Space Shuttle Over Kansas: A Discussion
  • Thread starter Thread starter dlgoff
    Discussion Space
The discussion revolves around a reported sighting of an unidentified flying object over Kansas, with participants speculating on the nature of the craft, including comparisons to known aircraft and potential military involvement. The scope includes exploratory reasoning and technical speculation regarding the appearance and identification of the object.
  • Some participants suggest the object resembles a space shuttle piggybacked on another vehicle or a ground-effect craft.
  • Others propose it could be an E-3 AWACS or a modified aircraft, with one participant suggesting it looks like a Saab Drakken with a prototype engine.
  • There are claims that the Air Force's lack of comment raises questions about the nature of the sighting, with some speculating it could be a test flight.
  • Participants discuss the angle of the photograph and its impact on the perceived shape and size of the craft, noting the absence of visible under-wing engine nacelles.
  • Some express skepticism about the authenticity of the photograph, suggesting it may be doctored or misrepresented.
  • Several participants share personal experiences and expertise in photography and aviation, questioning the validity of the photographer's account and the technical aspects of capturing the image.
  • Disagreements arise regarding the interpretation of the sighting and the credibility of various claims, with some participants defending the photographer's perspective while others challenge it.
Participants do not reach a consensus on the identity of the object or the validity of the photograph. Multiple competing views remain, with ongoing debate about the nature of the sighting and the implications of the Air Force's response.
Limitations include the lack of detailed context about the photograph, such as camera specifications and environmental conditions at the time of the sighting, which may affect interpretations of the image.
  • #61
DaveC426913 said:
well, it's certainly a fresh perspective, I would not have considered that upper tail-and-pod to be a horizontal wing-and-pod.
But your extrapolated interpretation doesn'r hold water if you now compare it back to the original image (instead of nottheone's touched up version).
It seems that the original image link is broken, but I think it is the same as this image I found on Google: http://kwch.images.worldnow.com/images/incoming/images/misc/ufo_original.jpg
Why do you think it does not "hold water" compare to the original image?
Science news on Phys.org
  • #62
Because your interpretation is taking advantage of "enhancement artifacts" introduced by nottheone's processing. If you take your new interpretation image and place it next to the original, you'll find a lot more tweaking will be necessary to reconcile the two.
notheone's image blurs many edges, making it easier to interpolate straightish lines where there were none (eg. 1] port wing, trailing edge and 2] nose taper). If you now put your interprertation next to the original, you'll see that the trailing wing edge is not continuous and the nose taper is completely different. Those are just a few examples.
  • #63
2 ideas...
Flying mole cricket with a jet strapped to it's back... Coming at us and to the right... lol
http://paynomind.com/media/1/20090201-mole cricket.jpg
Or going away from us and to the right a B2 with a jet strapped to it's back. Kinda like this, only the nose angled up a little more, and pointed away from us a little more: http://www.fas.org/nuke/guide/usa/bomber/b2bombs.jpg
As the first flyby happens watch the angle of it... http://www.metacafe.com/watch/775852/b2_spirit_fly_by_at_airshow/
Not saying it was a B2, but maybe something similarly shaped with a jet of some sort on the back.
  • #64
I'm not quite following the points you raised, however, the fact that it is missing a vertical tail fin seems to definitively rule out the perspective I suggested.
After taking another look at the original image, I realized that it's absolutely impossible for this to be a plane of any kind at all. Based on the focus of the tree in comparison to the object it's clear that the object is significantly nearer to the camera than the tree, and that it's size is therefore quite small.
Then taking another look at the image, I'm almost positive that this is a picture of a bird. There is a downward curve in the front characteristic of a beak, and a flat tail in the back with no vertical fin indicative of a bird's tail feathers, and the odd structure over the torso is easily explained by motion blur between the flapping wings.
The bright spots aren't lights, they are reflections. Bird feathers can be quite reflective, especially when wet.
http://img5.imageshack.us/img5/3016/crowp.jpg
  • #65
Hang on. Your conclusion is non sequitur. While it is notable that the tree and object seem to be differently in focus, there are myriad reasons for this that do not result in a complete dismissal of the eyewitness account - which utterly contradicts your interpretation.
  • #66
Eyewitness accounts can't really be trusted given the number of proven hoaxes (eg, loch ness, crop circles, flare-balloons...) that pervade this type of thing. Especially not when the eyewitness account is the only piece of evidence that doesn't have a direct explanation. In this case, an anonymous report of "I heard something...I took a picture...I think it was a plane" is not exactly convincing to me.
The circle of confusion in the image for the tree branches is ~4.5 pixels, and for the object it is ~10.5 pixels. The fact that these two numbers are different means that the objects are at different distances. If this were an airplane, one would assume that the distance of the object was greater than the tree.
However, that's not optically possible. As the distance of an object approaches infinity the change in size of the focus of confusion approaches zero, as illustrated by this animation:
From http://en.wikipedia.org/wiki/Acceptable_circle_of_confusion" , we can write the circle of confusion radius c as
c = A*abs(S2 - S1)/S2*f/(S1-f)
But in the same image, all of these are constants except for S2 (distance of the object), so for the purposes of the discussion it can be simplified to
c = k abs(S2-S1)/S2
where S2 is the distance of the object being imaged. The thing about this function is that c asymptotically converges quite rapidly to S1 as a function of S2. In other words, objects more distant than S1 have a very limited effect on increasing the size of confusion. That is why, for example, other very distant objects like the con trails still appear in focus in this image. If S2 is closer than S1, the size of circle of confusion increases very rapidly. This is the only way to explain the very large factor of 2.33 in the relative size of focus of confusion, and is conclusive proof that it is not an aircraft, but rather a small object in the foreground of the tree.
http://img24.imageshack.us/img24/4353/cocobi.jpg
Most people should not need to resort to math to come to this conclusion, though, because our brains are naturally capable of interpreting this type of information. This is why when you look at the whole image (not just the cropped part around the bird) it is quite obvious that the fuzzy object is close to the view, and a rough estimate of scale can even be perceived...
  • #67
Having gone to college for photography I am aware of depth of field geometry. But you are too sure of yourself (especially ironic as you flip-flop your sureness from post-to-post).
1] If you dismiss the observer's account you might as well dismiss everything. A picture means virtually nothing without the details of the account. In this case, we are actually lucky to have a witness account. One thing the witness account does is rule out that the object is small and nearby. Without the account we would have to consider that as a possibility.
2] As mentioned before, there are other reasons than differing distance why the two objects are not necessarily blurred the same way. Interestingly, you have already explicitly mentioned one of them in your own 'bird' account. Suddenly, now that you're sure it's a bird and not a plane, you seem to give it no consideration at all.
While you raise good points worth addressing, don't shoot yourself in the foot by making any claim "absolutely". Discussing anything with someone who is convinced of their rightness is a futile exercise.
  • #68
Awesome.
The original link seems to have rotted but I've found an image of it that's 3Megs.
And if that ones rots, I've saved it to my HD.
http://kwch.images.worldnow.com/images/incoming/images/misc/ufo_original.jpg"
  • #69
What factors could cause it to be blurry? The most common...
A) The object could be in the distance, greater than S1. I mentioned this possibility (that it is further away from the tree) only in order to disprove and rule out that possibility. If it were true, the con-trails in the far distant background show us the asymptotic limit of the radius of confusion on the far end, which is lower than the radius of confusion of the object. If the blurring is due to being out of focus, then this proves that the object is closer than the tree...and that's just based on the mathematics of it...
B) A fast moving distant object that is motion-blurred? There are a number of reasons why this explanation is not realistic. First, even a fast moving distant plane is not likely to cause motion blur because it's apparent speed on the image plane is divided by distance. If the shutter were open long enough to cause motion blur, the tree would likely have even more motion blur due to being shot from a hand-held camera. Second, the blurring on the tail is isotropic, indicating that it is due to being out of focus rather than motion blur.
C) The object could be in the foreground. This coincides with all visual evidence. There does appear to be some motion blur, and this is in support of it being closer, because a bird in the foreground is going to have dramatically more apparent movement in the image plane due to being so much closer (and having fast flapping wings).
On top of all this, if it were a distant UFO, just look at how big it would have to be...a lot bigger than any plane by my reckoning.
  • #70
It could be a kite (or glider) of some kind. If were seeing the belly of it from it's right side the little thing going down in front could be where the string attaches, and the string would be very hard to see with that much blurring. What you're saying about focus length does make sense, so that's why I ask. I could also see that easily being some kind of kite if you imagine it that way. At that angle the wings would be just about parellel to the ground and everything. Just an idea. I really have no idea.
  • #71
The object and the contrails are effectively at infinity. They will have the same level of focus.
You have not demonstrated how out-of-focus the contrails are, you are just taking it as a given.
It coincides with one piece of evidence if you interpret it that way. Your weapon is pointing at your foot and the safety is off...
One of most likely sources of the blur is camera-movement. That would explain why everything in the picture has (more or less) the same amount of blur and why the blur has quite sharp edges (look at the branches of the trees).
  • #72
[/URL]
I had to scan the entire thread to see if anyone else would mention a bird, this is a sight I see quite often in my back yard, as birds glide through the trees making an approach to land near the water pans, and my pool, which is now a fish pond.
  • #73
The con-trails are effectively at infinity (this was part of my argument)...the object is not.
I did not explicitly point that out because I thought it was obvious. If you zoom in on the two regions, it is evident that the object has a blurring radius that is larger than the maximum resolution of the contrail (see figure below). This shows that the object cannot possibly be at infinity with the con-trail as you suggest.
http://img10.imageshack.us/img10/1279/focus.png
(and now with altered levels just to show that the foreground object does indeed blur out to that amount)
http://img16.imageshack.us/img16/6537/focusb.png
Indeed, this is the basis of my argument...the con-trail being effectively at infinity shows the maximum radius of blurring that is possible to occur for an object due to being farther away than S1. Therefore, since the foreground object has significantly more blurring than the contrail, it must be closer than S1 and closer than the tree.
  • #74
You are putting far too much faith in your analysis of blurring.
  • #75
Blurring can be quite a reliable depth cue. It may not have high precision, but it is still reliable. It is well known that blur analysis is used as a depth cue in humans (on several levels). We even have computer software that can make 3D reconstructions based on blur analysis.
If you took a photograph of 2 balls that you knew were the same size, and you measured one of them to have a radius of 5 pixels and the other to have a radius of 100 pixels, you would take it as proof that the larger one is closer to the camera. That is the same level of confidence that can be drawn from the blurring in this image, the only difference is that we don't need to know how large the objects are to do the analysis.
My measurements may be crude, but I am only using them to show relative depth changes. In this case, all I needed to show to prove my point was that one circle is not the same size as the other by a statistically significant amount. In this case it's about 4 or 5 times larger, and the number of pixels under the area are effectively the number of measurements that corroborate that determination. So why are you so reluctant to believe it?
  • #76
The trouble is, they're not the same type of object. They couldn't be more different. One is black-against-light-sky, solid, opaque and sharp-edged, the other is white-against-light-sky, ephemeral, transparent and diffuse.
Dark objects and light objects do not blur the same way (light and lack-of-light are not two sides of the same coin).
  • #77
Blurring due to being out of focus is a purely geometrical effect caused by the aperture not being a perfect pinhole, and white objects do blur exactly the same way as black objects.
If anything, the con-trail having a softer edge in real life only strengthens my argument that the con-trail is more in-focus than the blob, because despite having a softer edge in real life, it still appears crisper in the image than the blob.
As for being transparent...it may be translucent up close but from afar it appears opaque. The only relevance that this would have on the analysis is that if the contrast from the background is too subtle, it would not be possible to determine the extent of the object's blur radius. In this case, the edge is distinctly visible, so it's not relevant.
  • · Replies 42 ·
16K
  • · Replies 35 ·
  • Sticky
  • · Replies 48 ·
71K
11K
  • · Replies 47 ·
11K
  • · Replies 30 ·
10K
  • · Replies 62 ·
13K
