Thread Closed
How do you derive the tidal force equation?
Share Thread Thread Tools
Apr7-05, 08:08 AM   #1
I've been trying to derive the Roche Limit and have been succesful for the most part but out of curiousity i was wondering how the tidal force equation was derived to be: -2GMmr/d^3 ??
Also on a related note i always get the constant at the front of the Roche Limit equation to be the cube root of two when apparently i should be getting two times this = 2.52, How is this constant found?
(i gather Roche gets 2.44 due to spheroid deformation).
Can anyone help with either of these problems.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr7-05, 01:54 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
The tidal force equation you give is just given by the derivative of Newton's Law of Gravitation:
[tex]F=\frac{GMm}{d^2}[/tex]
[tex]\Delta F=-\frac{2GMm}{d^3}\Delta r[/tex]
where [tex]\Delta F[/tex] is the tidal force and [tex]\Delta r[/tex] is the radius of the object. The reason we care about the differential force is that we want to know how the outer edge of the object is being pulled relative to its center of mass. If they were both being pulled by equal forces, there would be no deformation. The above equation is only an approximation, by the way. It won't be valid unless [tex]\Delta r << d[/tex].
As for the Roche limit, the derivations I've seen that get 2.52 usually make some sort of approximation like putting two equal-radius spheres next to one another and finding the distance at which they need to be from a massive object to have the tidal force pull them apart. My impression is that it's a fairly arbitrary approximation, but I guess it gives values closer to the rigorous treatment of spherical deformation.
Apr8-05, 02:37 AM   #3
Ah yes thankyou, i knew it was the derivative but didn't think to put the delta-r on the RHS.. i should have spotted this. I probably didn't because i was looking at websites that were taking the force at the front (d-r) of the object minus the force at the rear (d+r) and using this to calculate the differential force. I don't know if this is correct because there appeared to be some mistakes in their algebra with minus signs being misplaced etc, but would this account for the other terms that are missed out in this approximation?
To get 2.52 i did think that i would have to assume taking the whole diameter of the object but there would be problems with that. What you say about assuming two spheres being pulled apart makes sense more when picturing whats actually happening.
Thanks muchly!
May14-05, 05:09 AM   #4
In My Resnik-Krane book, i was doing a problem in which They told me to CALCULATE THE DIFFERENCE IN FORCE DUE TO MOON ON A POINT ON ONE EXTREME OF THE EARTH AND FORCE AT A WATER DROP AT THE CENTRE(BUT OUTSIDE OF EARTH) OF EARTH. I calculated the expression and they told me that this was called the tidal force and is reponsible for this phenomena,you also try it , it will give you an exact expression.
May14-05, 10:26 PM   #5
Recognitions:
Quote by student654321
The tidal force is the difference between the gravitational forces at 2
different distances:
[tex]
F_{tidal} =\frac{GMm}{d^2}-\frac{GMm}{\left( {d+\Delta r} \right)^2}
[/tex]
Find a common denominator
[tex]
F_{tidal} =\frac{GMm\left( {d+\Delta r} \right)^2-GMmd^2}{d^2\left(
[/tex]
FOIL the [tex](d+\Delta r)^2[/tex] 's
[tex]
F_{tidal} =\frac{GMm\left( {d^2+2\Delta rd+\Delta r^2}
\right)-GMmd^2}{d^2\left( {d^2+2\Delta rd+\Delta r^2} \right)}
[/tex]
Factor out [tex]GMm[/tex]
[tex]
F_{tidal} =GMm\frac{d^2+2\Delta rd+\Delta r^2-d^2}{d^4+2\Delta
rd^3+d^2\Delta r^2}
[/tex]
[tex]d^2[/tex] and [tex]-d^2[/tex] cancel each other
[tex]
F_{tidal} =GMm\frac{\rlap{--} {d}^{\rlap{--} {2}}+2\Delta rd+\Delta
r^2-\rlap{--} {d}^{\rlap{--} {2}}}{d^4+2\Delta rd^3+d^2\Delta r^2}
[/tex]
[tex]
F_{tidal} =GMm\frac{2\Delta rd+\Delta r^2}{d^4+2\Delta rd^3+d^2\Delta r^2}
[/tex]
Eliminate that which is not significant. Take advantage that d >> r
[tex]
F_{tidal} =GMm\frac{2\Delta rd+\rlap{--} {\Delta }\rlap{--} {r}^{\rlap{--}
{2}}}{d^4+\rlap{--} {2}\rlap{--} {\Delta }\rlap{--} {r}\rlap{--}
{d}^{\rlap{--} {3}}+\rlap{--} {d}^{\rlap{--} {2}}\rlap{--} {\Delta
}\rlap{--} {r}^{\rlap{--} {2}}}
[/tex]
[tex]
F_{tidal} =GMm\frac{2\Delta rd}{d^4}
[/tex]
Cancel the d the numerator with one of the d's in the denominator
[tex]
F_{tidal} =GMm\frac{2\Delta r\rlap{--} {d}}{d^{\rlap{--} {4}3}}
[/tex]
[tex]
F_{tidal} =GMm\frac{2\Delta r}{d^3}
[/tex]
Rearrange it to look like the formula in your post.
[tex]
F_{tidal} =\frac{2GMmr}{d^3}
[/tex]
I don't get the negative sign that you get.
May15-05, 12:05 AM   #6
Recognitions:
Quote by tony873004
[tex]
[/tex]
It's a matter of the coordinate system you work in. If [tex]\Delta r[/tex] is relative to the body imposing the force, then there's a negative. If it's relative to the forced body, it's positive. In general, it's easier to get these results by doing a first-order taylor expansion (effectively what I did) instead of deriving the full formula and taking the limit (effectively what you did). It's not wrong, just more tedious.
May15-05, 01:40 AM   #7
Recognitions:
Quote by SpaceTiger
I wish you'd read the homework help forums too. This is almost identical to the question I had asked last week. It took me hours to fail to figure this out. I only got it after visiting the teacher during office hours. That's why I was anxious to answer this thread with my new-found knowledge I think Doc Al was pointing me in the same direction you just described, but I'm no good at Calculus. Thanks ST.
May15-05, 01:42 AM   #8
Recognitions:
Quote by tony873004
Oops, sorry 'bout that.
I was preparing a talk last week and was barely able to post at all.
Dec17-08, 03:56 AM   #9
Hi
I'm doing an eksamen exercise for tomorrow about the science fiction book "The Inetgral Trees" by Larry Niven and tidal forces. One of the quiestions are if it is realistic with a tidal force at 1/5g (little italic g - g-force, not gram) at one of the trees (it is big trees looking like integral symbols from another solar system http://en.wikipedia.org/wiki/Integral_Trees) and I really don't understand how to do. So I hoped maybe some of you know it. It would be such a big help. And it's urgent
And sorry for my bad english. I'm danish
Thread Closed
Thread Tools
Similar Threads for: How do you derive the tidal force equation?
Thread Forum Replies
tidal force energy analisis with calculus (help please) Calculus & Beyond Homework 5
What is and how do we derive force (F) opposite the force of friction (Ff)? Introductory Physics Homework 1
tidal force, torque and precession Classical Physics 23
tidal force Introductory Physics Homework 1
Dark Energy a Tidal Force? General Astronomy 0
