Register to reply
Recursively defined numbers, need to show they are non-decreasing
by math_question
Tags: non-decreasing, recursive
Share this thread:
math_question
#1
Apr29-09, 11:32 AM
P: 2
Hello, I have a question involving a sequence of numbers [tex] \{a_n\} [/tex] defined recursively. They are defined as the positive solutions of the following set of equations.
[tex]1 = \frac{1}{a_1} = \frac{1}{(a_2+a_1)} + \frac{1}{{a_2}} =
\frac{1}{(a_3 + a_2 +a_1)} + \frac{1}{(a_3 + a_2)}
+ \frac{1}{{a_3}} = \cdots = \frac{1}{(a_n + a_{n-1}+ \cdots +a_1)} + \frac{1}{(a_n + a_{n-1}+
\cdots +a_2)} + \cdots + \frac{1}{{a_n}} = \cdots [/tex]
The first few can be solved analytically [tex] a_1 = 1, a_2 \approx 1.62, \cdots [/tex]. The rest can be found numerically.
However, instead of their values, what I need is to show that these numbers have to be non-decreasing, i.e. [tex] a_{n+1} \geq a_{n} [/tex] for all n.
Any ideas welcome.
Thank you.
Notes:
An observation that might be helpful is that, the numerical solutions show a_n's grow with natural logarithm. ([tex]\ln{(2n+2)}[/tex] seems to fit the numerical solution perfectly. ) Also, [tex]a_n \geq H_n, \text{\, where \,}
H_n = \sum_{k=1}^{n}\frac{1}{k} \text{\, is the $n^{\text{th}}$
harmonic number.} [/tex]
The numerical solution suggests [tex] a_{n+1} - a_n [/tex] goes to zero as n goes to infinity. So this might suggest induction is the way to go for the proof. Assume non-decreasing up to a_n, show that [tex] a_{n+1} \geq a_{n} [/tex].
Phys.Org News Partner Science news on Phys.org
Suddenly, the sun is eerily quiet: Where did the sunspots go?
'Moral victories' might spare you from losing again
Mammoth and mastodon behavior was less roam, more stay at home
Register to reply
Related Discussions
Decreasing numbers equation Linear & Abstract Algebra 4
How many n-digit numbers have their digits in non-decreasing order? Set Theory, Logic, Probability, Statistics 0
How do I show that the real numbers are not compact? Calculus & Beyond Homework 10
Numbers with Non-Decreasing Digits General Math 32
Can I use an analogus function to show that the sequence is increasing or decreasing? Introductory Physics Homework 5
