Diffusion equation and neutron diffusion theory
In summary: I'm not sure what is meant by the "square root" in this context.I think that means that you would need to solve for the fluxes for each group, and then use the boundary condition that S = 0 at the edge of the subcritical slab.
Astronuc
Staff Emeritus
2023 Award
21,902
6,321
Basically the steady-state diffusion equation can be written in a form
[itex] \nabla^2\phi\,+\,k^2\phi\,=\,S[/itex]
When S = 0, this is just the Helmholtz equation - http://mathworld.wolfram.com/HelmholtzDifferentialEquation.html
See also - http://www.math.ohio-state.edu/~gerlach/math/BVtypset/node107.html
To solve it, like any differential equation, one simply applies the boundary conditions.
I will add more later.
Likes Ibrahim Hany
What about the 2 group diffusion equation? If you are familiar, is said equation only solvable by computer program?
In special cases (e.g. 1-D), there can be an analytical solution for two group diffusion theory, basically solving two simultaneous linear differential equations.
However, for most practical (real-world) cases, the two group diffusion theory requires a numerical solution. Most modern nuclear design codes use a modified 2 group approach. There has been some effort at employing transport theory, but it has proved difficult.
A brief overview of transport and diffusion theory with respect to neutron propagation.
http://lpsc.in2p3.fr/gpr/PPNPport/node28.html
This is not comprehensive - just a summary.
The diffusion equation (second Boltzmann equation) is a special case of the transport equation.
Just in time for my final today! :smile:
Weird - I've been solving this all day in cylindrical polars... :smile:
...subject to some nasty conditions :frown:
Yep - Bessel's functions are the solutions to Bessel's equation, which is the form of the diffusion equation in cylindrical or polar coordinates for radial dependence.
Hi, I just started graduate level transport theory (sigh, the transport equation) and I'm having a heck of a time with it. Can anyone recommend any fantastic texts or websites? (I very obviously didn't do my undergrad in NE) Thanks!
Can you explain a little bit more what "k" and "S" mean in the context of neutronic diffusion?.
I think "k" is [tex]\frac {1} {L^2}[/tex] where [tex]L^2[/tex] is diffusion area. I think that makes "S" the source term.
Edit: I am having some problems with latex. Does the above look alright to everyone?
If you mean the way it displays on white, that is a feature of our installation that showed up the last time we did an upgrade to our main software. It's on the list of problems to be looked at, but other problems have higher priority; people can read this just fine, after all.
The diffusion equation is derived from transport theory with several assumptions.
Basically the steady-state neutron diffusion equation can be written as:
[tex]D\,\nabla^2\phi\,-\,\Sigma_a\,\phi\,+\,S\,=\,0[/tex], where
D is the diffusion coefficient, here spatially independent, i.e. constant, and
[itex]\Sigma_a[/itex] is the macroscopic absorption coefficient, and
[itex]\phi[/itex] is the flux.
Buried in here is an assumption that the neutrons are more or less the same energy. If not the case, then one must account for different energy groups and the absorption coefficient becomes a removal coefficient which includes absorption and scattering out of the energy group.
Anyway, the above equation becomes,
[tex]D\,\nabla^2\phi\,-\,\Sigma_a\,\phi\,=\,-S[/tex], and dividing by D
[tex]\nabla^2\phi\,-\,\frac{\Sigma_a}{D}\,\phi\,=\,-\frac{S}{D}[/tex], or
[tex]\nabla^2\phi\,-\,\frac{1}{L^2}\,\phi\,=\,-\frac{S}{D}[/tex],
where [tex]L^2\,=\,\frac{D}{\Sigma_a}[/tex]
Then there is the case where S = a function of the flux [itex]\phi[/itex].
Two group slab reactor
Would you say finding the fluxes for a two group is possible analytically? I have to solve the two equations below:
[tex]-D_{2}d^{2}\phi_{1}[/tex]/dx[tex]^{2}[/tex]+[tex]\Sigma_{R1}\phi_{1}[/tex]=1/k(v[tex]_{1}[/tex][tex]\Sigma_{f1}\phi_{1}[/tex]+v[tex]_{2}[/tex][tex]\Sigma_{f2}\phi_{2}[/tex])
[tex]-D_{2}d^{2}\phi_{2}[/tex]/dx[tex]^{2}[/tex]+[tex]\Sigma_{a2}\phi_{2}[/tex]=[tex]\Sigma_{s12}\phi_{1}[/tex]
This is solving a two group diffusion in a slab reactor with plane source at the center of the subcritical slab. So analytical or numerical? Any guess on the method to solve for flux?
Sorry, but v1 and v2 are not squared. They are just v_1 and v_2. Some reason it puts as a square.
Certainly the problem can be solved numerically (FD or FE), and I believe analytically, but I'd have to dig back in my archives for that.
one could write \nu_1 and \nu_2 in thex LaTeX expressions before \Sigma.
I think this is how the equations are supposed to look:
[tex]-{D_1}\frac{{d^2}\phi_1}{dx^2}\,+\,\Sigma_{R1}\phi_1\,=\,\frac{1}{k}({\nu_1}{\Sigma_{f1}\phi_1}\,+\,{\nu_2}{\Sigma_{f2}\phi_2})[/tex]
[tex]-{D_2}\frac{{d^2}\phi_2}{dx^2}\,+\,\Sigma_{a2}\phi_2\,=\,{\Sigma_{s12}}\phi_1[/tex]
Just looking these, one could collect coefficents and rewrite the equations as:
[itex]\phi_1[/itex]'' + A [itex]\phi_1[/itex] = B [itex]\phi_2[/itex]
[itex]\phi_2[/itex]'' + C [itex]\phi_2[/itex] = D [itex]\phi_1[/itex]
The equations as given, assuming that [tex]\phi_{1},\,\phi_{2}[/tex] are functions of x, represent a spatially distributed sources terms as opposed to a planar source, which would be a delta-function [itex]S\delta(x)[/itex] at x=0 (with x=0 being the center of the slab). S could be a function of [itex]{\nu_i}{\Sigma_{fi}}{\phi_i(x=0)}[/itex]
this forum has helped with this challenge problem but I am still having a hard time getting started, the problem is:
"There is a waiting room on the opposite side of a very large wall adjacent to a proton therapy treatment room at the local hospital.
Compute the neutron flux [tex]\phi[/tex](x) into the waiting room using a diffusion theory approximation. Assume the neutrons are emitted from the wall surface via a uniform planar surface source emitting Snot neutrons/cm^2/s. ( At wall surface, x=0)
The diffusion equation is D*(d^2[tex]\phi[/tex]/dx^2)-[tex]\sigma_{a}[/tex]=0 for x not equal to 0.
Assuming a 1-dimensional flux approximation, and other dimensions of the room (y,z) relative to the wall (at x=0) are infinite, use the following conditions:
(i)Flux must remain finite as x---> infinity
(ii)The X-ray all current(Neutron coming out of the wall) has a limit as x-->0, where:
limx-->0 J(x)*i^---->limx-->0(-D(d[tex]\phi[/tex]/dx))=(Snot/2)
(iii) D, [tex]\sigma_{a}[/tex], Snot are all constants"
any help is appreciated!
1. What is the diffusion equation?
The diffusion equation is a mathematical representation of how particles or substances move from areas of high concentration to areas of low concentration. It is commonly used to describe the behavior of gases, liquids, and other substances in various systems.
2. How is the diffusion equation used in neutron diffusion theory?
The diffusion equation is a fundamental equation in neutron diffusion theory, which is a branch of nuclear physics that studies the behavior of neutrons in a nuclear reactor. It is used to describe the movement of neutrons in a reactor and is essential in determining the reactor's criticality and power distribution.
3. What are the key assumptions of diffusion theory?
There are several key assumptions in diffusion theory, including the assumption that neutrons are emitted from a point source, the medium is homogeneous and isotropic, and the diffusion of neutrons is governed by Fick's law. These assumptions simplify the mathematical model and make it easier to solve.
4. What are the limitations of the diffusion equation?
The diffusion equation is a simplified model and has some limitations. It assumes that the medium is homogeneous and isotropic, which may not always be the case in real-world scenarios. It also does not account for the effects of temperature, pressure, and other external factors that may affect the movement of particles.
5. How is the diffusion equation solved?
The diffusion equation can be solved using various numerical methods, such as finite difference methods, finite element methods, and Monte Carlo methods. These methods involve discretizing the equation and solving it iteratively to obtain an approximate solution. Advanced computational techniques have also been developed to solve the diffusion equation in complex systems.
  • Nuclear Engineering
  • MATLAB, Maple, Mathematica, LaTeX
  • Differential Equations
