Evaluating Double Integrals: Switching the Order of Integration
The discussion revolves around evaluating a double integral by changing the order of integration. The integral in question is defined over a specific region, and participants are exploring how to switch the order of integration effectively.
  • Participants discuss the necessity of changing the order of integration, with some questioning whether it is needed at all. There are attempts to clarify the integration limits and the geometric interpretation of the region of integration. One participant expresses confusion about the original integral's setup and seeks assistance in switching the order.
Some guidance has been provided regarding the geometric interpretation of the integration limits, and a new expression for the integral has been proposed. However, there is still some uncertainty among participants about the reasoning and steps involved in switching the order of integration.
Participants have noted that the textbook example on switching the order of integration is unclear, which may be contributing to the confusion. There is also mention of a potential misreading of the integral's function, which adds to the complexity of the discussion.
Alw
Evaluate the double integral by changing the order of integration in the iterated integral and evalutating the resulting iterated integral.
[tex]\int[/tex][tex]^{1}_{0}[/tex] [tex]\int[/tex][tex]^{1}_{x}[/tex] cos(x/y)dydx
I know how to solve a double integral after I've switched the order of integration, I'm having trouble with the acutal switching part :confused: The book we are using has one example in it regarding this, and it isn't very clear. If anyone would mind walking me through how to switch the order of integration, that'd be great :smile:
Thanks in advance,
-Andy
edit: The text for the integrals didnt come out well, to make it more clear, its the integral from 0 - to - 1 and the integral
from x - to - 1
Why must you change the order? The integral is easily solvable as it is.
Is it? I can't see how.
I know how to solve a double integral after I've switched the order of integration, I'm having trouble with the acutal switching part The book we are using has one example in it regarding this, and it isn't very clear. If anyone would mind walking me through how to switch the order of integration, that'd be great
It always helps if you sketch the area over which you're integrating. Notice that the limits in x are from 0 to 1.
So, the area over which you're integrating is bounded in the x direction by the lines x=0 and x=1. Also, since the limits in y are from x to 1, the boundaries in the y direction are the lines y=x and y=1. Can you sketch the area now? From this, can you figure out how to switch the order of integration?
I read it wrong :( I seemed to read cos (y/x) >.<" Damn
Ok, thanks! so if I'm not mistaken then, the new equation is:
[tex]\int[/tex][tex]^{1}_{0}[/tex] [tex]\int[/tex] [tex]^{y}_{0}[/tex] cos(x/y)dxdy ?
Yes. In your original integral x ranged from 0 to 1 and, for each x, y ranged from x to 1. That is the triangle with vertices (0,0), (1,1) and (0, 1). In the opposite order, to cover that triangle, y must range from 0 to 1 and, for each y, x must rage from 0 to y.
  • · Replies 19 ·
  • · Replies 17 ·
