Does the Atom Have to Be U238 in Schrödinger's Cat Experiment?
  • Context: Undergrad
  • Thread starter Thread starter Andre
    Box Thinking
The discussion revolves around Schrödinger's cat thought experiment, specifically questioning whether the radioactive atom involved must be U238 and exploring the implications of the atom's decay on the cat's fate. The scope includes conceptual reasoning and interpretations of the experiment.
  • Some participants suggest that the cat is alive when the observer opens the box because the observer is also alive, implying a connection between their fates.
  • Others propose that the cat's survival is contingent on the atom not decaying within a specified time frame, with U238 mentioned due to its long half-life.
  • One participant questions the practicality of detecting a single alpha particle from one atom, indicating skepticism about the experimental setup.
  • There is a discussion about the reliability of the geiger-counter, with participants questioning whether it is functioning as assumed.
  • Some participants engage in playful commentary about thinking "out of the box" and the philosophical implications of the thought experiment.
Participants express differing views on the necessity of using U238 in the experiment and whether the cat's survival is directly linked to the atom's decay. The discussion remains unresolved with multiple competing interpretations and no consensus reached.
Participants do not clarify certain assumptions, such as the operational status of the geiger-counter or the implications of using a single atom for detection. The discussion reflects a range of interpretations without definitive conclusions.
Andre
A simple one, Schrödingers cat.
A cat is placed in a box, together with a radioactive atom. If the atom decays, and the geiger-counter detects an alpha particle, the hammer hits a flask of prussic acid (HCN), killing the cat.
Now why is the cat alive when the observer opens the box?
Answer:
The experiment wouldn't make sense if the cat were not alive at the time that the observer opened the box to put the cat in.
eom
okay let me rephrase, opening the box after N minutes after the start of the experiment. But good thinking.
Answer:
Because the observer is in the box with the cat. If the cat dies, so does the observer, and the box is never opened. If the observer opens the box, it means the observer is alive, and that means the cat is alive.
eom
Incredible how many way you can think out of the cat's box, It's starting to look like 'why did the duck cross the street'
Think proverbal.
Andre said:
Think proverbal.
I did early on, but I didn't think much of it. Answer:
The cat will only lose at most one of its nine lives. However, the cat may have lost eight lives before being confined, so this answer doesn't cover all cases.
eom
Right, So did Schrödinger think in of out the box?
Anyway, in another forum yesterday, I met an old forum buddy who inquired if I was still thinking out of the box while busy with a complex elaboration. So I replied that the quartenary box was way too small to think in so somebody else posted this picture
asking if this box was big enough. So I needed some ammo to dismiss the joke and carry on with the thread. So I explained why not even Schrödinger thought out of the box.
it's alive because that's the first time he opened the box to put the cat in!
Is there really a trick to this?
The cat is alive because the atom didn't decay in N minutes. The atom is U238, which has a half-life of 4.5 billion years.
Personally, I think the setup is shaky. One atom? How are you going to detect one alpha particle?
Are we to assume that the geiger-counter works?
Is there a reason to assume otherwise?
In that case, wouldn't the obvious answer be that the atom didn't decay?
You read post #9, right? :-p
Of course, but does the atom have to be U238?
  • · Replies 46 ·
9K
  • · Replies 143 ·
13K
  • · Replies 52 ·
  • · Replies 42 ·
  • · Replies 17 ·
  • · Replies 37 ·
  • · Replies 76 ·
10K
