| Thread Closed |
Solenoid Question |
Share Thread | Thread Tools |
| Mar22-09, 10:56 PM | #1 |
Solenoid Question
1. The problem statement, all variables and given/known data
I ran an experiment to find the magnetic field inside a solenoid at different points using a magnetic sensor, attached to a computer and interface. Starting at the center of the solenoid and moving outwards to the end, I collected points at 1cm increments (starting at the center = 0cm, and then moving outwards to 6cm for each half of the solenoid). I calculated what the field should be theoretically at each point, and compared it to my findings from the experiment by using basic (%) error analysis. My experimental values were as much as 16% lower than the theoretical values and as little as 2/3%. What I noticed was that the error % was the greatest when the sensor was at the center of the solenoid and declined as the sensor was moved towards the end of the solenoid. What I don't understand is if the magnetic field is strongest in the center of the solenoid, why is the error the highest? I would think that a sensor would have an easier time accurately picking up a strong magnetic field as opposed to a weaker field. 2. Relevant equations http://www.mountainescapesproperties.com/Magfig4.gif 3. The attempt at a solution Distance Experiment B Theo. B Error (cm) (mT) (mT) (%) 0.000 5.056 6.045 16.36062862 1.000 5.007 5.964 16.04627767 2.000 5.039 5.721 11.92099283 3.000 5.023 5.531 9.184595914 4.000 5.068 4.820 5.145228216 5.000 4.527 4.229 7.046583117 6.000 3.608 3.612 0.09691264 -1.000 5.031 5.964 15.64386318 -2.000 5.023 5.721 12.20066422 -3.000 5.019 5.531 9.256915567 -4.000 5.039 4.820 4.543568465 -5.000 4.600 4.229 8.772759518 -6.000 3.588 3.612 0.650699155 |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Thread Closed |
| Tags |
| experiment, magnetic field, solenoid |
| Thread Tools | |
Similar Threads for: Solenoid Question
| Thread | Forum | Replies | ||
| Solenoid question | Introductory Physics Homework | 2 | ||
| Solenoid Question | Introductory Physics Homework | 1 | ||
| Electromagnetics (solenoid question) | Classical Physics | 3 | ||
| Solenoid question | Electrical Engineering | 15 | ||
| Solenoid question | Introductory Physics Homework | 0 | ||
