Difference between the average position and the most likely position of a particle
by TFM
Tags: average, difference, particle, position
TFM
TFM is offline
#1
Feb8-09, 09:18 AM
P: 1,031
1. The problem statement, all variables and given/known data
part (a):
What is the average position of a particle
part (b)
What is the most likely position of the particle
2. Relevant equations
N/A
3. The attempt at a solution
What is the difference between these two questions, because on first glance, I would have thought they were the same?
TFM
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
malawi_glenn
malawi_glenn is offline
#2
Feb8-09, 11:12 AM
Sci Advisor
HW Helper
malawi_glenn's Avatar
P: 4,739
They are not a priori the same, consider as an analogy the maxwell veolcity distribution:
http://www.ac.wwu.edu/~vawter/Physic...heoryGas05.gif
The peak is most probable-speed and the location on the x-axis where you have equal amount of probability to the left as to the right of that point is the mean-speed.
This is general for all probability distributions, e.g. wave functions in quantum mechanics. The most probable value and mean value only coincide if the distribution is symmetric around its maximum.
As an example, consider my Cheat - Dice:
It has 6sides, 4 of them has the value 1, and the rest of them has the value 6. What is the most probable outcome? And what is the mean-value of my dice? (a normal dice has 3.5)
TFM
TFM is offline
#3
Feb8-09, 11:19 AM
P: 1,031
Okay, that makes sense, since the two questions are:
(a)
Calculate the average position of the particle on the x axis, as a function of β. Mark the average position in your sketch.
(b)
Mark the most likely position of the particle in your sketch and calculate it as a function of β.
So for this, you will have to work out (a), using [tex] \int^\infty_\infty x P(x) dx [/tex], and for (b), locate its position on the graph. But how would you work out it's function?
TFM
malawi_glenn
#4
Feb8-09, 11:21 AM
Sci Advisor
HW Helper
P: 4,739
you have still not said anything about what course it is, and what probability density function you have. Also, show attempt to solution ....
TFM
TFM is offline
#5
Feb8-09, 11:28 AM
P: 1,031
Ops, Sorry,
Okay so, I have the P(x) to be [tex] B^2 x e^{-\beta x} [/tex]
Where B is a function of beta
We also know from the wave function that the integrals are actually between 0 and infinity, because the wave function is 0, thus:
[tex] <x> = \int^{\infty}_{0} B^2 x e^{-\beta x} [/tex]
Using integration by parts gives me:
[tex] <x> = [-\beta x e^{-\beta x} - \beta^2 e^{-\beta x}]^{\infty}_0 [/tex]
malawi_glenn
#6
Feb8-09, 11:36 AM
Sci Advisor
HW Helper
P: 4,739
ok, now you are not quite correct, if the probability function [itex]
B^2 x e^{-\beta x}
[/itex] is the wave function modulus square, then this is the mean value:
[tex] <x>
= \int^{\infty}_{0} x P(x) \, dx
[/tex]
So please make sure you have done this, you have written something else in post #3 ...
Then most probable, it is just to find where maximum of P(x) is located.
TFM
TFM is offline
#7
Feb8-09, 11:43 AM
P: 1,031
Isn't it normally though:
[tex] <x> = \int^\infty_\infty x P(x) dx [/tex]
But changes sometimes due to limits impsoed on the system, eg with this specific function it goes to:
[tex] <x> = \int^{\infty}_{0} x P(x) dx [/tex]
malawi_glenn
#8
Feb8-09, 11:48 AM
Sci Advisor
HW Helper
P: 4,739
Yes, but you said that [tex]
P(x) = B^2 x e^{-\beta x}
[/tex]
and then you performed this integral:
[tex]
<x> = \int^{\infty}_{0} B^2 x e^{-\beta x} dx
[/tex]
Which is just [tex]
\int^{\infty}_{0} P(x) dx \neq <x>
[/tex]
So be careful.
TFM
TFM is offline
#9
Feb8-09, 11:57 AM
P: 1,031
Okay fair, enough, I can also see what I have done...
P(x) actually is
[tex] B^2 \sqrt{x} e^{-\beta x} [/tex]
But the version I copied from my workings I had already inserted the extra x, making
So does my integral look right now:
and how do you insert the limit of infinity?
malawi_glenn
#10
Feb8-09, 12:01 PM
Sci Advisor
HW Helper
P: 4,739
if [tex]
P(x) = B^2 \sqrt{x} e^{-\beta x}
[/tex]
And if [tex]P(x) = \Psi (x)^* \, \Psi (x) [/tex]
Then
[tex] <x> = \int _0^{\infty} x\,P(x) \, dx = B^2\int _0^{\infty} x\, \sqrt{x} e^{-\beta x} \, dx[/tex]
Now I can give you a hint: [itex]xe^{-x} \rightarrow 0[/itex] when [itex]x\rightarrow \infty [/itex]
TFM
TFM is offline
#11
Feb8-09, 12:27 PM
P: 1,031
I feel silly, I should have know that [tex] e^{-\infty} \approx 0 [/tex]
[tex] = \int _0^{\infty} x\,P(x) \, dx = B^2\int _0^{\infty} x\, \sqrt{x} e^{-\beta x} [/tex]
Okay, so now:
[tex] B^2\int _0^{\infty} x\, x^{1/2} e^{-\beta x} = B^2\int _0^{\infty} x^{3/2} e^{-\beta x} [/tex]
Integration by parts:
[tex] u = x^{3/2}, du = (x/2)^{3/2} dv = e^{-\beta x}, v = -\beta e^{-\beta x} [/tex]
This gives:
[tex] -\beta x^{3/2} e^{-\beta x} - \int {(x/2)^{3/2} e^{-\beta x}}[/tex]
Hmm, I need to use the integration by parts again, but if I do, I will still be left with another integral that needs int by parts again... Have I done something wrong?
malawi_glenn
#12
Feb8-09, 12:33 PM
Sci Advisor
HW Helper
P: 4,739
you might want to do the integration starting all over again...
Hint: consider [tex]\int f g^{'} dx = fg - \int f^{'} g dx[/tex]
with
[tex] f(x) = x^{3/2} [/tex]
[tex] g^{'} (x) = e^{-\beta x} [/tex]
you have done the derivative of x^{3/2} wrong...
TFM
TFM is offline
#13
Feb8-09, 12:48 PM
P: 1,031
Okay, so:
[tex] f(x) = x^{3/2}, f'(x) = \frac{2}{5}x^{5/2} [/tex]
[tex] g'(x) = e^{-\beta x}, g(x) = -\beta e^{-\beta x} [/tex]
Thus:
[tex] -x^{3/2}\beta e^{-\beta x} - \int{-\frac{2}{5}x^{5/2}\beta e^{-\beta x} } [/tex]
Okay so far?
malawi_glenn
#14
Feb8-09, 12:49 PM
Sci Advisor
HW Helper
P: 4,739
f 'prime' means derivative of f
that is standard notation
are you sure you have done integration by parts before?
TFM
TFM is offline
#15
Feb8-09, 01:08 PM
P: 1,031
Yeah, I did it for A Level a few years back, although, we used u/v and du/dv. I can do most of them okay...
So:
[tex] f(x) = x^{3/2}, f'(x) = \frac{1}{2}x^{1/2} [/tex]
[tex] g'(x) = e^{-\beta x}, g(x) = -\frac{1}{\beta} e^{-\beta x} [/tex]
So:
[tex] = -x^{3/2}\frac{1}{\beta} e^{-\beta x} - \int{-\frac{1}{2}x^{1/2}\frac{1}{\beta} e^{-\beta x} } [/tex]
[tex] = -x^{3/2}\frac{1}{\beta} e^{-\beta x} - -\frac{1}{2\beta} \int{x^{1/2}e^{-\beta x} } [/tex]
Is this okay now?
malawi_glenn
#16
Feb8-09, 01:12 PM
Sci Advisor
HW Helper
P: 4,739
Nope, what is derivative of x^{3/2} ?
TFM
TFM is offline
#17
Feb8-09, 01:24 PM
P: 1,031
Okay:
[tex] f(x) = x^{3/2}, f'(x) = \frac{3}{2}x^{1/2} [/tex]
Thus:
[tex] = -x^{3/2}\frac{1}{\beta} e^{-\beta x} + \frac{3}{2\beta} \int{x^{1/2}e^{-\beta x} } [/tex]
Better?
malawi_glenn
#18
Feb8-09, 01:25 PM
Sci Advisor
HW Helper
P: 4,739
yes, now the second integral you have to do integration by parts once more.
Register to reply
Related Discussions
Position of a particle Introductory Physics Homework 6
Position of a particle Introductory Physics Homework 4
Position of a particle... Introductory Physics Homework 2
How do you find average velocity from a position-time graph? Introductory Physics Homework 2
Position of a Particle Calculus & Beyond Homework 2
