Salt's Effect on Ice Melting Temperature: Investigating Latent Heat Absorption
  • Thread starter Thread starter philrainey
    Ice Salt
The discussion centers on the effects of salt on the melting temperature of ice and the associated thermodynamic principles, including latent heat absorption, entropy, and enthalpy. Participants explore theoretical implications, practical applications, and potential experimental setups related to refrigeration and phase transitions.
  • Experimental/applied
  • Some participants propose that adding salt to ice water lowers the melting temperature below 0 degrees Celsius due to changes in molecular interactions and entropy.
  • One participant discusses the role of entropy in phase transitions, suggesting that the presence of salt increases the entropy of the liquid phase, which affects the solid-liquid equilibrium.
  • Another participant questions whether the latent heat absorbed by melting ice in a salt solution is the same as that absorbed at 0 degrees Celsius, suggesting that the energy required may differ due to the endothermic nature of salt dissolution.
  • A participant speculates on the potential for achieving lower temperatures in refrigeration systems by using ice in a salt solution, proposing that it may require less energy to cool from 0 degrees than from -21 degrees Celsius.
  • Questions arise regarding the energy required to separate water from a salt solution through evaporation and whether this process is more or less energy-intensive than evaporating pure water.
  • Some participants discuss the implications of the exothermic and endothermic nature of salt dissolution and its effects on energy dynamics in the context of phase changes.
  • One participant considers the scenario of using a compressor to maintain solution concentration while removing water vapor, raising questions about energy dynamics in this process.
Participants express various viewpoints on the effects of salt on melting temperature and energy dynamics, with no consensus reached on the specific energy implications or the relationship between latent heat and temperature changes. Multiple competing views remain regarding the thermodynamic processes involved.
Limitations include assumptions about the behavior of salt solutions, the dependence on specific conditions such as temperature and concentration, and unresolved mathematical relationships between energy, entropy, and phase transitions.
This discussion may be of interest to those studying thermodynamics, phase transitions, refrigeration technology, and the effects of solutes on physical properties of solutions.
philrainey
When salt is added to a ice water solution it makes the ice melt at a colder temperture than zero degrees C. I'm told because it weakens the bonds that hold the ice together. Is the latent heat asorbed by the melting ice at the new lower temperture the same as if the salt was not added and melted at 0 degrees C? Is there the same amount of joules absorbed from the surroundings of the solution to melt the ice if the surroundings are above 0 degrees C?
Chemistry news on Phys.org
The main effect here is on the entropy of the liquid phase. Most phase transitions are due to what are known as order-disorder transitions. In such cases, there is a competition between the two phases. In the solid phase, the molecules are well ordered such that the interactions between molecules are optimized. This gives the system a low potential energy (enthalpy) at the cost of having low entropy (low disorder). In the liquid phase, the molecules have more disorder (higher entropy) at the cost of losing some of the optimal interactions (higher enthalpy).
Remember from thermodynamics that molecular systems would like to minimize their potential energy (like a ball wants to roll down a hill) and increase their entropy (like how it's easy for your room to go from an ordered state to a messy, disordered state but not the other way around). Thus, we have a problem with the solid-liquid transition. Going from solid to liquid raises the entropy (good) but also raises the enthalpy (bad). Conversely, going from liquid to solid lowers the enthalpy (good) at the cost of lowering entropy (bad). So, whether something is solid or liquid depends on whether lowering enthalpy or raising entropy is more important.
For reasons that are too complicated to explain succinctly now, temperature determines the relative importance of entropy and enthalpy. At high temperatures, systems would like to raise their entropy more than they would like to lower their enthalpy, and the opposite is true of lower temperatures.
So, how does salt play into this? Salt is largely excluded from the crystal lattice of ice so it does not significantly affect the enthalpy or entropy of the ice. However, salt dissolves in water, so it affects both the entropy and enthalpy of the liquid phase. The dominant contribution of the salt is to raise the entropy of the liquid phase.
Since the entropy of the liquid phase is larger in the presence of salt, water pays a larger entropic penalty when going from liquid to solid. Therefore at zero degrees Celsius, where the contributions from enthalpy and entropy were previously equal, the balance gets tipped toward the liquid form. This explains why salt can melt ice on roads. To regain the balance between the changes in entropy and enthalpy, one must go to lower temperatures since lower temperatures put less emphasis on the entropic penalty.
http://link.aps.org/doi/10.1103/PhysRevLett.95.148501"
I believe the amount of energy going into the melting ice from the surroundings would be slightly larger due to the addition of salt, as the dissolution of NaCl in water is slightly endothermic. However, this effect isn't connected to the freezing point depression, which occurs as Ygggdrasil described it. Salts that dissolve exothermally also lead to freezing point depression; it's a colligative effect.
why I asked this is because I was thinking if one can get the cooling at a lower temperture(-21) from ice frozen at 0 and put in a salt surray, one perhaps could get colder cooling for less energy (refrigeration energy)input as it takes less energy to cool from zero than minus 21. Perhaps adding a contaminate to another fluild (say CO2 ice in a liquid CO2 surray with contaminate).
if one trys to separate the water from salt solution by sucking (evapourating off) the water vapour with a compressor does it take more energy to do so than just evapourating pure water? the entropy of the solution is higher than if it were pure water so would there be a lower entropy difference between the salt solution to water vapour than to pure water to water vapour?( I'm thinking the vapour has a higher entropy than a liquid) Would this mean a higher boiling temperture to offset the smaller entropy gain?Or less heat asorbed in the latent heat of the water turning to vapour?
Less, it would seem; if the dissolution of NaCl in water is slightly endothermic, then the reverse reaction would be slightly exothermic.
there is two different energies here that we are talking about I think you are referring to the energy asorbed by the water as it boils (asorb less as there is energy released by the exothermic effect heats it a bit) but I was thinking more about the energy to drive the compressor to remove the water vapour and compress it to some fixed condensing temperture.
that is I was considering what happens if one has pure ice been dropped into a salt solution and a compressor removing the vapour to keep the solutions concentration the same, and that vapour been condensed and frozen at 0 degrees C before been returned to the solution.
  • · Replies 21 ·
9K
9K
