Register to reply
HELP! Light bulbs and circuits!
by GT1981
Tags: bulbs, circuits, light
Share this thread:
GT1981
#1
Nov28-07, 12:19 AM
P: 9
Two light bulbs, one 60 watt bulb (higher resistance) and one 100 watt bulb (lower resistance) are placed in series. A current is run through them. Which bulb glows brighter?
The answer detailed that: The bulb with more resistance would draw more current, thus get more voltage, so the 60 watt bulb glows brighter, has more power.
I thought all resistors in series had the same current...so how is it possible to draw more current (especially with more resistance)?
HELP!
THANKS!
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
cesiumfrog
#2
Nov28-07, 01:14 AM
P: 2,051
yeah, something sounds fishy.. but I agree most power is dissipated by the 60w bulb.
likephysics
#3
Nov28-07, 03:47 AM
P: 617
Which ever bulb dissipates more power glows brighter.
Basically, the two bulbs are like two resistors. One higher (60W) and the other lower (100W).
The higher resistor drops more voltage than the lower resistor.
The current flowing thru both of them will be the same.
Power dissipated across the 60W bulb will be higher, hence it will glow brighter.
If V=120V,
The resistance of the 60w bulb will be (from P=V*V/R) 240 ohms.
For 100W, R=144 ohms.
The total series resistance of the ckt is 384 ohms.
(From ohm's law) At 120V, current flowing thru the series ckt will be I=120/384= 0.3125Amps.
Power dissipation at 60W bulb is P=I*I*R = 23.4 W
Power dissipation at 100w bulb is P= 14.06 W
So you have a 23W bulb and a 14W bulb. The 23W obviously glows brighter.
GT1981
#4
Nov29-07, 12:08 AM
P: 9
Thanks for that additional example. Definitely helped. Just one quick question: What do you mean by "the higher resistor drops more voltage than the lower resistor"... by "drops more" what do you mean?
Thanks again,
_G
likephysics
#5
Nov29-07, 12:37 AM
P: 617
"drops more" meaning you see more voltage across the resistor.
fleem
#6
Nov29-07, 06:22 AM
P: 461
Incandescent light bulbs have negative resistance. That circuit might even have two metastable states. So its not quite as simple as the two-resistor analogy.
TVP45
#7
Dec1-07, 06:29 PM
P: 1,127
Quote Quote by fleem View Post
Can you give some reference for the negative resistance? I don't know about that.
Thanks
fleem
#8
Dec2-07, 05:52 AM
P: 461
Quote Quote by TVP45 View Post
Thanks
The "temperature coefficient of electrical resistivity" for tungsten is .0046 per degree C at room temperature. This means that if the temperature of the incandescent element of the bulb increases by, say, 3000 degrees C, then the resistance will increase by a factor of something like 3000*.0046 = 13.8. (Actually the coefficient varies a LOT with temperature, but this gives one an idea of the magnitude of the effect).
TVP45
#9
Dec2-07, 07:44 AM
P: 1,127
Thanks. I am familiar with the increase in resistance; I just didn't know the name.
One of the easy ways to answer this question (other than just try it) is to see that the question is general (i.e., higher and lower power bulbs in series) reather than specific (i.e., 100W and 60W). Then you just imagine a 10000W bulb in series with a 10W one and it can be seen that the 10000W bulb is equivalent to a piece of copper wire and thus not bright at all at the current permitted by the 10W bulb, but the 10W is at full brightness since it is not in any way limited.
khamaar
#10
Jun22-11, 10:58 AM
P: 14
May i ask why " P= V^2/R " was used to calculate the Resistance of the individual light bulbs? In doing so, the voltage in each case was taken constant. (120 V in second reply) How is this possible?. The voltage across the bulbs in series is not constant!!!
If " P= (I^2)R " is used to calculate the resistances of the bulbs, and considering that "I" for all the bulbs is constant, (being in series) ; we conclude that the 100W bulb has most resistance. You may try it.....
I dont know, i may be wrong, if im wrong , then im wrong in selecting which formula to use, so do help me out.
Thanks
phinds
#11
Jun22-11, 11:21 AM
PF Gold
phinds's Avatar
P: 6,340
Quote Quote by khamaar View Post
Thanks
You're not exactly wrong, you have just not understood what was being calculated.
This was NOT done implying that the bulbs each drop 120volts in the circuit described, it was an individual calculation of the resistance of each bulb based on the fact that they dissipate the stated amount of power WHEN DROPPING 120volts. This resistance was THEN used in the circuit described.
Register to reply
Related Discussions
3 light bulbs 3 switches Fun, Photos & Games 9
Circuts and Light Bulbs Advanced Physics Homework 1
How to treat BULBS in circuits? Introductory Physics Homework 10
Saltwater and light bulbs Electrical Engineering 3
Light bulbs in Series Introductory Physics Homework 2
