| Thread Closed |
what make the magnet to be magnet with magnetic field? |
Share Thread | Thread Tools |
| May14-07, 11:50 AM | #1 |
Answer please. Thank you very much. I am talking about permanent magnet.
| May14-07, 02:57 PM | #2 |
Scientist, I again reiterate what I said in your previous thread; forums are not an ideal medium from which to learn basic physical principles, you would be much better served with an elementary undergraduate physics book. That said I offer a brief summary of magnetism.
Magnetism is a direct affect of atomic magnetic dipoles, which itself results from two quantum mechanical properties of atomic electrons. Firstly, the electron has an orbital angular momentum which is determined by orbital angular momentum quantum number which falls out of the Schrödinger Equation. This "orbital angular momentum" should not be confused with classical angular momentum in so much as electrons in an atom do not obey classical orbits. This orbital angular momentum results in an orbital magnetic dipole moment which behaves as a classical magnetic dipole moment (think tiny bar magnet). The second, more dominant factor, is the electron "spin". Again, this spin should not be confused with classical spin (the electrons in an atom don't actually spin on their axis), it is merely a quantum mechanical description of the electron state. Again, this spin quantum number results in a spin magnetic dipole moment. Now, to occupy the lowest energy states (magnetic dipole moments have an associated potential energy in the presence of a magnetic field) the electrons tend to 'pair up' with other electrons so that their magnetic moments cancel each other out in a full shell/sub shell, it is the partially filled shells/sub shells which result in a net magnetic dipole moment. The atomic dipole moment is simply the sum of all the individual orbital and spin magnetic dipole moments. Therefore, elements / substances with certain configurations / partially filled [sub]shells will be magnetic. Magnetic Dipole Moment @ Hyperphysics (better than wiki) Magnetic Dipole Moment @ Wikipedia |
| May15-07, 02:08 AM | #3 |
| May15-07, 07:08 AM | #4 |
Mentor
If you have a problem in trying to ask a question, and you also have a problem in understanding the answers you were given, don't you think this whole exercise is becoming rather futile?
Here's what I strongly suggest that you do: 1. Read the references given, especially at Hyperphysics. 2. Now, using THOSE references, try to understand the relevant sections that could answer your questions. 3. After you have made an effort to understand those, and if you still could not figure those out, ONLY THEN should you ask here. But don't ask some basic, generic question that requires a whole lesson in physics to understand. That is impossible to do on a forum like this. Ask the specific item that you read that you did not understand. Give the exact reference and the exact location what and where you did not understand. If not, I don't think anyone has the patience to want to teach you whole textbooks worth of physics. I certainly don't. Zz. |
| May15-07, 10:53 AM | #5 |
| May15-07, 11:09 AM | #6 |
What you are essentially asking me/us to do is present virtually whole lectures on parts of physics where you have little or no grounding, this is a virtually impossible task on a forum and even if it were, I am not willing to invest the and effort that it would take. Now, I don't mind offering help to those who have fairly specific questions, and I don't mind writing extended posts, I usually have PF open while I'm working and just check for new posts every now and again; but what your asking is for us to basically write a physics textbook for you. I'll repeat again, you would be best served purchasing an elementary physics textbook or at least reading the references I gave you because from your questions it doesn't seem to me that you have read the links. Again, I sympathise with your language barrier but you would be best served with a textbook (or at least reading the references). |
| May17-07, 12:54 AM | #7 |
and is the magnetic field energy?
| May17-07, 02:16 AM | #8 |
[tex]\frac{U}{V} = \frac{B^2}{2\mu}[/tex] You should realise that the magnetic field is simply a relativistic consequence of the electric field. P.S. There's no need to tack your question onto the bottom of another [unrelated] thread; you should post new questions as new topics. Thanks
| May17-07, 04:03 AM | #9 |
| May17-07, 04:11 AM | #10 |
| May17-07, 06:22 AM | #11 |
Answer please. Thank you.
| May17-07, 07:26 AM | #12 |
| May17-07, 12:11 PM | #13 |
| May17-07, 02:41 PM | #14 |
| May18-07, 01:14 AM | #15 |
| May18-07, 07:27 AM | #16 |
Hootenanny - could you explain a little more about why you used the term "pseudo-vector field" to describe the magnetic field? Because of its relativistic nature? Thanks.
| May18-07, 10:43 AM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: what make the magnet to be magnet with magnetic field?
| Thread | Forum | Replies | ||
| How can a permanent magnet produce magnetic field? | General Engineering | 20 | ||
| Induction of a coil and force exerted on magnet in a magnetic field | Classical Physics | 1 | ||
| modeling the magnetic field of multiple magnet bars | General Physics | 4 | ||
| What is maximum magnetic field strength of SC magnet | General Physics | 2 | ||
| Calculating Magnetic field of permanent magnet | Classical Physics | 1 | ||
