Register to reply
Eutectic point
by chound
Tags: eutectic, point
Share this thread:
chound
#1
Jun11-06, 12:52 AM
P: 239
What is eutectic point?
Phys.Org News Partner Chemistry news on Phys.org
Faster, cheaper tests for sickle cell disease
Simulations for better transparent oxide layers
Characterizing strontium ruthenate crystals for electrochemical applications
ccl4
#2
Jun11-06, 11:42 AM
P: 10
Quote Quote by chound
see here:
http://en.wikipedia.org/wiki/Eutectic
ccl4
chound
#3
Jun12-06, 06:49 AM
P: 239
Actually I read that but couldnt understand what was written that's why I posted here
Astronuc
#4
Jun12-06, 07:36 AM
Admin
Astronuc's Avatar
P: 21,880
Eutectic point
chound, what is not clear in the wikipedia article.
The key point is:
A eutectic or eutectic mixture is a mixture of two or more phases at a composition that has the lowest melting point, and where the phases simultaneously crystallise from molten solution at this temperature.
In the two phase diagram given, the eutectic is found at the "V" of the liquid phase, where the vertex touches the horizontal line. The horizontal line represents a constant temperature, and the vertex represents a specific composition. The eutectic represents the point where that composition goes 'directly' from solid to liquid, i.e. without partially melting to a solid-liquid combination.
The example of the steel (Fe - C) system is perhaps better.
http://en.wikipedia.org/wiki/Eutectic#Eutectoid
This figure shows the eutectic and eutectoid.
Then there is a three-phse reactions diagram below that:
http://en.wikipedia.org/wiki/Image:T...-Reactions.png ,
which should be more clear.
Here is another site which discusses binary phase diagrams.
http://csmres.jmu.edu/geollab/Fichte...x/BinryEu.html
Gokul43201
#5
Jun12-06, 09:24 AM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
Look at this post from another forum. It may be helpful.
http://www.scienceforums.net/forums/...6&postcount=20
Register to reply
Related Discussions
Why triple point of water is higher than freezing point Classical Physics 7
Is every point of every closed set E subset of R^2 a limit point of E? Calculus & Beyond Homework 2
Shortest time from a point to a moving point Calculus 5
Calculating point X on the Golden Spiral knowing a point and a distance Calculus 0
Distance from a point on a sphere to a point on a plane... Calculus 6
