The discussion revolves around the concept of introducing a voltage-controlled variable delay in a monochromatic light beam, specifically focusing on methods to phase modulate the light. Participants explore various approaches, including the use of piezoelectric materials and liquid crystals, while addressing the technical challenges involved.
- Exploratory
- Technical explanation
- Debate/contested
- One participant inquires about the method to phase modulate a monochromatic light beam using a voltage-controlled device.
- Another participant suggests using microcontrollers with built-in ADCs to create a voltage-controlled delay circuit, questioning the accuracy required for the application.
- A participant proposes using a piezoelectric crystal mirror to vary the path length of the laser beam, noting potential mechanical issues and expressing interest in liquid crystals as an alternative.
- There is a question about whether the intention is to phase modulate the frequency of the light or to vary the phase of pulsed laser light.
- One participant clarifies that the frequency of modulation is ten megahertz and that the light source is continuous, not pulsed.
- Another participant expresses skepticism about achieving a 30 microsecond delay for light, suggesting the need for multiple optical fiber delay lines and questioning the feasibility of the proposed methods.
- A participant acknowledges a mistake regarding the delay calculation and expresses regret for the confusion caused.
Participants have differing views on the feasibility and methods for achieving voltage-controlled variable delay in light beams. There is no consensus on the best approach, and technical challenges remain a point of contention.
Participants mention various technical limitations and assumptions, such as the mechanical challenges of using piezoelectric mirrors and the complexity of achieving precise delays with optical fibers. The discussion includes unresolved mathematical considerations regarding the modulation frequency and delay times.
