Orbital Energy of a binary star system
The discussion revolves around the energy of a binary star system where both stars have equal mass and a highly eccentric orbit. The original poster is exploring how to describe the total energy of the system, particularly at apocenter where the velocities are minimal.
  • The original poster attempts to calculate the total energy based on potential energy at apocenter, questioning the validity of their reasoning.
  • Some participants question the assumption of negligible velocity at apastron and whether such a scenario is realistic.
  • Others suggest considering the implications of angular momentum and the symmetry of the orbits in a binary system.
  • There is a discussion about the potential to simplify the problem by treating the system as a one-body problem with respect to the barycenter.
The conversation is ongoing, with participants exploring different interpretations of the energy calculations and the assumptions involved in the binary star system. Some guidance has been offered regarding the nature of potential energy and the conditions at apastron, but no consensus has been reached.
Participants are navigating the complexities of orbital mechanics, particularly in relation to eccentric orbits and the implications of mass and angular momentum in binary systems. There is an acknowledgment of the challenges posed by the assumptions made in the problem setup.
Aquafina20
Say you have a binary star sytem. Both stars have mass M and semimajor axis a. The orbits are extremely eccentric (e is approximately 1). How would you describe the energy of the system?
SEE BELOW
Basically I'm very unconfident about my answer and feel like I'm blanking on basic physics. I imagined the stars both at apocenter at some initial time. With such an eccentric orbit the velocities would be nearly zero here, so the total energy of each stars orbit would be quite nearly all potential energy.
-Gmm/r where r is distance to the barycenter or 2a so the potential energy of each star is -(Gm^2)/2a. So the sum of the PE's would be 2 times this amount and therefore the total energy of the orbit is -(Gm^2)/a
Is this valid?
Essentially zero velocity at apastron would be a very special case.
This might be of use - http://instruct1.cit.cornell.edu/courses/astro101/java/binary/binary.htm
http://www.astro.cornell.edu/academics/courses/astro201/bin_orbits.htm
http://filer.case.edu/sjr16/advanced/stars_binvar.html
See this page - http://csep10.phys.utk.edu/astr162/lect/binaries/visual.html - which also has an applet.
Should the two stars have the same initial angular momentum?
I was trying to think of a way to generalize circular binary orbits - e.g.
http://hyperphysics.phy-astr.gsu.edu/hbase/orbv.html#bo
This is understandable, but would it not be possible to have orbits so eccentric that apocenter velocity would be negligable in contribution to energy? Do not be concerned with practicality or realism. I imagine this being an approximate model for a collision scenerio with both objects starting at rest where the exaggerated eccentricity allows us to throw the objects as nearly directly towards one another as an orbit can allow.
If the kinetic energy was negligible, then at apastron, the total energy (neglecting the rotational energies of the stars) would simply be the gravitational potential energy at that distance/separation.
The java applets show that e=1 is extremely eccentric with little overlap of the orbits.
But I was wondering about a more general case. I think one is assuming not only the same mass, but same eccentricity and angular momentum, i.e. the same (or symmetric) orbital parameters for both stars.
Would -GM^2/2a be an acceptable description of total energy or am i misinterpreting center of mass? Could you not say the two masses are m/2 and 2m and turn it into a one body with one oject stationary at the barycenter and the other following the same orbit in the two body?
Well, wouldn't that be implicit in having a two body problem where m1=m2=m?
No - why would it? In addition to m1 = m2, one would need m1v1r1 = m2v2r2, no? And the two mass would have to be in phase in their orbits.
Orbital mechanics in not my specialty, and it's been a long time since I've sat down and worked through such material.
10K
  • · Replies 30 ·
