Can F-Test Confirm Equal Variances in Radioactive Zones?
The discussion revolves around the application of statistical tests, specifically the F-test and t-test, to determine if the variances and means of measurements from two radioactive zones can be assumed to be equal. The original poster presents data from two zones and expresses uncertainty about their calculations and interpretations related to these tests.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply the F-test to compare variances and later considers the t-test for comparing means. Participants raise questions about the correctness of calculations and the interpretation of statistical values, including degrees of freedom and critical values from statistical tables.
Participants are actively engaging in verifying calculations and clarifying the application of statistical tests. There is a focus on ensuring the original poster understands the implications of their findings and the correct procedures for comparing variances and means.
There are indications of potential errors in calculations and assumptions regarding degrees of freedom, as well as the need to differentiate between one-sided and two-sided tests. The original poster is working within the constraints of homework guidelines, which may limit the depth of exploration.
Hummingbird25
Hi
I have been on some statistics and I am not sure that I am on the right track
Given two meassurement zones of radioactive vast:
[tex]\left(\begin{array}{cc} zone 1 & zone 2 \\ 55 & 55 \\ 44 & 24 \\ 47 & 57 \\ 61 & 37 \\ 15 & 51 \\ 36 & 33 \\ 29 & 39 \\ 69 & 11 \\ 8 & 42 \\ 32 & 80 \\ \ & 21 \\ \ & 26 \end{array} \right)[/tex]
Show that the variances can be assumed to the same in the two zones.
2. The attempt at a solution
I have looked up in my statischics book and found that the F-test looks to the best way to compare two variances.
Here goes:
[tex]\mu_{zone1} = \frac{\sum(X)}{N} = 39.6[/tex] and [tex]\mu_{zone2} = \frac{\sum(X)}{N} = 39.6667[/tex]
Next the Variance for the two zones
[tex]s^2_1 = \frac{\sum(X-\mu_1)^2}{N-1} = 367,56[/tex] and
[tex]s^2_{2} = \frac{\sum(X-\mu_2)^2}{N-1}= 507,04[/tex]
Then according to the F-test
[tex]f = \frac{s^2_{2}}{s^2_1} \approx 1.38[/tex]
which is according to my Schaum's outlines of Statistics and Economics that gives arround 75 degrees of freedom, and of the f-test(the two zones lies in the same population) and therefore the variances can be assumed to be the same.
I hope somebody will look at this and maybe help me to conclude if I have understood the problem correctly?
Sincerely Yours
Hummingbird
Did you mean to write
[tex]s^2_1 = \frac{\sum(X-\mu_1)^{squared}}{N-1},[/tex]
and similarly for [itex]s_2^2[/itex]? You should check your calculations.
You should compute one degrees of freedom for the numerator and another for the denominator. Also, in a 2-sided test, you should remember to divide the probability level ("alpha") by 2.
Howdy and thank you for your answer,
I have looked at the calculations and it was only in here that I had forgot the squares here.
Anyway the f = 1.38 and I look up 1.38 in a f-distribution table I get a df(nummerator) = 40 and df(denominator) = 400 where it says(1.57) with bold writing.
I divide 40 by 400?
Sincerely Hummingbird
Here is a sample table: http://www.itl.nist.gov/div898/handbook/eda/section3/eda3673.htm#ONE-05-11-20
Let's say your df for numerator (v1) was 20 and your df for denominator (v2) was 100. Then, the critical F0.05 value would be 1.676 such that (one-sided) probability to the right of the critical value is 0.05. Since your calculated F is less than 1.676, with these degrees of freedom (20 and 100), you would have been able to conclude that "the two variances are not different from one another at a 5% significance level in a one-sided test."
Thank you EnumaElish,
That leads to my second question, howto assume that the mean is the same in the two zones??
Can that be concluded by that as show above that the difference in procent between the two means are less than a procent??
Sincerely
Hummingbird.
That's a different test altogether, typically the t-test (in your case, with unequal sample sizes and equal variances).
Hello again EnumaElish,
Thank You for your answer,
Good then using the t test which you kindly referred to with equal variance and un-equal sample sizes.
I then get
[tex]S_{(\mu_{1} - \mu_{2})} = \sqrt{\frac{(10-1) \cdot 367.56 + (12-1) \cdot 507.04 \cdot \frac{1}{10}+\frac{1}{12}}{10+12-2}} = 3.29035[/tex]
Then [tex]\frac{39.6-39.6667}{3.29035} = -0.20271.[/tex]
Does that look okay?
Sincerely Yours
Hummingbird.
Possibly there is an error, see the parentheses I inserted around 1/10 + 1/12. You should check your calculation:
[tex]S_{(\mu_{1} - \mu_{2})} = \sqrt{\frac{(10-1) \cdot 367.56 + (12-1) \cdot 507.04 \cdot \left(\frac{1}{10}+\frac{1}{12}\right)}{10+12-2}} = 3.29035[/tex]
Once you check your calculation, you can compare your t-value against a t-table.
EnumaElish said:
Possibly there is an error, see the parentheses I inserted around 1/10 + 1/12. You should check your calculation:Once you check your calculation, you can compare your t-value against a t-table.
[tex]S_{(\mu_{1} - \mu_{2})} = \sqrt{\frac{(10-1) \cdot 367.56 + (12-1) \cdot 507.04 }{10+12-2} \cdot (\frac{1}{10} + \frac{1}{12})} = 9,02498[/tex]
where [tex]t = \frac{39.6667-39.6}{9,02498} = 0,007391.[/tex]
I have been Looking for a t-value which resembles this one, but couldn't find it. But its very close to the t-value t = 0.005. Which is 99,5 %. That must mean that are in the same zone or population?
How does it look now??
Sincerely
Hummingbird.
No. You should check the your calculated t statistic against the critical t-value from a t-table. For example, the critical t-value in a ONE-sided test at 5% significance with degs. of frdm. = n1 + n2 - 2 = 20 (see http://projectile.is.cs.cmu.edu/research/public/talks/t-test.htm#equalvariance ) is 1.724718 (from http://www.statsoft.com/textbook/stathome.html?sttable.html&1, under p = 0.05 column).
This means that if the calculated t statistic < 1.7247..., you cannot reject [itex]\mu_1 = \mu_2[/itex] at 5% in a ONE-sided test (that is, against the alternative hypothesis [itex]\mu_1 > \mu_2[/itex].
Two-sided t-test
If your alternative hypothesis is [itex]\mu_1 \ne \mu_2[/itex] then you need to run a two-sided t-test. At a 5% significnace level, that would mean [itex]\alpha/2[/itex] = 0.025 on each side (adding up to a total "tail" probability of [itex]\alpha[/itex] = 0.05). If you'd like to use the above-referenced t-table, you now need to look under the p = 0.025 column. For degs of frdm = 20, the critical t is 2.08596, which is the value to compare the calculated t statistic against. If calc. t stat < 2.08596, then one cannot reject the null hypothesis [itex]\mu_1 = \mu_2[/itex] against [itex]\mu_1 \ne \mu_2[/itex].
Two-sided t-test
I will do that and then return, but just one question. Is my t-value correct??
Sincerely Hummingbird.
Assuming you correctly calculated the means and the s, yes.
Since the two means aren't not completely a like i use the two sided test. Don't I ?
Very rarely the two calculated means are equal. The question (of 1-sided vs. 2-sided test) is theoretical not empirical.
For example, suppose you'd like to prove "the French aren't shorter than the Germans." Then you should run a one-sided test. However, if your hypothesis is "the French and the Germans are equally tall" then you should run a 2-sided test.
Hi Enuma,
Looking at the t-table here http://mips.stanford.edu/public/classes/stats_data_analysis/principles/t_table.html
Then 20 degres of freedom and t approx 0.01 that gives 2.528. Excuse me for asking, but does this sound reasonable?
Best Regards
Hummingbird.
Hummingbird25 said:
Hi Enuma,
Best Regards
Hummingbird.
If this is yes. Then how I find the estimation?
Next 95% confidence interval for the commen mean and variance. Is that this http://en.wikipedia.org/wiki/Confidence_interval
BR
Hummingbird..
2.528 is right.
The estimated t statistic is what you computed as [itex](\mu_1-\mu_2)/s_{\bar{x_1}-\bar{x_2}}[/itex] in a previous post.
The 95% C.I. around the common mean is [itex]\bar {x} \pm t_{0.025}(n-1)s/\sqrt{n}[/itex] where [itex]\bar {x}[/itex] and s are respectively the computed average and the computed standard deviation of the entire sample, [itex]n = n_1 + n_2[/itex] is the sample size and [itex]t_{0.025}(n-1)[/itex] is the critical t value with 0.05 total (two-sided) tail probability and n-1 degrees of freedom.
The 95% C.I. around the common variance is [L , U] = [ [itex](n-1)s^2\left/\chi^2_{0.025}(n-1)[/itex] , [itex](n-1)s^2\left/\chi^2_{0.975}(n-1)[/itex] ], where [itex]\chi^2_p(n-1)[/itex] is the critical chi-squared value with probability = p (to the left of the critical value) and degrees of freedom = n-1.
  • · Replies 20 ·
