- 12,000
- 2,307
ok. but you have an intuitive idea of continuity, and the three big theorems just say:
1) if f is continuous on an interval, then the values of f form an interval also.
2) if f is continuous on a closed bounded interval, then the values also form a closed bounded interval.
well ok i got them to two theorems.
so then the question becomes, how do i define continuity precisely so as to make these intuitive theorems actually true?
the answer is to say that small changes in the inputs produce only small changes in the outputs. but this has to be made very precise, with letters for the degree of change in input (delta) and output (epsilon).
up the answer" That said it is worth working through these problems because they not only enhance your conception of the topic being discussed but also teach you problem solving.
