Wiring a 110V Fan with Low Voltage Thermostat: A Beginner's Guide
The discussion revolves around the challenge of controlling a 110V fan using a low voltage thermostat. Participants explore various methods and components suitable for this application, including relays, opto-isolating triacs, and temperature sensors. The conversation includes both theoretical and practical considerations for wiring and safety.
  • Homework-related
  • One participant suggests using an opto-isolating triac to safely isolate the low voltage side from the high voltage side.
  • Another participant recommends starting with a plain old relay, indicating that it may be more suitable for beginners.
  • There is a proposal to use a line voltage thermostat, although some participants express concerns about wiring line voltage to the thermostat.
  • A suggestion is made to use an LM35 temperature sensor connected to a comparator to trigger a relay, with an adjustable reference voltage.
  • Concerns are raised about the safety of designing a low voltage controller without expert knowledge, emphasizing the importance of proper enclosure and isolation.
  • Some participants agree that it is better to purchase a suitable UL approved controller rather than attempting a DIY solution.
Participants express differing opinions on the best approach to control the fan, with some advocating for relays and others for line voltage thermostats. There is no consensus on a single solution, and safety concerns are a common theme in the discussion.
Participants highlight the importance of safety and proper knowledge when working with electrical components, indicating that the discussion is not just about wiring but also about ensuring safe practices.
ZooY151
I am trying to control a 110V fan with a low voltage thermostat. I am pretty new to electrical theory... I would like a basic description of what I need and how to properly wire it. Thanks!
You need an Opto-Isolating Triac, this will safely isolate the low voltage side form the high voltage side.
Do an internet search for opto-isolating triacs, get the data sheet on a suitable one and there may be circuits in the application notes.
Make sure you get your work checked by somebody who knows what they are doing before you build it and definitely before you plug it in.
For someone who seems new to electricity as does the OP I would recommend starting with the low-tech approach of a plain old relay. I haven't looked for a while, but I suspect Radio Shack has exactly the device you need.
An lm35 temp sensor hooked up to a comparator to trigger a relay is probably the way I would go. You can hook a pot up to the comparator to adjust the reference voltage and act like a thermostat. The last time I used an LM35, I believe it sourced 1mA/degree celsius.
russ_watters said:
What about a line voltage thermostat?
I don't think you want to put line voltage on your temp. control wires. As Averagesupernova says; use a "plain old relay" ...that can be mounted on the fan with the other power devices.:cool:
When you wire a line votage thermostat, you wire it as in place of a wall switch.
If the fan has a wall switch in a sutible location, you can just substitute.
"When you wire a line votage thermostat, you wire it as in place of a wall switch."
Okay then.
I wanted to make sure that the OP didn't try to wire line voltage to his existing thermostat.
Okay then.
Good point.
It's also not trivial to design a safe low voltage controller.
Proper enclosure and isolation layouts are not something to attempt without expert knowledge.
Better off purchasing a suitable UL approved controller.
  • · Replies 38 ·
