| Thread Closed |
finding spring constant |
Share Thread | Thread Tools |
| Nov23-08, 07:54 PM | #1 |
1. The problem statement, all variables and given/known data
In a 'worst-case' design scenario a 2000-kg elevator with broken cables is falling at 25m/s when it first contacts a cushioning spring at the bottom of the shaft. The spring is supposed to stop the elevator, compressing 3m as it does so. During the motion, a safety clamp applies a constant 17,000N frictional force to the elevator. As an energy consultant, you are asked to determine what the force constant of the spring should be. 3. The attempt at a solution The way I set up the problem was like this: Work done by noncons force + GPE initial+ KE initial+ EPE initial= GPE final + KE final+ EPE final EPE initial is 0. I set my zero as the point when the mass is coming to rest on the spring for a slight instant before compressing the spring. I assume the 25m/s is a constant velocity...? If so, then KE inital and KE final cancel. So I am left with: -fd + mgy0= mgyf + .5kx^2 thing is, then I have two unknowns, because I don't know the spring constant and I don't know what height it starts off at...If someone could point me in the right direction, I would greatly appreciate it:) |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov23-08, 08:06 PM | #2 |
Recognitions:
No, 25 m/s is not constant. It was 25 m/s at the point where the elevator first contacts the spring, then, at full compression, the speed is zero.
The energy going into the problem is KE+GPE. The height for GPE is the 3m it will compress. The dissipated energy is-Fd, ans you noted, where d is the same 3m. The remaining energy is in the spring. |
| Nov23-08, 08:15 PM | #3 |
Why is d 3m for -Fd? I thought the d would be the entire distance the elevator was falling? Because isn't Work done the total distance over which the friction acts?
| Nov23-08, 08:19 PM | #4 |
in the same vein, why would the h for the GPE be 3m as well? assuming that this is the initial GPE, wouldnt h be the height at which the elevator starts falling at? How do we know it starts at a height of 3m?
| Nov24-08, 07:47 AM | #5 |
Recognitions:
Your equation should reflect both terms.
KE of the initial 1/2mv² = 1/2kx² + 17000 * x Looks like everything is known but the spring constant k, which happily is what they asked you to find. |
| Nov24-08, 04:19 PM | #6 |
Recognitions:
| Thread Closed |
| Tags |
| elevator, spring constant |
| Thread Tools | |
Similar Threads for: finding spring constant
| Thread | Forum | Replies | ||
| Finding the Spring Constant | Introductory Physics Homework | 3 | ||
| finding spring constant with electron on end | Introductory Physics Homework | 1 | ||
| finding spring constant | Mechanical Engineering | 3 | ||
| Need help finding spring constant | Introductory Physics Homework | 7 | ||
| Finding Spring Constant | Introductory Physics Homework | 3 | ||
