUME OF A SURFACE?CAN U CONSIDER THE VOLUME OF A CURVE?
ME NEITHER.
So how can someone speak about the area of a circle??
Daniel.
PS.What about the triangle??The square??The polygons??Do they have area??
Enclosed area. No need for the outraged splitting of hairs.
AAAAAAAAAAAAAAAAAAAAaaaaaaaaaaaaaaaaaaaaaahhhhhhhh,well that's something else... :approve:
I'm glad you agree. :-p
Daniel.
Good. :smile: Now what about the binomial thing below ? :biggrin:
Perfect. :approve:
If you really want to split hairs, there's an important difference between having zero area and not having area. :biggrin:
(The circle has zero area)
hey, so, how do I call the enclosed area of a triangle, square, rectangle ...etc :rolleyes:
Please,Hurkyl,show us that the circle has zero area using the double integral construction with Riemann sums... :bugeye:
Daniel.
The "enclosed area of a triangle/square/rectangle" ? :-p
The "enclosed volume of a cone/cylinder"??The volume of a ball??
Daniel.
PS.I liked the part with the physicists... :-p ball
It reduces to showing that the outer area of the circle is zero. Recalling the definition, the outer area of a set X is defined as follows:
Consider any grid G of rectangles that covers X. Let A(G, X) be the total area of the rectangles of G that have a nonempty intersection with X. Then, the outer area of X is defined to be the infimum of A(G, X) over all grids G.
Then, you just need to show that, as you refine the grid, the number of such rectangles grows roughly linearly, while their areas decrease quadratically.
don't avoid my question... how people called the area enclosed by a triangle? I searched through google and return nothing, also.. is triangle an angle or a curve? if I have a closed shape contains 3 angle and 3 curve(not straight) on a flat plane, do we call it triangle? what if the shape is not closed? :cry: Could someone tell me what is a triangle... what is its definition?
Usually, one specifies precisely what they mean by "rectangle" (and similar words) before using it. (Like I should have done in my previous post)
I didn't...
The enclosed area of a triangle?
That's because it's not something specific.Any closed curve encloses a domain of (hyper)surface.Any (hyper)surface has an area and any domain (open/closed) has an area.Ergo,we should call it "area of the surface enclosed by a triangle",but that's too long and we say "area enclosed by a triangle"...
It is a closed curve which has three tops/peaks/summits (which is the word?? :confused: ),three angles and three sides...
Nope.I think it has to do with the fact that its sides must be geodesic curves on the (hyper)surface in which the triangle lies...
Nope.It wouldn't be a triangle.
Maybe my/this post gave you a (hopefully correct) idea.
Daniel.
dex, you are rock...I like you point out the concept of "geodesic curves", yeah, this solved my straight line problem in the triangle... howabout angles... how do you define angle?
could i define it like this: an angle is a continue curve which is not smooth...
I'm not looking for a textbook definition.I'll let u pick it up.Consider a (hyper)surface and the bunch of curves on it.These curves intersect each other.IIRC the definition of the angle between two curves on a (hyper)surface is the angle betweent the two tangent LINES (THESE MUST BE LINES) at the two curves in the intersection point.Note the fact that the concept of geodesic curves plays no role.Think about the 2D sphere (topological definition).The curves on this surface are from very simple (the geodesics,namely the big circles) to very complicated.The idea that the the angle between two of these curves is not given in terms of geodesics,but in terms of lines has deeper roots and allows the definition of angle between geodesic curves as well.
The roots are found in the fact that the lines I'm talking about care actually vectors in the tangent space of the manifold (2 sphere) in that point of intersection.
In the simple 2D plane u can have angles between geodesics (lines) and general curves (from simple to very complicated) given in terms of the lines tangent of the curves in the intersection point.The tangent space of the 2D plane coincides to the plane itself.
However,for a triangle,the sides must be geodesics and the angles in the triangle are defined in terms of the angle between the geodesics.Think of the astroid,can u think of it as being a "curved" quadrilater??Compute its angles.They are all zero...The sum would not be 360° as it should.Yet it would be in a plane,a closed plane curve...
Geometry is beautiful.
Daniel.
Thanks for the short explanation.
PS: I know the difference between the full circle and the empty circle, but I looked at the dictionary it has just one meaning for both!
Meanwhile when we calculate the area of a triangular, do we add the area of the line segments? I mean does the total area include the inside of the triangular and line segments or just the inside of the triangular?
You're welcome.
No,no,you're talkin about another "animal",the DISK,or the 1D ball.It has a closure and that's the circle.
We've just said that the curves have zero area... Segmens have zero area...
It's irrelevant,the closure (the triangle) has zero area...Adding with zero won't change anything...
Daniel.
The area enclosed by a CIRCUMFERENCE is called CIRCLE.
No problem if you say 'area of a circle' . However 'area of a circumference' doesn't make sense.
WRONG!Don't mislead people. :mad: The circle is the geometrical locus of all points from a plane found at equal distance from a fixed point.
I advise u read some geometry.
Daniel.
Who is misleading people here?
According to you, if circle was just a curve, its area would be zero.
However, try google "area of a circle" and "area of a circumference", and see the difference. If it is not enough, google "area of a disk", too.
The 2-D figure enclosed by a circle (a 1-D curve) is called a DISK.
End of discussion.
(This corresponds to the distinction in higher dimensions between a sphere and a ball)
  • · Replies 16 ·
  • · Replies 59 ·
232K
