Help can someone differentiate e^(nx)
  • Context: High School
  • Thread starter Thread starter Bailey
    Differentiate
The discussion revolves around differentiating the function e^(nx), where n is any integer. Participants explore various methods of differentiation, including the chain rule, product rule, and limits, while addressing the correctness of different approaches.
  • One participant claims that the derivative of e^(nx) is n*e^(nx) and provides a proof involving limits.
  • Another participant suggests using the chain rule, letting u = nx, to find the derivative as n*e^(nx).
  • A different viewpoint proposes that the product rule could be applied, although this is challenged by others.
  • Some participants argue that the product rule does not apply in the way suggested, as e^n is a constant.
  • One participant mentions that the product rule can be used repeatedly to differentiate e^(nx) and provides examples with e^(3x).
  • Another participant emphasizes that e^(nx) is not equal to e^n * e^x, indicating a misunderstanding in applying the product rule.
  • Several participants discuss alternative methods, including using logarithms and the power rule in conjunction with the chain rule.
There is no consensus on the best method to differentiate e^(nx). Participants present multiple competing views and approaches, with some disagreement on the applicability of the product rule.
Some participants express uncertainty regarding the application of the product rule and the correctness of algebraic manipulations. The discussion includes various assumptions about the definitions and properties of exponential functions.
Bailey
can someone differentiate e^(nx) where n is any integer. i think is equal to n*e^(nx).
please show the proof, thanx.
:smile: :smile: :smile:
Well the proof is very big, so i just give u an idea as to how to go abt proving:
[tex]d(e^{(nx)})/dx = ne^{nx}[/tex]
now increment y by a small value such that:
[tex]y + \Delta y = e^{(n(x + \Delta x))}[/tex]
Divide the whole term by y such that:
[tex](\Delta y)/y = [[e^{(n(x + \Delta x))}]/(e^{(nx)})] - 1[/tex] {We are putting [tex]d(e^{nx})/dx = n*e^{nx}[/tex] on the right hand side of the eqtn.}
take the one on the other side to get:
[tex]\Delta y/ y = [e^{(n(x + \Delta x))}- e^{(nx)}]/[e^{(nx)}][/tex]
now apply the limits [tex]\Delta y \longrightarrow 0[/tex] to bot sides and evaluate the limit to get your answer.
Sridhar
Or, assuming you don't actually need to go back to the original definition of the derivative: apply the chain rule.
To differentiate y= enx, let u= nx.
Then y= eu so dy/du= eu
(If you don't know that then you will need to go back to definitions- in particular exactly how you are defining ex.)
du/dx= n, of course, and
dy/dx= (dy/du)(du/dx)= eu(n)= n enx.
thanx guys. i think the product rule can also use to differentiate
e^(nx), since e^(nx)=e^(n)*e^(x). but that will require much more time.
this is not correct, the product rule does not apply here.
e^(nx)=e^(n)*e^(x).
Hmm . .. I don't think that is quite legal since e^n is a constant, the product rule only applies if you have two functions.
you could alternately take the log of both sides which may look something like:
lny(x)=lne^nx
differentiate with respect to x
y'/y=n
y'=ny
and since y= e^nx
y'=n*e^nx
Of course I used the chain rule now on the left hand side, now
The product rule applies fine for a constant term, since a constant is a perfectly good function. It does not apply the way he said though; his exponential relation is wrong.
[tex] e^ne^x=e^{n+x}[/tex]
It's mightily unnecessary as one term will automatically go to zero, and yes I missed his algebraic mistake
sorry about that mistake, what i meant was that,the product rule can be use repeatly to differentiate e^(nx).
eg. differentiate e^(3x)
e^(2x) = e^(x)*e^(x)
[e^(2x)]'=e^(x)*[e^(x)]' + e^(x)*[e^(x)]' = e^(x)*e^(x) + e^(x)*e^(x)
[e^(2x)]'= 2e^(2x)
e^(3x) = e^(2x)*e^(x)
[e^(3x)]'=e^(x)*[e^(2x)]' + e^(2x)*[e^(x)]' "sub [e^(2x)]'= 2e^(2x)"
[e^(3x)]'=e^(x)*(2e^(2x)) + e^(2x)*e^(x)
[e^(3x)]'=2e^(3x) + e^(3x)
[e^(3x)]'=3e^(3x)
Okay, you recognize that enx is NOT enex so that the a single application of the product rule does not work.
Yes, you can use the product rule repeatedly (in a proof by induction) but why?
What's wrong with using the chain rule as I suggested?
Actually, this is a more interesting problem that I first thought- there are several different ways of doing it.
The "obvious" way (to me anyway) is to note that the derivative of ex is ex and use the chain rule:
denx/dx= ex(d(nx)/dx)= nenx.
But we can also write enx= (en)x and use the fact that dax/dx= (ln a) ax:
d((en)x)/dx= ln(en)(en)x= nenx.
Or do it the other way around: enx= (ex)n) and use the power rule (together with the chain rule and the derivative of ex):
d((en)x)/dx= n((ex)n-1)(ex)= n(ex)n= nenx
  • · Replies 33 ·
11K
